Old Nov 02, 2011, 12:38 AM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Fatshark Dominator and DX8 Headtracking.
A few days ago I received a cable from Gregory from Fat Shark and tonight I hooked my AR8000 back into my Twinstar II.
It really was quite simple to get communication between the devices.
First off, setup the Trainer area of your DX8.
Turn on holding the roller and go to the trainer menu, click.
Then you may see that it is "inhibited" so select that and change to "Programmable Master".
I set everything to master except "ax2" and "ax3" which I set to slave.
That means when I hold down the trainor button on the upper left, I can turn my head and adjust the camera hooked to the pan and tilt of the receiver.
One cable hooks in the headtracker connection under the right side of the Dominators. The other end into the slave plug under the DX8.
Have not calibrated or tried to set center yet, but can confirm that when I tilt up and down it moves up and down, and when I turn, it turns.
Setting the head tracking channels in the Dominator is easy as well.
Hold down the HT button on top and then plug in power. It will start to beep so let go of the button.
Then count.
To set to channels 7 and 8 it was 6 beeps, so 1...then 2....and so on. Right in the pause after 6 beeps you press the HT button again and that is it.
Then plug your pan and tilt servos into aux2 and aux3 on the receiver and it works.
Got to say that I was pretty impressed with Fat Shark service in this.
Once he was aware there was a demand, he got a cable to me to try out. Obviously he dedicates his company towards the needs of his customers and does listen to what they are asking for.
Shadrack is offline Find More Posts by Shadrack
Old Nov 02, 2011, 10:30 AM
hga77 is offline
Find More Posts by hga77
hga77's Avatar
Joined Jan 2010
Great stuff! Where can we buy this cable from?
hga77 is offline Find More Posts by hga77
Old Nov 02, 2011, 10:54 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
I will send a message to Gregory and find out for you. He kind of whipped this one up for me to make sure that is worked so will post his response on here as soon as I get it. I know he is 13 hours ahead of central time so will probably speak to him tonight.
Old Nov 02, 2011, 08:51 PM
seojeff is offline
Find More Posts by seojeff
seojeff's Avatar
United States, GA, Atlanta
Joined Aug 2011
Subbed
seojeff is offline Find More Posts by seojeff
Old Nov 02, 2011, 11:20 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
ReadyMadeRC should have them, though they may not be listed yet. Gregory is going to remind them so they are available there.
Old Nov 03, 2011, 11:45 AM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Subscribed
idletime is offline Find More Posts by idletime
Old Nov 03, 2011, 11:49 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Originally Posted by seojeff View Post
Subbed
Originally Posted by idletime View Post
Subscribed
scrape is offline Find More Posts by scrape
Old Nov 03, 2011, 11:54 AM
idletime is offline
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Originally Posted by scrape View Post
err..I didn't get it
Old Nov 03, 2011, 12:57 PM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Didn't get what?
Old Nov 03, 2011, 02:01 PM
scrape is offline
Joined Mar 2006
You can subscribe to a thread ("Thread Tools") without posting in the thread so that everyone that is subscribed isn't notified that you have subscribed.
More post are about subscribing than the OP's topic.
Old Nov 03, 2011, 08:08 PM
seojeff is offline
seojeff's Avatar
Joined Aug 2011
Thanks for the forum lesson, scrape. However my purpose for posting that I subbed was simply to inform Shadrack that I was also waiting for his follow up.
Old Nov 03, 2011, 09:19 PM
scrape is offline
Joined Mar 2006
Oh sorry, hard to tell.
Why didn't you say so.
Thanks.
Unsubscribed.
Old Nov 04, 2011, 07:32 AM
superevan is online now
Find More Posts by superevan
superevan's Avatar
United States, TX, Austin
Joined Aug 2007
Videos?
superevan is online now Find More Posts by superevan
Old Nov 04, 2011, 08:02 AM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
So what if you wanted to use this with a LRS that is in the trainer port?
banzi28 is offline Find More Posts by banzi28
Old Nov 04, 2011, 10:12 AM
Shadrack is offline
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
superevan
Video of hooking it up? What type of video are you looking for?
banzi28. Great question, but from what I have seen, the head tracking gets moved to the long range box such as the ezUHF.
Help! Fatshark Dominator or Foxtech AIO nexstarselect FPV Talk 48 Jan 17, 2015 04:34 AM
New Product New Fat Shark Dominator - specs/photos fatshark FPV Talk 741 Aug 04, 2014 11:29 AM
Discussion Fatshark Dominator HeadTracker Hack/Mod bdellon FPV Talk 2 Jan 25, 2012 02:42 AM
Question Problem with Fatshark Dominator Head Tracker and Robbe/Futaba FX-30 MrBean FPV Talk 2 Dec 13, 2011 05:35 PM
Wanted Guardian Stabilization Expander and Fatshark dominator zkilzz FPV Equipment (FS/W) 2 Oct 17, 2011 11:09 PM
