View Poll Results: How much foam do you consume?
1 bundle or less per year 83 33.88%
1-2 bundles per year 98 40.00%
2-6 bundles per year 42 17.14%
1-2 bundles per month 7 2.86%
2-4 bundles per month 4 1.63%
4 or more bundles per month 11 4.49%
Voters: 245. You may not vote on this poll
Old Apr 25, 2012, 11:10 AM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
wow i didn't know that. i going to have to try it.
papabatman is offline Find More Posts by papabatman
Old Apr 25, 2012, 11:38 AM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Great tip.
Thanks!
bz1mcr is offline Find More Posts by bz1mcr
Old Apr 25, 2012, 01:14 PM
dnebeker is offline
Find More Posts by dnebeker
United States, CA, San Diego
Joined Jun 2005
How do I get on the wait list?
I'm a little late to the party. How do I get on the wait list or know when the next shipment will be in to place an order?
Del Nebeker
dnebeker is offline Find More Posts by dnebeker
Old Apr 25, 2012, 01:35 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Maybe Fred has an idea of how to do this...I spent some time searching the forums to no avail. I'd like to form the foam in two axis at once so as to create a kind of "push-up bubble" in the wing pan.
My Lunatic prototype was built with PBIII wings that happened to come from a sheet having curvature in both axis. This was simple, purest luck that the curvature was regular and even enough that I could cut two wings of sufficient symmetry that the plane went together perfectly. See pics. However, my luck ran out after that one sheet (!) and I haven't been able to reproduce that effect again.
I've spent a lot of time with the heat gun on various materials trying to get a dome shape curved into my wings. Any idiot (well, me) can get a panel to curve in one direction or the other. The trick here is to get it to bend in both X and Y axis simultaneously. This has proven impossible for me.
Any ideas?
A Useless Geek is offline Find More Posts by A Useless Geek
Old Apr 25, 2012, 01:55 PM
TheOne420 is offline
Find More Posts by TheOne420
Chad
TheOne420's Avatar
United States, CA, Cathedral City
Joined Dec 2010
Any ideas?
i know when you pull the paper off one side of the foam board it will cause this same "bubble" effect you are looking to replicate. maybe you can do some tests like adding a newspaper skin on one side then let it dry with no pressure to hold it flat and it may give you the same effect that you get when you pull the paper from one side of the foam board.
TheOne420 is offline Find More Posts by TheOne420
Old Apr 25, 2012, 02:08 PM
bz1mcr is offline
AKA Don
Joined Dec 2002
Del Nebeker
To order go to www.modelplanefoam.com Order now to be sure of getting the first of the new shipment.
For information on arrival of the next batch and availability stay tuned to this thread.
Don
Old Apr 25, 2012, 02:12 PM
Chicagoland
Joined Oct 2008
Actually, Chad, I've tried pulling the paper from foam board and the skin from FFF and a number of other things and I can't get the effect reproduced. The "vapor barrier" film has little to do with the shape of the foam itself, apparently. But there's gotta be a way...Perhaps your idea with letting the wet paper shrink might do it. Worth a try.
Old Apr 25, 2012, 02:20 PM
miniprinter96 is offline
Find More Posts by miniprinter96
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
What about covering with paper, propping the edges up on several 2X4s, and weighting the middle? You'd have to be careful to not dent the foam though.
miniprinter96 is offline Find More Posts by miniprinter96
Old Apr 25, 2012, 02:27 PM
Chicagoland
Joined Oct 2008
Hmm. I'd have to try that with some pre-cut panels and see if I can get the curvature I want. If so that might become a construction method. Gonna take time to get the proper weight and heat combo to form the material.
Oh, yeah, this would have to be done under heat, methinks, otherwise the foam would eventually relax back into its original flat shape. Or am I missing something?
Old Apr 25, 2012, 02:42 PM
Psalms 23:4
Goshen, IN, USA
Joined Nov 2010
Heat would definitely be useful to maintain the shape. Let us know how it goes!
Old Apr 25, 2012, 02:58 PM
Chad
TheOne420's Avatar
Joined Dec 2010
when i pull the paper from one side of $tree foam the whole sheet will bow on both x and y axis I have done this on several occasions with the same result. you only pull the paper from one side and the tension from the paper on the other side will cause the bubble. Maybe its just the dry heat we have here in southern california that keeps the paper nice and dry on the other side
and yeah i believe the wet paper shrinking should work. because the guys that use the newspaper to cover wings and such are very carefull not to stretch the wet newspaper too much because after it dries it does just what you are trying to do.
Old Apr 25, 2012, 03:35 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Originally Posted by TheAeronut View Post
Are you going to try FedEx or USPS shipping alternative to Universal Parcel Smashers? Have you researched the cost of those alternatives and if so, how much more?
Order #32, UPS demolition test case #1...
J.P.
Universal Parcel Smashers LMAO
Funny but unfortunately true
they try to put the blame off on the conveyor systems at the sorting facilitys but I have been to a UPS sorting facility and have witnessed first hand how the workers abuse the packages getting them from the truck to the routing conveyors.
that is why I ship fedX if a package is too big fto send VIA USPS.
RogueTitan is offline Find More Posts by RogueTitan
Old Apr 25, 2012, 07:57 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
RT,
That compound curve you are looking for is very cool indeed. Sort of bird like. The issue is that your spherical shape is pretty shallow. My solution would be to have a dome shaped sandwich that could be placed in the oven. It could be metal, wood, fiberglass, etc, but problem would be to find a domed pattern to start with. It could be cast from a ball shaped object, but you would need a huge ball 10-15 feet in diameter? Maybe somewhere a platter or such could be found. Wish Instill worked in the machine shop, a talanted sheet metal worker could pound and form a master probably from aluminum.
Darn now you have me thinking..........
Fred
Freddie B is offline Find More Posts by Freddie B
Old Apr 25, 2012, 08:09 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
FYI,
We now have an account with Fedex. So we will see.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Apr 25, 2012, 09:17 PM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
Originally Posted by Freddie B View Post
RT,
Fred
Fred I am totally lost aparently I have slept since the last time we talked about compound curves
Mini-Review Bluecor Fan Fold Foam Research and Testing MyGeekShow Foamies (Scratchbuilt) 15 Mar 26, 2012 05:08 PM
Question Depron / Fan fold foam and laser cutting laserman Foamies (Scratchbuilt) 4 Feb 09, 2012 11:16 AM
Discussion Pactiv fan fold foam jimrudholm Foamies (Kits) 1 Jan 31, 2012 03:08 PM
Free Dow Fan Fold Foam near Enid, Oklahoma jacob Non R/C Items (FS/W) 4 May 25, 2011 09:26 AM
