Old Feb 18, 2012, 09:26 AM
Harm is offline
Find More Posts by Harm
Holland
Joined Jan 2004
Why not simply use one or two massive joiners for ballasting up instead of the standard hollow joiner tubes?
As everything goes as planned I will have my K8b in the house by next weekend.
Harm is offline Find More Posts by Harm
Old Feb 19, 2012, 02:06 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
haha because you can loose weight before landing just like a real one!
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Feb 19, 2012, 10:49 PM
soaring_sweden is offline
Find More Posts by soaring_sweden
soaring_sweden's Avatar
Joined Feb 2012
Hey.
Yes, I had thought something like that. But have searched the web for type solid fiberglass rod 32 mm but have not found yet .32 mm is a bit odd size. Have found 30 mm carbon fiber tube!
As I heard and understood as the Phoenix at some hard "test flight" bent / aluminum tubes.? Therefore, Phoenix added 2 x 1 meter massive 12 mm carbon fiber rods in the wing! Perhaps it is not aluminum tubes of the best quality?? I've also thought about pressing in a turned birch rod of the best Swedish quality in the forward tube. For maximum strength. Have done so before in various models.
Okay, good luck with your model. You are welcome to Sweden and our IGG meeting this year. IGG-Sweden celebrates 10 years on 6-10 June at Ålleberg / Falköping.
http://www.igg-sverige.se/
soaring_sweden is offline Find More Posts by soaring_sweden
Old Feb 19, 2012, 11:03 PM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
You could also "pull" some wetted out carbon tow thru the tube and make it soild.
SZD16 is offline Find More Posts by SZD16
Old Feb 19, 2012, 11:17 PM
Joined Feb 2012
Yes, it is also a good idea. If there is a 28 mm carbon fiber tube to buy. Will check it out
Old Feb 24, 2012, 09:54 PM
bananaman is offline
Find More Posts by bananaman
bananaman's Avatar
Brisbane Australia
Joined Oct 2000
I have one of the later ones. It has a slot for a brake on the upper surface and no "barn door type panel. However, as weight isn't an issue I'm making something closer to scale.
I'll post some pics of the final result when its done.
bananaman is offline Find More Posts by bananaman
Old Feb 25, 2012, 05:19 AM
Larrikin is offline
Find More Posts by Larrikin
Everything's A Compromise
Larrikin's Avatar
Joined Jan 2005
Well Bananaman, those bad boys should slow it down
Do you have an event in mind to have it ready for?
It'd be a sight to behold.
D.
Larrikin is offline Find More Posts by Larrikin
Old Feb 25, 2012, 11:41 AM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
brake slot length?
That sounds like good news. What is the length and width of the slot? Is there a servo access compartment also provided? Thanks.
flyingfever is offline Find More Posts by flyingfever
Old Feb 25, 2012, 05:46 PM
bananaman's Avatar
Brisbane Australia
Joined Oct 2000
Hi LK aka D, if I didn't have to work, it would be ready for Toowoomba, as I do who knows? When I can is my best estimate. My focus is on getting the tug repaired and finishing the Fox. I should be home on Friday if you want to drop by for a look.
Mr. Fever, the slot is 450mm x 17mm (which is a little less than 17 and 3/4 x a little more than 5/8 for the non metric minds). There is no servo access panel. The manual says the slot is provided for "Electric Air Brakes (Not included with the kit)" 440mm is the largest size electric brakes I know of.
Old Feb 25, 2012, 10:02 PM
Joined Jul 2009
air brakes
[QUOTE
Mr. Fever, the slot is 450mm x 17mm (which is a little less than 17 and 3/4 x a little more than 5/8 for the non metric minds). There is no servo access panel. The manual says the slot is provided for "Electric Air Brakes (Not included with the kit)" 440mm is the largest size electric brakes I know of.[/QUOTE]
Thanks. That helps with planning.
Old Feb 28, 2012, 10:11 AM
stephen Damon is offline
Find More Posts by stephen Damon
USA, TX, Waco
Joined Nov 2010
Ka8
If anyone decides to drop off the list please let me know. I would like to get one.
stephen Damon is offline Find More Posts by stephen Damon
Old Feb 28, 2012, 10:25 AM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Stephen, I replied to your PM, should not be a problem.
I called Hobbico a few days ago to check on the status of our order. Target date is still on for June, they'll let me know if the shipment comes in sooner.
Hobbico has asked that I supply them with a list of the buyers including their names, physical addresses, email addresses and their Tower account numbers, if you have one (not necessary to purchase).
So, for all of you who have asked to be in on this order, please send me a PM with all of this info, I'll set up a spreadsheet with all this data and will forward it to Hobbico.
Once all of this info is organized, I'll check to see if Hobbico can arrange some consolidated shipping to save costs.
Steve
SteveR is offline Find More Posts by SteveR
Old Feb 28, 2012, 10:32 AM
cpdude is offline
Find More Posts by cpdude
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Hey Steve,
I don't have a Tower account. Are there any benifits to having an account specific to this order?
Brian
cpdude is offline Find More Posts by cpdude
Old Feb 28, 2012, 10:47 AM
SteveR is offline
New York
Joined Feb 2002
Brian, I don't think so but I'll check.
Steve
Old Mar 03, 2012, 07:48 PM
RoyAceWings is offline
Find More Posts by RoyAceWings
Joined Jan 2012
K-6
hi guys, been really busy and haven't had a chance to check in. I am working on some carriers for a couple of cubs, Giant scale. 18 ft wingspan and a 14 foot wing span.
We are working on a K-6 and asked about pricing on the carriers for the wings, stabs and tail rudder. So it it is in the range of $360 on this model.
I know S2000 asked about it in the forum so I thought I would share that information with you.
I here the gliders are still pushed out till June for delivery I bet your all on pins and needles with excitement on getting these babies.
I will post pictures on our web site when we are done, since these planes are going to be shown for the first time, I will wait until they have done that and then post pictures. Really cool stuff.
Roy
RoyAceWings is offline Find More Posts by RoyAceWings
Discussion New hobby shop special - 2 meter fun fly dion9146 Electric Sailplanes 4 Oct 18, 2011 10:28 PM
For Sale New 2dogrc Challenger Bipe Pre-Order Special! Plane plus 3s620 Special 2dogrc Aircraft - Electric - Airplanes (FS/W) 0 Dec 31, 2006 02:05 PM
Alert Special One-Time Offer for new Xtrema Charger/ Motor Test Station LBMiller5 Batteries and Chargers 25 Jan 30, 2006 10:34 AM
For Sale XUSHOBBY one day special sale(1/8/6) - TowerPro SG50 5g Servo: $7.95 ildo Aircraft - General - Radio Equipment (FS/W) 2 Jan 08, 2006 09:59 PM
