Old Jan 04, 2012, 10:27 AM
3Don is online now
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Aileron servo selection depend on what you expect from plane. If build super light, and you don't want crazy roll authority single JR290 will be good enought. But if you want hi end setup, i would recommend putting two JR290 on ailerons, and connect them to 2s lypo (as far as i know this works fine, but manufacturer does not recommend this). Single servo option would be Hitec 65hb.
3Don is online now Find More Posts by 3Don
Old Jan 09, 2012, 05:11 PM
3Don is online now
3Don's Avatar
Joined Nov 2004
Great news just came back home from Spain and i find Sultimate V3 kits. New Sultimate looks Awesome, very bright color sheme, and some new neat details. I will give you more details tomorrow and show you some close pictures.
Old Jan 10, 2012, 03:43 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by 3Don View Post
Great news just came back home from Spain and i find Sultimate V3 kits. ...
How was Spain? Looking forward to a Facebook Update.
One video I have already found:
XTIC 2012 Donatas Pauzuolis.... (4 min 50 sec)
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 13, 2012, 04:19 AM
hstv is offline
Find More Posts by hstv
Andres Girabel
hstv's Avatar
España, AL, Málaga
Joined Jan 2012
...The same video for app mobile or blogs pages in :
http://www.videofy.me/v/362150
....good job from Don here in Spain, really.
hstv is offline Find More Posts by hstv
Old Jan 13, 2012, 01:16 PM
Max Se is offline
Find More Posts by Max Se
Joined Feb 2011
One other very nice plane Donatas !
Why did you prefer the Arrow for freestyle? Witch one have more wing area?
Thanks.
Max Se is offline Find More Posts by Max Se
Old Feb 16, 2012, 05:31 AM
yellowdogaero is offline
Find More Posts by yellowdogaero
Joined Jun 2010
Hy guys, I just got the Kit, but i wonder where is the CG on this plane, if someone could help me out.
yellowdogaero is offline Find More Posts by yellowdogaero
Old Feb 17, 2012, 09:50 AM
Joined Jun 2010
Please Someone
Old Feb 18, 2012, 08:53 AM
iloveflying is offline
Find More Posts by iloveflying
Joined Dec 2011
hi donatas
hi donatas i just want to ask how can i built the plane if theres no build instructions on it and thank you
iloveflying is offline Find More Posts by iloveflying
Old Feb 19, 2012, 03:38 AM
Finnspeed is offline
Find More Posts by Finnspeed
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
I suppose Donatas doesn't have the manual for Sultimate ready yet but the Arrow V5 manual should be helpful, the planes are similar:
http://donatasdesign.com/downloads/M...owV5Manual.pdf
Apparently his web page is under heavy construction too but probably that link works regardless.
Finnspeed is offline Find More Posts by Finnspeed
Old Feb 19, 2012, 10:53 AM
3Don is online now
3Don's Avatar
Joined Nov 2004
Thank you for covering my back mate! Reality: this is first year starting my own business and so far i do everything alone. So sorry for delay with manuals, Sultimate can be build using Arrow manual for sure. I will check exact CG on my plane when i return home, Right now im on the way back from Finland F3P championship.
Old Feb 20, 2012, 06:08 AM
F3A Team Finland
Finnspeed's Avatar
Järvenpää, Finland
Joined Nov 2005
You are most welcome! It was nice to chat with you in Iittala and I hope you will make it back home OK. Your AM routine was extremely cool and you deserved the win.
The F3P FAI competition was also very exciting and I enjoyed competing against Evaldas and all the other guys in Sport class.
***Risto***
Old Feb 21, 2012, 10:07 AM
DaveL322 is offline
Find More Posts by DaveL322
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
I test flew my V3 this weekend. While there are no instructions, the assembly was pretty easy and very much like the Arrow V5 (instructions link previously posted).
Couple points -
- Thicker CF rod is for LG, wing spars, and aileron pushrods.
- Thinner CF rod is for tail and fuselage bracing.
- Flat CF is for wing LE and TE and fuse sides, and strengthening the aileron counterbalances and ele center section.
- Locations for all the CF rod gluing locations are marked on the foam with small holes.
I used a little bit of extra fiberglass cloth in a few places (I always have) and added pinned hinges at the attachment point of all control horns to strengthen the hingelines.
I built mine with an Eflite Park 280 as a test for the motor. Very efficient, but power is down a bit to the Hacker A10-9L, and further behind an AXI 2203 RACE or Neutrino 1215-6Y. 9x4.7 or 8x6 should put the power close to a 9L, but I didn't have any of those with me.
The CG location marked on the wing is at 220mm from the nose. For me, the airplane is very neutral at that location, and I prefer about 215mm, which requires just the tiniest bit of down elevator.
With Thunder Power ProPower 65C 25, Castle Creations Phx 10, JR290G ail, JR188 rud/ele, and Spektrum AR6115E, weight on my plane is 5.3 oz (150 grams) with minimal measures to lighten the plane. Plane is very stiff and feels solid in the air.
I've flown the SUltimate V2 and Arrow V5 a lot. I would say this V3 is definitely a step up in performance from the V2, and pretty close to the Arrow for roll rates and corners, but, the Arrow still does tighter KE maneuvers.
I should have more kits in stock in the US in a couple weeks (Arrow and Symmetric are in stock now).
Some pics attached.
Regards,
Dave
DaveL322 is offline Find More Posts by DaveL322
Old Feb 21, 2012, 10:13 AM
DaveL322 is offline
Team JR
DaveL322's Avatar
Medford, NJ
Joined Jan 2004
Biggest difference is larger fuse on Arrow. Wing and stab are slightly larger on the Arrow.
Regards,
Dave
Old Feb 23, 2012, 07:33 AM
3Don is online now
3Don's Avatar
Joined Nov 2004
Couple points -
Some pics attached.
Regards,
Dave
Hello Dave thank you for very nice update and ideas about your setup. So far i had not so much time on V3 Sultimate, but soon i plan to make promotional video for this baby I agree plane fly better than V2
Old Feb 28, 2012, 09:31 AM
sarvenn is offline
Find More Posts by sarvenn
Sarven Bedikoglu
sarvenn's Avatar
Türkiye, Istanbul, Istanbul
Joined Jul 2009
Hi Don,
Is there any updates about the Sultimate V3. Any review videos or flight performs of your own?
I have Hacker 10-9L and AXI 2203/46 both with Hacker x-7 esc. I have GWS 8x4DD and 8x4.3SF props as well. Which combination would you suggest me to use on such a plane like sultimate v3 or arrow v5.
regards.
sarvenn is offline Find More Posts by sarvenn
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 07:22 AM
Discussion Donatas Design: Arrow V5 3Don Indoor Pattern/F3P 189 Oct 02, 2013 12:31 PM
Discussion Donatas Design: Symmetric 3Don Indoor Pattern/F3P 100 May 15, 2012 04:20 PM
Discussion Donatas Design: Arrow V5 3Don 3D Foamies 13 Jan 03, 2012 10:44 AM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 07:41 AM
