Old Oct 31, 2011, 11:54 PM
Azn_Ace is offline
Find More Posts by Azn_Ace
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
EB Excalibur Sky Crawler 3Ch at Costco
Does anyone have experience with this one? It showed up at my local Costco in Orange County this past weekend.
$35 bucks.
Azn_Ace is offline Find More Posts by Azn_Ace
Old Nov 01, 2011, 02:53 AM
Zerodark is offline
Find More Posts by Zerodark
Fledgling Aviator
Joined Oct 2011
This one here?
http://www.amazon.com/Sky-Crawler-Ra.../dp/B0013L426S
These guys didn't like it:
By J. D. SALEM (Tampa, FL) - See all my reviews
(REAL NAME)
Durability:1.0 out of 5 stars Fun:1.0 out of 5 stars Educational:1.0 out of 5 stars
This review is from: Sky Crawler Radio - controlled Helicopter (Toy)
The Good: This toy was fun for a few minutes (but read the bad before you buy one)
The Bad: This product is junk, don't buy it unless you only want to play with it for 10 minutes. It flew for 10 minutes and broke the fuselage on its first flight crash and the battery harness on its second flight crash. Like other reviews, it is uncontrollable, it goes up in a spin and remains in a spin, so you can't control direction. You can control height, but even height is very difficult to control. All problems were mentioned, 4 direction control rather than 6, unresponsive or clumsy controls, constant uncontrollable unstoppable spinning, cheap plastic that breaks on first crash landing, 10 minute lifespan of toy, no replacement parts to be found, so it is junk.
I didn't get mine at amazon, but this copter is the same no matter where you buy it. It's not a 3 channel, only a 2 channel (main rotor and tail).
People who say it just spins never bothered to calibrate it, people who say that it crashes and breaks... well... they are right.
I used 2 charges to adjust the fan calibration so that it would not just swirl around in circles at full speed. As the power drops you need to add some stick control to compensate for the rotor torque. When you do try to steer, a little power goes a really long way.
I flew mine 2 flights before the fuselage was all cracked up from a hard landing in a dry patch of grass (the radio sometimes doesn't respond causing the motor to stay at its last setting, which means when you want a last thrust to soften the landing, you often don't get it)
The battery takes forever to charge and lasts 5 minutes or so.
All that being said, the chopper has really great thrust and can lift a the whole 2 ballpoint pens, 2 glue sticks and 2 metal computer case punch outs that I used to repair the chassis.
All and all, I think you'd have alot more fun with an ed hardy or an air-hogs for the same price or less.
Zerodark is offline Find More Posts by Zerodark
Old Nov 01, 2011, 10:35 PM
Azn_Ace is offline
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
Here's the photo
Nope. This is a new one. Picked it up for my son - pretty cool.
It's a relatively large coax, uses 27MHz radio (as opposed to IR), and because it's heavier can fly outdoors.
They call it 3.5CH because there's a button to turn on blinking LED's across the boom as well as the missile. Flies very well - very stable and tracks precisely. I tried it outdoors. Of course, because of it's size, it is more prone to break if you crash it.
I just got myself a Blade 450 3D heli - I figure I'd get my son a larger companion to his little Syma (also from Costco)
PS. I think it's a great deal and won't last long at Costco. Helis this size cost at least twice as much at Frys.
Old Nov 01, 2011, 11:52 PM
Azn_Ace is offline
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
Here it is
It's in their online store now:
http://www.costco.com/Browse/Product...=1&topnav=&s=1
However, it was less in the brick&mortar store.
The only drawback is the charge time - 2 hours with supplied charger!
Does anyone know the type of battery it takes? Perhaps can get spare ones for additional flights between charges...
Old Nov 02, 2011, 03:00 PM
sevenbravo is offline
Find More Posts by sevenbravo
sevenbravo's Avatar
Boise, ID
Joined Jan 2003
I picked one up as well. Very stable and surprisingly tough. I stripped every unneeded item to improve its performance and that does help a lot. Hard to beat for $35.
sevenbravo is offline Find More Posts by sevenbravo
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Is this big heli a re-badge of another brand/model? I somehow remember seeing that LED missile somewhere before, except I just couldn't place it right now.
Ace, is the battery fixed inside of the canopy? Could you tell us a bit more about the specs of the battery, like voltage, C-rating, mAh, dimension, weight, connector type... whatever you could tell us. Is there an ON/OFF switch, or do you connect the battery to fly, disconnect to store/charge? Seriously, 2 hours of charge time for a few minutes of flight time? What is the current rating (mA) on the supplied AC charger?
Zerodark, how about editing your post since all the info there really relates to a completely different model. I pointed my friend to this thread, and he said he'll pass. I asked why, and he said because of a couple of bad reviews. Now, I see what he was talking about. He read the bad reviews of the completely different model. So, please get rid of those quotes for others that come and read about this Costco deal? Thanks.
Heli Pad is offline Find More Posts by Heli Pad
Old Nov 02, 2011, 05:48 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
EX RC Sky Crawler
Saw the EX RC Sky Crawler at my local Costco, it's a very typical mid size 3 CH, RF controlled type toy heli with 130 size motors and most likely 1000mah 3.7V lipo,very similar to the JM806:
http://www.rcgroups.com/forums/showt...ighlight=jm806
Here's a video of the Sky Crawler:
exRC Sky Crawler Helicopter (1 min 10 sec)
Doubletap is offline Find More Posts by Doubletap
Old Nov 03, 2011, 12:14 AM
Zerodark is offline
Fledgling Aviator
Joined Oct 2011
That's a nice heli. I might have to break down and go to Costco. Let's see, what does the wife need from Costco?
Old Nov 04, 2011, 11:11 PM
demirde is offline
Find More Posts by demirde
Joined Nov 2011
Sky crawler
On second day my upper gear is stripped. What's up with that?
It seems like a very nice heli.
I only used it until the battery died which is really a whole 15 to 20 minutes.
Any comment is welcome.
Thanks.
demirde is offline Find More Posts by demirde
Old Nov 05, 2011, 12:09 AM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Originally Posted by Heli Pad View Post
Is this big heli a re-badge of another brand/model? I somehow remember seeing that LED missile somewhere before, except I just couldn't place it right now. . . .
This might be the one - mid-size MJX-T05 3ch next to the Sky Crawler. Not the same heli, though.
gordonzo is offline Find More Posts by gordonzo
Old Nov 05, 2011, 01:02 AM
gordonzo is offline
gordonzo's Avatar
Joined Jan 2011
Thanks.
Am I correct in assuming you are fairly new to rc helis? You have come to the right place.
I believe the upper gear is attached to the outer shaft/lower blades. Requires a bit of disassembly but a good, easy learning experience. I have only once seen the upper gear damaged on any coax heli, and that was caused by a hard hit with the power kept on full. Is that what happened? It's ok - you can tell us.
Things your seller may not tell you about your rc heli:
1. Seller's descriptions are frequently exaggerated.
2. Most coax's need a calm day to fly outdoors.
3. Li-po battery management is critical. Read up on it or ask questions.
4. Learn to cut the throttle when crashing.
5. Certain frequencies (& infrared) may experience interference in certain areas which can cause momentary loss of control.
6. Some helis, particularly department store models, can be hard to find parts for. You may have to match that gear up from another model.
Welcome to flying, fixing and fun. There is a whole rc world to explore and lots of people here to help.
Old Nov 05, 2011, 02:05 AM
Azn_Ace is offline
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
Thanks. The included charger is 3.7V 800mA. If it's a 1000mAH lipo, it shouldn't take two hours to charge (indicated in manual)...
Does anyone know if the battery can be charged at 2C?
Old Nov 05, 2011, 02:06 AM
Azn_Ace is offline
I feel the need...
Azn_Ace's Avatar
Orange County
Joined Feb 2011
I'd guess he took it back to the store, blaming it on the heli...
Old Nov 05, 2011, 02:07 AM
Aara chen is offline
Find More Posts by Aara chen
Joined Oct 2011
a nice helis,I must have one
Aara chen is offline Find More Posts by Aara chen
Old Nov 05, 2011, 03:24 AM
Heli Pad is offline
Heli Pad's Avatar
Joined Aug 2011
Are there any replacement parts available online for this helicopter (not what comes with the box)?
Discussion Another Toy Heli at Costco Doubletap Coaxial Helicopters 69 Oct 23, 2011 09:46 AM
New Product Oregon Scientific ATC9K with 720p@60fps, now at Costco Glenstr Aerial Photography 0 Jul 11, 2011 10:00 AM
Discussion A Cheep $45-50 3CH 2.4Ghz Crawler Radio? SoMoney Rock Crawlers 6 Jun 17, 2011 07:25 PM
Discussion RockSlide RS10: A $150 RTR 3CH 1/10 Crawler?! SoMoney Rock Crawlers 28 Sep 28, 2010 02:28 PM
Discussion EXCALIBUR Sky Wings Fighter grantman54 Micro Ready-to-Fly 2 Feb 26, 2009 10:54 AM
