Old Nov 03, 2011, 04:52 PM
LouScarlino is offline
Find More Posts by LouScarlino
Chappaqua New York
Joined Aug 2004
From whom can we rent a pool to run boats?
We're looking for a company that rents pools large enough to run electric boats on at the 2012 WRAM Show which will be held at the Meadowlands Expo Center in Feb 2012. Any assistance would be sincerely appreciated.
LouScarlino is offline Find More Posts by LouScarlino
Old Nov 03, 2011, 05:28 PM
catchthis is offline
Find More Posts by catchthis
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
There was a very big one that ran rc boats in it at the NY boat show last year. Dont know of the company.
catchthis is offline Find More Posts by catchthis
Old Nov 03, 2011, 06:01 PM
RCBoater is offline
Find More Posts by RCBoater
Webmaster, MMCNE
United States, NH, Derry
Joined Feb 2000
Speedboats or scale boats? That will certainly affect the size of the pool.
Maybe you should look to rent a skating rink.
Our club has a portable pool that we use for events-- it is basically assembled like a skating rink-- 2x10s bolted together and then a large liner (tarp) is laid into the frame and filled with water.
Here's a picture of the pond in action at the 2006 Salem Maritime Festival. (We do this every year.)
RCBoater is offline Find More Posts by RCBoater
Old Nov 03, 2011, 06:12 PM
frankg is offline
Find More Posts by frankg
Joined Dec 2004
LOU- You might want to look into the way they set up the pool in the old MARC show down in Timonium, MD. They use cement blocks, two high around the outside with a tarp liner. You will however have top have a pump of some type to empty it out. Two cement blocks high will net you about 14 inches of water. Plenty of water for the model boats sans the sail boats and subs.
Good Luck on the search for the pool. Rich Koll (frankg)
frankg is offline Find More Posts by frankg
Old Nov 03, 2011, 06:18 PM
frankg is offline
Joined Dec 2004
Hey LOU- Do you think we could make a movie about this along the lines of , “BUILD IT, THEY WILL COME”. Might make a little money for the club on the side. HO!! It will only work if we can get GAR WOOD came out of the fields.
Old Nov 03, 2011, 06:19 PM
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
Why didnt I think of that. Use ply and 2x4 bracing. The tarps we used to get to cover our pool were 60'x40' so that is a decent pool.
Old Nov 03, 2011, 06:36 PM
RCBoater is offline
Webmaster, MMCNE
Joined Feb 2000
Correction-- Our pool is not built with 2x10s, but with 3/4 inch plywood-- the pieces are 4 feet long and about 12 inches high. The are bolted into metal frames that we bought from an ice rink supplier long ago.
Here's another design-- an all-wood idea:
http://www.mybackyardicerink.com/build-rink-boards.html
If you google backyard ice rinks, you'll get all sorts of leads....
Old Nov 03, 2011, 08:45 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Our club is trying to sell off it's portable pool. We just don't use it any more, and the price would reflect that! I looked through all the photos I have on file and I don't have a good one handy.
The pool is 20' x 40' and just under a foot deep. The frame sections are built from 2x12 timber (yes, they are a bit heavy). Some light ply and pink foam, about 18" tall, rests inside the frame to keep the sloshing waves from escaping. A custom built pool liner fits inside the frame. The liner was professionally fabricated by a local pool/spa installer and has square, welded corners. The liners' color is blue and white speckles. And the whole thing comes on it's own single axle trailer!
If you, or your club, are interested in obtaining this unit, please contact me ASAP! We had made a decision at our last club meeting that since there appeared to be very little local interest were were going to break up the entire setup so we wouldn't be charged another year of storage. I don't believe anything has moved yet, but time is running out!
Dave
boater_dave is offline Find More Posts by boater_dave
Old Nov 03, 2011, 09:46 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Temp. pool,
Talk to a company that does Hazmat, Emergency Services. The double tube type pools are almost 24 inches high, you fill them to no more than partway up the second tube. A "double size", pool is large enough to run most RC boats. The problem with them is that care must be used, not to puncture the tubes. Unlike a hard side pool, that just leaks, if the tubes fail, you are going to have a LOT of water were you don't want it. They have been used for shows several times on the West Coast, BUT, we have always used them outside. At the end of the show, we have just dumped them into the street, or bay. With a preapproved plan, and permit, by the Fire Dept., and the Venue we were at. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Nov 04, 2011, 04:40 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
First thing to check if making one is - how big of a tarp/pool liner can you get?
Then - will it stand up to re-use? Most pool liners assume that it will be installed and left, any warranty would be voided as soon as it was packed up for storage.
Next - Who is going to look after the parts between shows? A pool in component form can be big.
mfr02 is offline Find More Posts by mfr02
Old Nov 04, 2011, 05:58 AM
Prins Willem is offline
Find More Posts by Prins Willem
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
The pool the Wisconsin Maritime Museum sets up for us is ply backed with 2x2 & 2x4. The sides have gussets for support and cables run under the liner to prevent spreading. The liner is a tarp from Menards. Size of the pool is approx 20' x 30'x 12". Our original pool liner was Visqueen vapor barrier we bought in rolls from a local concrete company. Doing mall shows we couldn't risk leaks so we went to a commercially made liner ss boater_dave said above.
As far a renting a pool talk to an above ground pool store and see if they would set up a demonstrator in exchange for putting an ad on the side. Clear any advertising deal with the show organizers first.
Prins Willem is offline Find More Posts by Prins Willem
Old Nov 04, 2011, 08:15 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Lou nice to see you on here, looking forward to February.
Try Gary at Cabin Fever I know that he has 2.
He setup a good size one every year and one year he did a 2nd for me.
www.cabinfeverexpo.com
I’ll give you a call.
John Gill
Commodore
South Orange Seaport Society
GILL RC is offline Find More Posts by GILL RC
Old Nov 11, 2011, 06:41 AM
Chappaqua New York
Joined Aug 2004
Thanks to all of you, and John Gill in particular, for your suggestions and offers. We've made a connection for a 20' x 40' pool. Whether or
not we will install it at the 2012 Show is dependent on cost and space availability. We'll keep you informed.
Discussion Building a pond/pool for r/c boats shipcollector5 Scale Boats 24 Oct 08, 2011 11:50 PM
Discussion Can we build something like this from scratch? mrexcel Foamies (Scratchbuilt) 6 Jul 07, 2011 01:55 PM
Discussion Went out to run some boats, randomly ran into a couple guys from OSE. wparsons Racing Boats - Electric 7 Jun 27, 2011 10:02 PM
Discussion Can we move on from choo choo trains now? plowboy1966 Life, The Universe, and Politics 26 Mar 31, 2011 08:34 PM
Help! Can we get 1S power from 2S LiPo? Merog Batteries and Chargers 11 Mar 08, 2011 01:48 PM
