Old Oct 31, 2011, 05:56 PM
A10pilot is offline
Find More Posts by A10pilot
A10pilot's Avatar
United States, TX, Seguin
Joined Mar 2006
How Do YOU Measure Power on Large EDF Systems
All:
I have been around glow ducted fans for quite some time and I am familiar with 3KW electrics (pattern planes) but I am now venturing into the 4+ KW EDf systems and I have some questions about power measurement.
I have an Astro Flight watt meter that can measure up to 50 volts, 70 amps and about 5KW. I am moving from the 70 mm EDf's to the 90- 127 mm EDf systems. I tend to be a numbers guy and I am interested in testing some of the 90-127mm fans/power systems and I am willing to buy some equipment to do the testing. I can measure volts (have a fluke digital voltmeter) but I am curious as to how some of you measure current (amps) in excess of say 70 amps, voltages above 50 and power above 3KW.
Questions:
1. Are there some devices out there that some of you use to measure volts other than a dvm.
2. How do you measure amps (say in excess of 70 amps)? Do you use a clamp on meter?
3. Do you simply calculate the power using volts and amps or is there a meter out there that you use?
4. Are there any watt meters out there that you might recommend for current above about 125 amps, packs above 12s?
5. How do you measure efflux (exhaust velocity) and where do you tend to measure it (between the stators or at the back of the tail pipe)?
I do not mean to sound harsh but I am really interested in hearing from those that have actually performed these measurements (like Knife Liddle, Corsair Nut and many others).
Thanks in advance and I look forward to learing some new stuff about the larger EDF power systems.
Ed
A10pilot is offline Find More Posts by A10pilot
Old Oct 31, 2011, 06:48 PM
Gaz-b is online now
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Have a look at eagletree systems nice loggers with loads of sensors available i test edf on a set of kitchen scales with a pito tube about 3" behind the eflux tube I measure thrust.air speed.rpm.volts mainly to see if the cells are holding or will need higher c rating.amps.watts.motor and esc temp.interesting playing with eflux diameter to see air speed and thrust ratio.
Gary
Gaz-b is online now Find More Posts by Gaz-b
Old Oct 31, 2011, 08:12 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
I have a clamp on type amp meter for measuring amps, it has a set of jaws that just close around one wire and measure through inductance I think. For volts I just hang a lipo checker off the balance tab on one pack. Watch the cell volts, multiply times cell count, multiply times amps. Beyond some point the watt meters aren't good for ESC health and are questionable as far as accuracy goes...
Chris True is offline Find More Posts by Chris True
Old Oct 31, 2011, 08:28 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Chris in right on about accuracy. When I started causing amp draws in excess of 80, I did a test to check rpm with Astro watt meter inline and then without. I saw quite a bit more rpm with it out, so I bought a clamp meter and have been using that ever since.
I'd like to know which amp meter guys are using. I bought the most expensive one I could find (it's Craftsman) and I have to give it a few good whacks to get it to zero out.
Steve C
Steve C is offline Find More Posts by Steve C
Old Oct 31, 2011, 08:58 PM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
I have a v4 ET eLogger (it's good for 70V and 150A) and also a 400A clamp on meter. For my really large setups I have 2 parallell batteries so the ET logger is hooked onto one of the batteries, total amp draw is then simply the double of this, also easy to verify with the clamp on meter. The ET logger also gives me Volts, rpm, temps and efflux speed readings, the limit is really how many extra sensors you purchase.
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Old Oct 31, 2011, 09:38 PM
A10pilot is offline
A10pilot's Avatar
Joined Mar 2006
Guys:
thanks very much for the replies. These are the kinds of things I need to know.
Ed
Old Oct 31, 2011, 09:46 PM
Joined Dec 1996
The one I use is by Graupner Steve, bought it off JC (aka Bidule) prbably 6 or so years ago second hand. Or maybe it was someone else <g>. I met him at a little F5B electric glider event to take an Cougar off his hands. The amp meter might have come from a different competitor. Been happy with it, it's got a little dial for zeroing - very sensitive adjustment.
Old Oct 31, 2011, 10:17 PM
Bajora is online now
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
Yep, the 150 amp Eagle Tree eLogger is the method I use too. Castle 6mm bullets for connectors on it.
Bajora is online now Find More Posts by Bajora
Old Oct 31, 2011, 10:44 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
The ONLY fully accurate method is using an inductive clamp-on type meter. Shunts, like what are used in the eLoggers have a high resistance and will not give you the exact same amps when the device is removed (it will be higher).
JimDrew is offline Find More Posts by JimDrew
Old Oct 31, 2011, 11:52 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Thrust stand and amp meter minimum, watts mean very little without other figures to support it.
You can bust 3000 watts and get 6pds of push on bench and be wasting a lot of energy
erh7771 is offline Find More Posts by erh7771
Old Nov 01, 2011, 03:22 AM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
Shunts, like what are used in the eLoggers have a high resistance...
Adding something between ESC and battery adds resistance for sure. But there is no shunt in Eagletree (Hall-effect) and added resistance is minimal. It is somewhat the cables only. I use cables as short as possible on mine to keep that minimal.
I use that information (U-I-A-rpm-temp)to check I'm within the limits. This is interresting specially in flight. The key to me is efficiency of whole system.
Not the numbers but what it actually does IMHO.
/Jyri
jjantti is offline Find More Posts by jjantti
Old Nov 01, 2011, 04:34 AM
michel49 is offline
Find More Posts by michel49
Joined Jul 2011
According to Eagle Tree, the E-logger don't use a shunt but a Hall sensor.
michel49 is offline Find More Posts by michel49
Old Nov 01, 2011, 08:25 AM
JurassicJet is offline
Find More Posts by JurassicJet
JurassicJet's Avatar
United States, WI, Chetek
Joined Jul 2011
Gary
No disrespect but that setup looks a little scary...
A10Pilot....
If you check out EffluxRC they have a thrust testing sled that is pretty cool. http://www.effluxrc.com/MACH-THRUST-...L-MACHTF-S.htm
I have thought about building a setup. A person could do it cheap by using two ball bearing drawer slides (higher quality, not the cheap ones) mounted flat and horizontal with a sled attached to the slides and the slides attached to a base. The fan would be mounted to the sled. Then something as simple as a fish scale attached to the sled would give you the thrust read out. I could probably build that system for less than $30 (plus the fish scale). Just a thought....
JurassicJet is offline Find More Posts by JurassicJet
Old Nov 01, 2011, 09:42 AM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
To measure efflux velocity I use an 250-mph ASI I bought on eBay for $35.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Nov 01, 2011, 09:45 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Minimal and accurate are two different things. I designed a telemetry sensor using the same shunt that is used in the Eagletree logger. Grab the datasheet yourself and look at the stated resistance of the part. It's pretty good, but not 100% accurate. The Allegro current sensor is a metal shunt with a hall effect sensor on top of it, packaged together.
Discussion How do you know if a battery is bad on a DX7? got-one Radios 11 Sep 08, 2011 07:48 PM
Discussion How do you power video glasess, receiver & camera system? bigo66 FPV Talk 18 Mar 23, 2011 04:18 AM
Discussion What do you use to measure EDF RPM's? ScaleBrad Electric Ducted Fan Jet Talk 6 Jan 29, 2008 06:54 PM
Question How do you measure to see if you have a 20mm or 22.7 motor? BlazerB52 Electric Motor Design and Construction 5 Feb 10, 2006 12:35 PM
How do you ensure the prop adaptor stays put on large brushless set-ups? austinflyer Power Systems 6 Oct 08, 2004 09:47 AM
