Old Nov 03, 2011, 06:48 PM
peternemser is offline
Find More Posts by peternemser
Joined Nov 2011
Figuring out electric engine size for my flying wing.
I am building an epp flying wing, I need to determine what size electric engine to use. My wing will be 80 inches. Is there a formula? Weight to wing area? In addition, I want to do long range flights, how do I determine which type of electric engine to use. Are the more expensive ones any better than the cost effective Chinese?
Any thoughts would be appreciated.
peternemser is offline Find More Posts by peternemser
Last edited by peternemser; Nov 03, 2011 at 06:50 PM. Reason: Left out some information
Old Nov 03, 2011, 07:15 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
There are a few more factors that will affect your final choice besides wingspan.
You say you want to do long-range flights, so let's start there. How long is "long"? A mile? Ten miles? More? Virtually anything is possible, but a plane set up to fly a mile will need a vastly different motor than one intended to make it, say, fifty miles from the starting point.
An eighty-inch wing powered like a slowish sport plane (40mph cruise) might cover around ten miles in one flight, figuring on an average speed of 40mph for about 15 minutes.
Additional information would be helpful, though. What type of wing is this (chevron, delta, plank, forward-swept etc.)? What kind of aspect ratio are we dealing with? Pics would certainly help.
Piece is online now Find More Posts by Piece
Old Nov 03, 2011, 11:19 PM
Joined Nov 2011
Capture 80 - By Mclain
I would like to cover flights up to 40 miles. Live out in the West with lots of open space.
Wing span is 80 inch.
Wing area is 1072 sq. in.
CG from nose is 9 1/2 in.
http://www.mwcores.com/servlet/Detail?no=217
Old Nov 04, 2011, 10:19 AM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
How do you plan on controlling the wing- I assume some sort of high gain tracking device?
boingk is offline Find More Posts by boingk
Old Nov 04, 2011, 12:18 PM
Joined Nov 2011
Tracking the plain...
I would like to use a programmable gps unit to load up missions and fly. Honestly, I am venturing into this realm, so sure a high gain system sounds good. Can you provide some reference links. I am using this as a proof of concept for the local mountain rescue. We get a lot of people lost in the mountains where I live. Real helicopters are expensive....
ps. excuse the mispelling of plane.
Old Nov 07, 2011, 04:08 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
You will want to check out the FPV subforum, there is a mile of information there for you to get stuck into!
The big thing is to start out small... try checking out the HobbyKing website and looking at their 5.8GHz 200mW transmitter/recevier package. This will give you around 1km of range in stock form and can easily be upgraded with better antennas (bought or homemade) and tracking devices to give up to 8km of range or more. The best thing is its inexpensive so you can upgrade later on if/when you want.
Anyway, the reason to start out small is that it is easy to get disoriented - and thats with a system that functions perfectly! Trying out a new system on a new plane will really test you... the last thing you want to do is try going long range on top of that. There is also the risk that the system will fail and you will lose the plane you worked hard to buy and build - taking small steps will help all but eliminate this as a factor.
If you wanted to check out my blog for some basic FPV info then just click on my username. I've put a bit up there recently so it should be of some help at least.
Cheers - boingk
Wanted trade my nitro engine/airframe for your electric plane-SW Michigan thebuckeye Aircraft - Electric - Airplanes (FS/W) 2 Sep 23, 2012 07:42 AM
Cool For all electric plane enthusiasts!!, check out my new page L00K! cloudhopper14 Other Websites 10 Oct 08, 2011 11:22 PM
Wanted 48" Flying Wing/Combat Wing Electric wbrannies Aircraft - Electric - Airplanes (FS/W) 8 Sep 30, 2011 08:20 PM
Discussion What is the proper size engine for my electric glider? hiTmanhiT Electric Sailplanes 27 Jul 03, 2010 10:28 PM
Question Prop size/gearbox for my flying wing vtecorsair Foamies (Kits) 5 May 22, 2004 11:02 PM
