View Poll Results: How much foam do you consume?
1 bundle or less per year 83 33.88%
1-2 bundles per year 98 40.00%
2-6 bundles per year 42 17.14%
1-2 bundles per month 7 2.86%
2-4 bundles per month 4 1.63%
4 or more bundles per month 11 4.49%
Voters: 245. You may not vote on this poll
Old Mar 29, 2012, 10:58 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I never really had to do SEO (Search Engine Optimization) for site I run as they are informational for a specific target audience. I looked into it briefly a few years back, and decided I didn't need it.
I did a quick Google search on SEO. This link looks like a good place to start:
http://www.businessinsider.com/10-ba...ow-2010-1?op=1
As anti-twitter, and facebook as I am, you may want to look at starting them up for the business... Apparently they are valuable tools particularly for cottage industry.
rcav8r2 is offline Find More Posts by rcav8r2
Old Mar 29, 2012, 11:21 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Airplane foam
Foamie
parkflyer
Scratchbuilt
Foam jet
Just some meta tag suggestions^^^
for your site to be near the top peop;e can +1 you just like RCG
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 29, 2012, 11:37 AM
birdofplay is offline
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
THese guys are telling it right.
they code like this, but you are using a tool so look it up in the help.
<META NAME="MODEL PLANE FOAM">
<meta name="KEYWORDS" content=Model Plane Foam;foamy;foam sheet>
Bob
Northwest Cutout Service
birdofplay is offline Find More Posts by birdofplay
Old Mar 29, 2012, 11:38 AM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
How about
Depron Substitute
Depron Alternative
Depron Replacement
White Foam
Scratch Builders Foam
Foam for Airplanes
Airplane foam
Modelers Foam
Modelers Building Material
Hobby Foam
White XPS
Foamy Building Material
RC Model Foam
Also remember, if you want them to be effective Meta tags you must use the word/words in the text some where on (preferable the main page) your site. One trick used is to make a list of the tags and place them in the bottom of the main page and make that text the same color as the background so it is invisible.
But it is far more effective if actually used in descriptions for example. " The only American made Depron Substitute" or "Our Depron Alternitive is... ".
I think you get the idea.
The tags must also be relevant to your site content. There is a whole raft of rules to use to get good placement in the search. I took a course in Internet marketing. I am also the webmaster for several sites.
Hope this helps.
larryross is offline Find More Posts by larryross
Old Mar 29, 2012, 12:01 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Done. Though not sure how much just me doing it will help
grimbeaver is offline Find More Posts by grimbeaver
Old Mar 29, 2012, 12:19 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
So, I rummaged through Google and found how to and got site verified, but not yet crawled or able to do the diagnostics. I did note that too many meta tags make the site show up as spam, so we'll have to sort through all the suggestions and pick the best ones, I guess. Also, found out that I can actuallly see the meta names window in properties edit area in Concrete5 editing, if I switch IE to compatibility mode, but if I try to edit, still get a wierd page of html code that's larger than the screen and won't let me scroll to bottom to see if there's a "save" button there (did I ever tell you how counter intuitive concrete5 is? let me take an hour or so and do that......) I did the help on that, and found only more people asking the same question.... So still no meta names or tags yet. When I get the boxes redone, I'll start porting the site to wordpress or something else.
I guess it's not critical if we're already showing up in Google searches, tho.
springer is offline Find More Posts by springer
Old Mar 29, 2012, 12:20 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
Originally Posted by bz1mcr View Post
So, some possible "meta terms" might be:
modelplanefoam
modelplane foam
MPF
mpf
plane foam
model foam
model plain foam
Modle plane foam
Foam sheet
Sheet foam
Do I have the idea? Do others have more suggested "Meta terms" for Model Plane Foam
model airplanes
foamies
foam
scratch built foamies
RC foam
any key word that has to do with building or R/C in general will help generate traffic to your site...
or should I say help generate a result at a search engine. the traffic on your site depends on whether the searcher clicks on the link to your site provided by the search engine.
the key word MPF or model plane foam used in threads or posts in forums will generate results to that forum.
hope this helps
RogueTitan is offline Find More Posts by RogueTitan
Old Mar 29, 2012, 12:26 PM
Joined Dec 2010
i couldn't find ya on google either
Old Mar 29, 2012, 12:40 PM
springer is offline
treefinder
springer's Avatar
SE MI
Interesting, when I googled Model Plane Foam, the second hit was our home page, and the 8th hit was the RCG threads. Google may be using my frequent usage to tailor the search, though.
Old Mar 29, 2012, 12:54 PM
mav913 is offline
Find More Posts by mav913
GLMS
mav913's Avatar
Michigan
Joined Jan 2007
Mike, Ken and Don,
I got my two boxes of the seconds material yesterday and all I could think is that WOW! If this is the seconds material I can't wait to get a box of the primo stuff. VERY SATISFIED.
SUPER huge thanks to you three gentlemen and hope that the success continues.
John
mav913 is offline Find More Posts by mav913
Old Mar 29, 2012, 01:16 PM
Joined Dec 2010
https://www.google.co.uk/#hl=en&suge...w=1163&bih=817
^heres my results
Old Mar 29, 2012, 02:27 PM
OnGuard is offline
Find More Posts by OnGuard
Indiana
Joined Nov 2004
Model Plane Foam on google comes out as the first result for me.
OnGuard is offline Find More Posts by OnGuard
Old Mar 29, 2012, 04:02 PM
TheOne420 is offline
Find More Posts by TheOne420
Chad
TheOne420's Avatar
United States, CA, Cathedral City
Joined Dec 2010
they come up second to the bottom when i click on your results.
when i do the search on my computer they come up #1. because i have visited the site several times in the last month.
i get the same results as OnGuard
TheOne420 is offline Find More Posts by TheOne420
Old Mar 29, 2012, 10:19 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Wondering if you all cleared your search history what your search results would be. Maybe borrow a family members time to give a go on a fresh machine. My history pops the web site up first everytime, in fact the complete URL with only a few letters typed in.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Mar 29, 2012, 11:23 PM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Not wanting to hijack the thread any more than it has, but if your site actually uses words that apply to the search criteria as actual content (meaning, you mention this stuff in the description of your product that the visitor reads) then your search engine ranking is bound to go up. Google keeps their search engine ranking rules a closely guarded secret, but the one thing that is consistent is pages that have real content containing these terms get higher ranking.
So, when you start posting pics and brief descriptions of the models being built by your customers using your material the corresponding Google page rank will rise. [ahem]
A Useless Geek is offline Find More Posts by A Useless Geek
Mini-Review Bluecor Fan Fold Foam Research and Testing MyGeekShow Foamies (Scratchbuilt) 15 Mar 26, 2012 06:08 PM
Question Depron / Fan fold foam and laser cutting laserman Foamies (Scratchbuilt) 4 Feb 09, 2012 12:16 PM
Discussion Pactiv fan fold foam jimrudholm Foamies (Kits) 1 Jan 31, 2012 04:08 PM
Free Dow Fan Fold Foam near Enid, Oklahoma jacob Non R/C Items (FS/W) 4 May 25, 2011 10:26 AM
