Old Oct 31, 2011, 09:13 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Delta (flying) wing setup help!!!!
QUOTE 1320turbo
I have an Aurora 9 with v1.08 and use to fly with v1.07 and my delta setups worked as designed.
Now with version 1.08 when I make a trim change only one elevon will move with the trim change and the other one never moves.
Control surface deflection is correct with stick movements but trim is completely screwed up.
Model memory was working fine until the upgrade.
Have reprogrammed to a different model number thinking data was corrupted....its not. its still does the same thing.
Elevator trim moves the right elevon only and the aileron trim moves the right elevon only.
The home screen shows the trim moving for the elevator and aileron, but I go to the the monitor screen and it corresponds to the elevon movement.
With any trim adjustment I only get roll trim (but only with one elevon moving) and NOT pitch. Please help me out.
No problem experienced with upgrades when Delta/Flying Wing is set up as shown:
Aurora 9 - Delta Wing - set up EPA, D/R & EXP w/photos.
Aurora 9 - Elevon, Ailevator & Taileron - Set up.
"When setting up model in either Acro or Glider mode, under system menu select
[MDL type] > [Wing] > (page 2/1) > [2AILE] or with separate flaps as appropriate.
. Default then places servos/channels as shown in attached extract from Optic 6 manual.
. Default is as with Hitec Servos, standard clockwise rotation.
If using Futaba servos or clones thereof which rotate in the reverse direction, open
[System] menu > [reverse] reverse channel 1 & 2.
See also page 103 of Aurora manual, extract attached
Aurora 9 - Airbrakes -Twin Rudder set up. posts 4503 & 4504 e.g. Stryker F27-Q
EPA, ATV, Dual Rates & Expo Differences & Caution + ESC BEC Set Up may also assist.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Oct 31, 2011, 09:38 PM
1320turbo is offline
Find More Posts by 1320turbo
United States, MO, St Charles
Joined Dec 2009
My planes are setup EXACTLY as instructed. It was working previously. NO programming changes were made and i have had several flight with the trim functioning perfectly. I have only updated the transmitter, module, and receivers to the latest firmware, and now it acts up. In fact, I had one delta working perfect and the newly programmed on not, so i copied the model to a new model, and the new model did not work properly either. then i went into the original model and moved the trim around and then it went crazy too... there's a glitch somewhere...just gotta find it....
1320turbo is offline Find More Posts by 1320turbo
Old Nov 01, 2011, 05:08 AM
A.T. is offline
Joined Aug 2002
Answered on duplicated thread
Alan T.
Question Flying wing radio setup Scott Seidler Thermal 15 Nov 30, 2011 11:27 PM
Discussion Flying Wing vs Delta Flyboy Steve Foamies (Scratchbuilt) 3 Nov 02, 2011 09:40 AM
Discussion Delta Wing Setup Jamzdabrainz Electric Plane Talk 0 Sep 19, 2011 12:07 PM
Help! JR 9303 delta/flying wing setup help! dbatey Radios 4 Aug 26, 2008 06:07 PM
Help! !! HELP !! Delta Wing Setup jetcaptain Foamies (Scratchbuilt) 5 Aug 09, 2008 05:18 AM
