This thread is privately moderated by jgalexander, who may elect to delete unwanted replies.
Old Nov 01, 2011, 07:40 PM
jgalexander is offline
Find More Posts by jgalexander
Trader Rating: 856
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Trader Rating: 856
Sold
Electrify C-7 Nano High Frequency ESC for Brushed Motors
This is new, untouched. I picked it up for a LED light project I'm working on, and then found a used one hiding in the corner of a large lot I bought.
6-8cell NiCD or NiMH, 2-3cell Lipo.
$19.99 new, $15 shipped w/ tracking. Paypal or MO preferred.
Josh
From Electrify:
This is the C-7 Nano High Frequency Electronic Speed Control w/BEC.
For very small indoor, Park and Backyard Flyers with 280-size or
smaller Brushed motors requiring 7A or less.
FEATURES: Extremely compact size to minimize weight and simplify installation Set battery type with included jumpers Uses "Safe-Start" system to prevent accidental motor starts by disabling the motor circuitry until the throttle stick is moved to full throttle, then to the OFF position Factory installed motor, radio and battery connectors Fully proportional forward only (no brake) Battery Eliminator Circuitry provides sufficient voltage for the receiver and two to three micro servos. The motor battery powers the receiver and servos, then when voltage is reduced to the appropriate voltage, the Low Voltage cut-off circuitry stops the motor while continuing to supply power to the receiver and servos High frequency to optimize battery run-time and cool operation Bright Blue LED and audible tones for easy set-up Very smooth throttle response 180 day limited warranty
INCLUDES: One C-7 Nano Electronic Speed Control with Deans polarized micro connector for battery, 2mm gold plated female bullet motor connectors and Universal receiver connector and separate pre- assembled leads with male and female 2-pin connectors One instruction sheet
REQUIRES: Attaching to motor and setting up speed control Battery pack Plug Universal plug into the throttle channel on the receiver
SPECS: Length: .66" (17mm) Height: .28" (7mm) Width: .43" (11mm) Weight: .20oz (5.5g) with wires Input: 6-8 NiCd/NiMH cells; 2-3 LiPo cells Max Rated Current: 7A continuous BEC Voltage: 5V/1A Low Voltage Cutoff: .80V per cell for NiCd/NiMH 2.75V per cell for LiPo Connectors: Receiver lead- Universal Battery lead- Deans 2R micro connector Motor Connector- 2mm gold plated female bullet connectors Switching Frequency: 2.5kHz Motor Size: 280 or less Brushed only
COMMENTS: Will handle 3 micro servos with proper cooling Do NOT use with Brushless motors
jgalexander is offline Find More Posts by jgalexander
Old Nov 13, 2011, 01:44 PM
Trader Rating: 856
Joined Apr 2010
Trader Rating: 856
BTW, I have lots of items listed right now, if you see multiple items you like, we can combine shipping and save a few bucks.
Old Nov 13, 2011, 11:07 PM
Trader Rating: 856
Joined Apr 2010
Trader Rating: 856
Sold!
Sold REDUCED! From $20.00 to $15.00 shipped-Great Planes Electrify C-25 Brushed ESC Olias Aircraft - Electric - Power Systems (FS/W) 2 Sep 05, 2011 03:47 PM
For Sale Great Planes ElectriFly C-7 Nano Brushed ESC w/BEC and 2 Eflite S75 servos crxsir121 Aircraft - Electric - Power Systems (FS/W) 1 Jun 21, 2007 09:28 PM
For Sale Great Planes ElectriFly C-7 Nano Brushed ESC w/BEC and 2 Eflite S75 servos crxsir121 Aircraft - General - Radio Equipment (FS/W) 1 Jun 21, 2007 09:27 PM
For Sale NEW Great Planes C-20 Mini High Frequency Brushed Motor ESC - $17! Jason M Aircraft - Electric - Airplanes (FS/W) 2 Aug 02, 2005 10:26 PM
Sold NIB Great Planes C-50 High Power High Frequency Brushed Motor ESC - $27! Jason M Aircraft - Electric - Airplanes (FS/W) 4 Jul 31, 2005 10:10 PM
