View Poll Results: How much foam do you consume?
1 bundle or less per year 83 33.88%
1-2 bundles per year 98 40.00%
2-6 bundles per year 42 17.14%
1-2 bundles per month 7 2.86%
2-4 bundles per month 4 1.63%
4 or more bundles per month 11 4.49%
Voters: 245. You may not vote on this poll
Old Feb 03, 2013, 05:42 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Originally Posted by bz1mcr View Post
If you have not tried "Foam Cure" you should. I like it a lot better than FoamTac. For me it provides stronger bonds, lasts longer after opening and it available in a smaller lower cost package. Here is link to one source but others may have a better price. Let me know if you find one.
Thanks Don i will give some a try. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Feb 03, 2013, 07:00 PM
Makdaddy is offline
Find More Posts by Makdaddy
Doink-not again :)...aka Greg
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
Thanks Don, will look into that for sure.
Makdaddy is offline Find More Posts by Makdaddy
Old Feb 04, 2013, 01:43 PM
Makdaddy is offline
Makdaddy's Avatar
Joined Jul 2012
Don,
Looks like our MI LHS (the Prop Shop) carries "Foam Cure". I know you are down in Florida but you will return some time. Same price as your link on line.
Old Feb 04, 2013, 04:38 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Thanks for that. Support of the local shops is a good thing.
bz1mcr is offline Find More Posts by bz1mcr
Old Feb 04, 2013, 09:47 PM
Makdaddy is offline
Makdaddy's Avatar
Joined Jul 2012
Yes it is! Will pick some up the first time I get
Old Feb 09, 2013, 02:46 AM
brett.c is offline
Find More Posts by brett.c
Foam is where the heart is
brett.c's Avatar
Australia, NSW, Sydney
Joined Aug 2010
My ov-10 is coming along nicely thanks to MPF.
I am really enjoying working with this stuff. It is far nicer to work with compared to depron.
The only complaint I have is that some sheets are a bit wavey, some have as much as 1mm difference in thickness.
I still haven't decided what to do with the elevator control. So far I have a servo in one of the booms and intend to fit a bell crank at the tail.
Open to other suggestions.
brett.c is offline Find More Posts by brett.c
Old Feb 09, 2013, 08:15 AM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Fit the elevator servo in the other boom and use a flexible sleeved control rod. This way you'll balance the servos weight laterally, and not start off with a plane that wants to roll because one side is too heavy.
Edit: I think I misunderstood. I thought your servo in the boom with a bell crank at the tail was for rudder control. Anyhow now you can have both!
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 09, 2013, 09:33 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Wow, Brett, you ain't just foolin' around! That bird is looking great! Shows off the formability of MPF, too.
On the thickness & waves, yes, unfortunately MPF isn't as consistent as Depron (not as expensive as that either, of course; and like or not, we're process constrained on those characteristics - getting the best the process can deliver at this time) For most folks the variations are inconsequential or minor irritations. We don't recommend using MPF for applications like the 3D profiles where the straightness & stiffness of Depron is critical. I've never used Depron, having come at the hobby from fanfold and dollar store foams, and MPF is orders of magnitude better that those. But I can understand that folk coming from Depron may see it differently. My experience has been that they seldom can be detected in the finished plane.
springer is offline Find More Posts by springer
Old Feb 09, 2013, 02:30 PM
brett.c is offline
brett.c's Avatar
Joined Aug 2010
Thanks, I may go for the flexible idea because it would be a lot neater.
I was going to just fit a counterweight in the wing to offset the servo. I always balance my planes laterally.
However I may fit a rudder servo on the other side. I wasn't going to use rudders but am rethinking that.
Re: the waviness, you just have to watch what side you are using because one side is nice and flat.
Old Feb 10, 2013, 05:42 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Have you guys considered adding magnets to you site ? I would think they could be slid into the box and its something that i use on almost all my builds .
Wilfor is offline Find More Posts by Wilfor
Old Feb 10, 2013, 08:22 PM
bz1mcr is offline
AKA Don
Joined Dec 2002
Magnets....Interesting suggestion.
Any others think they would like to be able to order magnets with foam?
And, what specifications of magnets would be desired?
Old Feb 11, 2013, 12:04 AM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
I would highly consider it. 1/4" round neodymium are the ones I look for most often. Good for cowls, hatches, canopies...
Old Feb 12, 2013, 12:10 AM
sjd is offline
sjd
Find More Posts by sjd
sjd
My scratchbuild flew!!!
sjd's Avatar
Australia, NSW, Barden Ridge
Joined Mar 2012
I am really enjoying working with this stuff. It is far nicer to work with compared to depron. .
Brett, which glue are you using on the mpf, and is it sandable?
sjd is offline Find More Posts by sjd
Old Feb 12, 2013, 12:20 AM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Speaking of magnets, here's a tip I find invaluable. I always have the hardest time getting screws into servo horns and micro connectors etc etc etc without dropping and losing them. So, here's what I do: I have a stack of 1/8" neodymium magnets I got from a jeweler friend. He was using them as clasps for bracelets and necklaces. Stick one on the side of your screwdriver to instantly magnetize it and never drop a screw again. Thought I'd share since I did this trick just tonight.
Old Feb 12, 2013, 12:27 AM
Wilfor is offline
RC Adddict
Wilfor's Avatar
Joined Jan 2010
I have 1 of these
That way you can magnetize and demagnetize as needed
Mini-Review Bluecor Fan Fold Foam Research and Testing MyGeekShow Foamies (Scratchbuilt) 15 Mar 26, 2012 06:08 PM
Question Depron / Fan fold foam and laser cutting laserman Foamies (Scratchbuilt) 4 Feb 09, 2012 12:16 PM
Discussion Pactiv fan fold foam jimrudholm Foamies (Kits) 1 Jan 31, 2012 04:08 PM
Free Dow Fan Fold Foam near Enid, Oklahoma jacob Non R/C Items (FS/W) 4 May 25, 2011 10:26 AM
