Old Nov 03, 2011, 09:46 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
Donatas Design: Sultimate V.3
Hello boys and girls, finally i receive Sultimate V3 first sample. I would say it looks amazing! I will review kit asap and give factory necessary updates for mass production. First kit is 44.5g, so with milling if we remove 9 grams, at weight of ~35g, it will be perfect kit for VPP with TVR system and AXI2203/40 motor.
SultimateVPP (7 min 19 sec)
This milled white kit in video also was just 35g.
I hope everything will go smooth and kits will be available after 4 weeks. Here are first pictures.
Another good news we made a deal with well known company in UK:
http://www.electricwingman.com/donatas-design.aspx
Please contact Mr.Paul and Simon if you live in UK ore Ireland, these gentleman's will be able to help you in near future.
3Don is offline Find More Posts by 3Don
Old Nov 03, 2011, 01:07 PM
HonzaS is offline
Find More Posts by HonzaS
Jan Spatny
Czech republic
Joined Nov 2004
That is great color scheme! Love it!
Jan
HonzaS is offline Find More Posts by HonzaS
Old Nov 03, 2011, 01:22 PM
leliommarino is offline
Find More Posts by leliommarino
leliommarino
leliommarino's Avatar
United States, MA
Joined Nov 2007
Can't wait to add this to my hangar
leliommarino is offline Find More Posts by leliommarino
Old Nov 03, 2011, 07:37 PM
high alpha is offline
Find More Posts by high alpha
new jersey
Joined Aug 2003
Whats the difference between the v2 and the new v3?
high alpha is offline Find More Posts by high alpha
Old Nov 04, 2011, 08:27 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
New Sultimate is slightly bigger. Elevator and Ailerons are bigger as well. Nose is shorter (this will help to set right C.G. in case you use VPP). Also rudder is little smaller, i found with TVR system its to much loading for servo. And besides that rudder connected with TVR will give more than enought rudder authority.
Old Nov 04, 2011, 06:29 PM
new jersey
Joined Aug 2003
Thx
Old Nov 25, 2011, 07:03 AM
Leelander is offline
Find More Posts by Leelander
Joined Jun 2007
The fuselage breaks often right behind the wing. Is the new fuselage wider at this delicate point?
Leelander is offline Find More Posts by Leelander
Old Nov 27, 2011, 08:51 PM
RCvehicleGuy is offline
Find More Posts by RCvehicleGuy
Mr. Foam, Tape, and Carbon
RCvehicleGuy's Avatar
Joined Feb 2011
I found that all foamies break right there, and when they do just forget about it. The carbon fuse bracing on the fuse keeps it together. All my home made designs do that and it is no surprise that these professional ones do it too. Just don't worry about it.
Look at it this way, when it does break it doesn't get any worse. It would actually be a smart idea to leave a small section there cut so that it has the give and won't make unsightly cracks.
Chris~
RCvehicleGuy is offline Find More Posts by RCvehicleGuy
Old Nov 28, 2011, 01:05 AM
jibber is offline
Find More Posts by jibber
Joined Jan 2009
Hi,
i usually lay/glue a flat piece of carbon (about 3 - 4 cm long) on the underside of the wing/fuselage connection. the long way. Like this it can flex a little bit, but it wont break.
this is slightly heavier than just tape - but lasting longer.
If you want to be on the very safe side, do it on the top as well.
cheers,
cyril
jibber is offline Find More Posts by jibber
Old Nov 28, 2011, 11:22 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Yes fuselage is wider here, so it will be slightly stronger here, but if you will crash hard this will be problematic place on the kit. There are several reinforcement options, but all of them add bit of weight. My recommended 0.3mm flat carbon on sides and fiberglass cloth that is included with kit, will help allot.
Regards,
Donatas,
Old Dec 23, 2011, 06:01 PM
3Don is offline
3Don's Avatar
Joined Nov 2004
Good news, SUltimate is already available ar www.autopartner.se . Mr. Per will be back to busines on 12.27. I will receive my Sultimate kits, after good week ore so.
My prototype is half way done, i hope to finish it durring christmas.
Happy holidays for everybody!
Donatas,
Old Dec 23, 2011, 09:27 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Donatas,
I tried to order one, but the checkout page keeps saying me email address has an "incorrect format".
The whole site is kind of "clunky"
If you are in touch with him, ask him to see what is up with it. Running Seamonkey (Firefox)
Site does not work at all in IE6, the only copy I have.
edit - tried ie8 today- same error
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 29, 2011, 08:53 PM
jackack is offline
Find More Posts by jackack
jackack's Avatar
Sweden
Joined Oct 2005
Hi,
I received my Sultimate V3 yesterday and today it is "fit for flight"
No problems at all to mount its parts or to get things straight, These model almost click togheter by them self!
This is my building log: http://www.svensktmodellflyg.se/foru...1&replypage=99
I hope Youll understand some of it, atleast with Google Translate ;-)
Weight: 157g with battery. Not super light = but reinforced well/ it is "stiff"
Setup
Servo: Hitec HS-5035HD, Hitec HS-5045HB
Receiver: R6004FF
Engine: Tiger 1806 (GWS 8x4)
Battery: Desire Power 380 mah 2s
Speed Controller: Techone 10 Amp
All my equipment comes from https://www.autopartner.se/
I know already this will be my absolute favorit F6B plane, I liked earlier verion of Sultimate, but this time im in love
Enjoy! // Jackack
jackack is offline Find More Posts by jackack
Old Dec 30, 2011, 04:09 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Hello Jack, very nice pictures, thank you for sharing! Looking forward to see your flying with new SUltimate.
Sultimate V.3 will be available for sale first week after new year, pre order yours now: donatasdesign@gmail.com
Old Jan 04, 2012, 08:36 AM
nate540 is offline
Find More Posts by nate540
Joined Oct 2006
Don
Is a 290G enough for the ailerons on this?
nate540 is offline Find More Posts by nate540
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don Indoor Pattern/F3P 34 Jun 13, 2014 07:22 AM
Discussion Donatas Design: Arrow V5 3Don Indoor Pattern/F3P 189 Oct 02, 2013 12:31 PM
Discussion Donatas Design: Symmetric 3Don Indoor Pattern/F3P 100 May 15, 2012 04:20 PM
Discussion Donatas Design: Arrow V5 3Don 3D Foamies 13 Jan 03, 2012 10:44 AM
Discussion Donatas Design and Sultimate XL plans for sale ! 3Don 3D Foamies 15 Jan 03, 2012 07:41 AM
