Old Jan 05, 2012, 06:04 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Totally on the same page Henrik
The 3D motor version is a 2839 or 28 dia X 39 short can. Its a 2200kv motor being pushed on 6S or 21V. The fans, other than one being counter rotating I don't see a difference from the standard FW 70mm fan. Such a short motor turning at high rpms to get the 3Kg that they state below 110amps is doing better than Wemo with any of the top motors out there that draw even higher amps. So my guess is the 3kg is peak burst figures but that is just speculation. If someone posts a vid of a PnP SU-35 in a hover, them may be I'd change my mind.
I'll eventually put these fans in one of my SU-34s to find out but despite my prior comments, the factory fans from FW have alway surprised me as to how much these plastic cheap fans actually put out and some of them last.
Maxthrottle is offline Find More Posts by Maxthrottle
Last edited by Maxthrottle; Jan 05, 2012 at 07:46 PM. Reason: wrong kv post for 3D motor 3000 to 2200
Old Jan 05, 2012, 06:10 PM
High Orbit.....
Joined Jun 2009
Originally Posted by SU-4ever View Post
I think it could be designed to work exactly that way. I mean, if you reverse the direction of the vents, it will create a lot of undesireable drag. By aerodynamic principles, the sheer air circulating above the vents will be sucking hot air out of the inside. .......
I just got mine and both the Manual and mine have the vent like V8s with the fins forward. So NS if you turned yours around because you were repositioning the ESC's please advise. So off to the other thread.....
Old Jan 05, 2012, 06:13 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Max if you look @ the box its says the standard version on 4s is 3000kv motors on 45a esc. The 3D version is 2200kv motors on 6s 55a esc's.
v8truckin is offline Find More Posts by v8truckin
Old Jan 05, 2012, 07:45 PM
High Orbit.....
Joined Jun 2009
Thanks V8 you are absolutely right. I'll go back and change my post to 2200kv but the concern remains. At 2200kv 21V thats 46200 calculated rpms with a cheap plastic fan to produce 1.5Kg ea. All doable but at 50amps????? My F-35 70mm was seeing 69amp.
If you go to the CS 10 blade thread, they gave up comparing the CS to Wemo loads but are consistent with the low expectation of short can motors being able to handle some expectations.
If those fans are having a hard time achieving low amps and 3kg, with can generally 50mm and longer, it gets only hotter if you go to a shorter can. Thus my wonder. I just pulled my FW 70mm fan and matched it to the fans in the box. No point taking a picture since you wouldn't see a difference. They are identical in every respect other than one is counter rotating.
So an easy compare is what were all the numbers anyone has been getting from any of the FW 70mm model line up. They either just found or made a super motor or something is a little off They would get the thrust but not at such low amps.
Old Jan 05, 2012, 07:56 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Thats why i still have a hard time believing 50 or 55a will do on this plane for very long.
On another note I haven't really followed the 70mm cs 10 blade thread mainly the cs 12 blade thread. Ne how being that the specs on different website show 2100-2200kv motors for the CS fan, would it be safe to say the stock FW motors are sufficient for these fans?
Old Jan 05, 2012, 08:02 PM
merlinfan is offline
Find More Posts by merlinfan
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
How's your eye Neversommer?
merlinfan is offline Find More Posts by merlinfan
Old Jan 05, 2012, 08:13 PM
High Orbit.....
Joined Jun 2009
I think it will be consistent with the previous performance from the same FW 70mm EDF. 1.6kg ea at about 60-65amps. I'm not saying this in absolute... if they have a motor that can do this, I want it!!!! Thats very low amps for a 6S setup that is pushing 1.5kg on a cheap fan. FW hasn't updated their site with the SU-35 or motor so I'll have to just wait and see with the PnPs or when the motors are sold as parts. But then again I'll also have to wait to see if they last at all also because pushing a short can usually just burns them up which was what Henrik alluding to.
Old Jan 05, 2012, 08:42 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
I got some of the 2200kv PNP motors coming my way in a few days, so that's why I was asking.
Old Jan 05, 2012, 08:45 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
& my CS fans have been stuck on the same info on USPS for the past 8 days, should've done ems on em 2.
Old Jan 05, 2012, 09:20 PM
High Orbit.....
Joined Jun 2009
V8... not sure if you read the other thread but I think I know why you setup your tail stabs as you did. And looking to the pics you would have had way too much movement from these.
IN short the manual sucks and the pics encourage to do the opposite of how this should be setup.
Old Jan 05, 2012, 11:26 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Guy's any flight reports yet?? How does it fly compare to the freewing f-18???
capt soap is offline Find More Posts by capt soap
Old Jan 06, 2012, 05:51 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Not good yet
Still endure pain.
NS.
neversommer is offline Find More Posts by neversommer
Old Jan 06, 2012, 05:52 AM
Luzern/Switzerland
Joined Aug 2008
The SU-35 on Stock Setup is faster then the F-18 Super Hornet on Stock Setup.
Flight Characteristics are very good once all setups are being done.
NS.
Old Jan 06, 2012, 12:19 PM
SU-4ever is offline
Find More Posts by SU-4ever
Flying Hazard
SU-4ever's Avatar
Spain
Joined May 2006
I'm starting to quite frighten about ESC numbers.
I'm starting FPVing and I have to put an order soon at HK so I may start picking some good 2 ESCs in prevision of complete disaster.
SU-4ever is offline Find More Posts by SU-4ever
Old Jan 06, 2012, 10:06 PM
Throttle Bender
merlinfan's Avatar
Joined Jun 2008
The Camo one spotted!
SU35 70mm(twin) PNP完成機 (3 min 28 sec)
Both fans sound out of balance.
New Product Techone 39'' Airfoiled Wing EPP SU-31 From EPPHOBBY.com Get Real 3D Foamies 365 Sep 24, 2014 12:34 AM
Discussion NEW: Giant A-10 ready2fly.com / Lanxiang ready2fly.eu Foamy EDFs 26 Nov 11, 2010 05:21 PM
For Sale Freewing 3000kV EDF motor from 360 TV jet latinlax01 Aircraft - Electric - Jets (FS/W) 0 Jun 04, 2010 08:57 AM
Sold Hobby-Lobby / FREEWING F-35 Lightning II TV Parts TKK Aircraft - Electric - Jets (FS/W) 0 Apr 10, 2010 12:26 PM
