View Poll Results: How much foam do you consume?
1 bundle or less per year 83 33.88%
1-2 bundles per year 98 40.00%
2-6 bundles per year 42 17.14%
1-2 bundles per month 7 2.86%
2-4 bundles per month 4 1.63%
4 or more bundles per month 11 4.49%
Voters: 245. You may not vote on this poll
Old Dec 01, 2011, 05:35 PM
Model Aero is online now
Find More Posts by Model Aero
Northwest Ohio
Joined Jan 2002
We use a few thousand sheets of 6 mm Depron a year. For us to be interested the material would need to be as good or better than Depron and delivered in sheets in perfect condition, flat with no perforations or skin. I would forget about colors other than white. It will be a challenge to get any company in the US interested in producing it at all, let alone multiple colors.
There are a few companies who could produce the material in the US if the demand were there, but I really question if the demand is even close to being enough. Nevertheless, I'm happy to see someone investigating this and it would be great to have a competitive product to Depron. I'll be following the thread!
Scott
www.ModelAero.com
Model Aero is online now Find More Posts by Model Aero
Old Dec 01, 2011, 06:44 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Scott,
Thank you for your interest.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Dec 01, 2011, 06:59 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Scott
www.ModelAero.com
How many is "a few thousand"? The highest catagory in the pole is 4 bundles a month, which is 1200 sheets per year. Please add your usage in the poll at the top of the page.
bz1mcr is offline Find More Posts by bz1mcr
Old Dec 01, 2011, 07:11 PM
Northwest Ohio
Joined Jan 2002
Usage added. Is there any reason you would spec 5 mm and not 6 mm which is the standard for Depron? That would be a deal breaker for us.
Scott
www.ModelAero.com
Old Dec 01, 2011, 08:03 PM
GorillaBob is offline
Find More Posts by GorillaBob
Re-Kitting Expert :o
Bullhead City, Arizona
Joined Jan 2005
I think 6mm is pretty universal. Isn't blucore about 6?
GorillaBob is offline Find More Posts by GorillaBob
Old Dec 01, 2011, 08:06 PM
bz1mcr is offline
AKA Don
Joined Dec 2002
Scott,
Thanks for adding your usage and your comment. I agree 6 mm would be the best target thickness for the initial product with perhaps 3 mm following later.
I am guessing that Kens initial request for 5 mm was because it is closer to the Dollar Store "Ready Board" and the Dow protection board which are current products from this manufacturer. But again, I agree a 6mm sheet would be a better choice, unless it results in some extra tooling or other expense.
By the way are 2'x4' sheets an exceptable size for you?
And how about 23.5"X4'? That is favored by some Phlatprinter users.
Old Dec 01, 2011, 09:04 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
I'd buy 2 bundles per year for sure. Numbers added. Might even be tempted to try to kit something commercially if the quality and cost made this favorable -- which at $50 or so a bundle for flat white uniform stock would make it do-able.
vtdiy is offline Find More Posts by vtdiy
Old Dec 01, 2011, 09:43 PM
bz1mcr is offline
AKA Don
Joined Dec 2002
Ken has purchased and measured a lot more Protection board and other FFF than I. Maybe he can share his data on thickness.
Old Dec 01, 2011, 10:27 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
FWIW, as a PhlatPrinter owner, the 2'x4' works just fine.
When designing in SU for FFF, I use 6mm as the standard for the tabs, slots, and about 85% of the time that works just fine. It does vary a bit even on the same sheet (long piece with multiple tabs/slots, most are perfect fit, some aren't)
Also 5MM would be fine with me, but I would prefer 6mm and then 3mm as a close second.
rcav8r2 is offline Find More Posts by rcav8r2
Old Dec 02, 2011, 06:38 AM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Ditto!
Ken
Old Dec 02, 2011, 10:30 AM
Sixter is offline
Find More Posts by Sixter
Flying Models for 52 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
I agree that 6mm will be the preferred thickness. As for the size of the Foam sheets, I prefer 2' x 4' sheets of Foam. That is the same size as the original FFF Sheets. Why 2' x 4', 99% of the Models we Scratch Builders build have wingspan's less than 4'! So, with a 4' long sheet you can build a wing with out having to glue two sheets together. Comments welcome.
Bobby
Sixter is offline Find More Posts by Sixter
Old Dec 02, 2011, 01:21 PM
dz1sfb is offline
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Between Blu-Core, PBIII, HPU, OC Foamular, and $Tree Readiboard, thickness ranges from .250" down to .188", and they all deviate to around .2" or 5mm. I know that is not exact, but there is that much variation across these products.
BC = .25"
PBIII = .188" - .2"
HPU = .2" - .225"
OC Foamular = .2" - .23"
Readiboard = .188" - .2"
Ken
Old Dec 02, 2011, 04:41 PM
Northwest Ohio
Joined Jan 2002
Scott,
I have to cut the sheets down to 23" x 34" fit the laser so anything larger than that could work. I have laid out the kit parts to use the cutoffs for some of the smaller parts. So there is very little waste from the full size Depron sheets.
Personally I'm not sure if I'd be interested in 5 mm foam. It just wouldn't work well for our kits.
Scott
www.ModelAero.com
Old Dec 02, 2011, 09:08 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
I think surface finish is important -- beyond just no holes or waves.
A good acrylic paintable surface would be great. I've had acrylics peel off of Cellfoam88 rather easily -- it has a hard shiny finish. If you sand it then it suddenly turns into a hard sponge texture.
I'd really like to see a smooth somewhat matte finish that would mechanically key into acrylic paints well. The paint could be gloss even if the foam finish was matte -- the foam finish is just there to let the paint grab, it doesn't determine the paint finish.
That would also be better for gluing as well.
BTW, I have written before that Yankee Dollar stores here in the NE US carry a 3mm painted foam that is perfectly flat and smooth in a variety of colors, sold as poster board. It has no paper covering. And it costs a dollar a sheet. I wonder if Adams makes that as well?
It seems a little fragile, to me, but I haven't had anything to compare it with of that size.
see:
http://www.rcgroups.com/forums/showthread.php?t=1493432
Old Dec 02, 2011, 09:59 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
My CNC table is 4' x8' BUT I currently only have a 2' x 4' Vac hold down.
So Any of those sizes are OK with me. I currently process mostly the 13x39 depron.
My vote is 6mm or .25 " which ever.
Almost Everything I do is set up for 6mm slots and tabs.
Don, Ken, Guys, lets NOT loose sight of Other foam characteristics.
There are denser and more brittle and more floppy/rubbery formulations out there.
Even Depron is not ultra consistant and Grey/Black is not the same a White.
I've run into several of these grades over the years.
I picked up some bargain foam, once upon a time -
it's so brittle that it's useless for models.
I use it for packing material.
I also took a run at Other manufacturers of foam and wound up with a floppy
but better than EPP foam that was useable but not as desirable as depron.
I once found an Asian place that wouldnt even let me PURCHASE samples.
But they want me to buy a CONTAINER of what ever they are selling.
NOT !!!
Bob
Northwest Cutout Service
birdofplay is online now Find More Posts by birdofplay
Mini-Review Bluecor Fan Fold Foam Research and Testing MyGeekShow Foamies (Scratchbuilt) 15 Mar 26, 2012 05:08 PM
Question Depron / Fan fold foam and laser cutting laserman Foamies (Scratchbuilt) 4 Feb 09, 2012 11:16 AM
Discussion Pactiv fan fold foam jimrudholm Foamies (Kits) 1 Jan 31, 2012 03:08 PM
Free Dow Fan Fold Foam near Enid, Oklahoma jacob Non R/C Items (FS/W) 4 May 25, 2011 09:26 AM
