Old Sep 23, 2003, 01:17 PM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
A question for the Filip 600 proud owners
Hi all,
I'm building a new wing for my old electric sailplane (yes Andy, I'm still on it)
I like the Filip 600 wing and I've got a very positive feedback from the related threads I've been reading.
Here's the question: how many dihedral degrees has each wing section?
Each wing section is 1/4 of the total wingspan?
RookieOne is offline Find More Posts by RookieOne
Old Sep 26, 2003, 12:56 PM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
OK, I see there're no Filip 600 proud owners.
C'mooooon!!!!!
Old Sep 26, 2003, 01:10 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I'm not able to measure mine at this time..
..a
Old Sep 26, 2003, 01:56 PM
Weisse Luft is offline
Find More Posts by Weisse Luft
Joined Sep 2003
Two different wings on the 600. E or sport? I'll assume E as the Sport wing is sheeted and spar-reinforced foam.
I don't know about the angles but would appreciate any info on building one as this would be great to have for no-wind sailing on my 600 Sport fuselage, if the bolt holes aligned(???). I wouldn't mind building one myself, possibly with a bit more washout and flaps
Weisse Luft is offline Find More Posts by Weisse Luft
Old Sep 26, 2003, 05:24 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
If you build it yourself, the bolt holes would be wherever you made them - the chord shouldn't be an issue, at least on my fuselage the rear section is pretty flat.
I might be able to do something for you later..
..a
Old Sep 27, 2003, 09:42 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Don't let it be said I'm not a nice guy..
..a
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Old Sep 27, 2003, 10:13 AM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
..a
just ask tic
(sorry Andy that one was to easy...)
soholingo is offline Find More Posts by soholingo
Old Sep 27, 2003, 01:23 PM
Joined Sep 2003
Yes, if I built one, it would be a no-brainer to align the holes. I think an ARF E wing is available and the holes might need a tweaking.
Old Sep 29, 2003, 03:31 AM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Clear as cristal Andy. Thanks a lot.
Seems to have 1 degree at center section and 3 degrees at the wingtips.
Does it sound correct to you?
BTW: Andy is a nice guy!!!
Old Sep 29, 2003, 07:57 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
"not quite flat" in the middle is how I'd describe it.
I had no flat surface available on which to measure..
..a
Old Sep 29, 2003, 08:02 AM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Not necessary. I did it using your picture. Pinted it and measured using the TTOUUTMD (that thing one usually uses to measure degrees).
It's 3 degrees center section and 6 degrees wing tips.
Thanks again.
Old Sep 30, 2003, 12:26 PM
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Can you confirm the dihedral degrees I've measured?
Here's the first template for the sd7037 wing root. Yapppeeeee!!!
BTW: which should be the correct wing incidence? 2-3 degrees?
Bye,
Michele
Old Sep 30, 2003, 04:13 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
With the V-tail in place and my reinforcement installed, I have no way to measure that..
..a
question for the mini speed wing owners gazza2003au Flying Wings 16 May 31, 2006 03:03 AM
Power setups for Filip 600 Sport Rainman-ACRF Sailplane Talk 2 May 28, 2004 04:10 AM
Motor mount for Filip 600 AndreyT Electric Sailplanes 2 May 08, 2004 10:54 PM
Best battery for Filip 600 w/geared Speed 500??? jshelton Electric Sailplanes 13 Apr 27, 2004 03:14 PM
Question for MM DuskStick and Cessna Owners. rcav8r2 Parkflyers 11 Dec 18, 2002 07:34 PM
