Leduc, AB, Canada
Joined Oct 2008
Colin,
The ESM cowls attach to the fuselage the same way as any other model; with screws. I have learned in my build you do not have your battery tray on the cowl itself. You are right, it will not hold up without reinforcement. I have attached my battery tray to the firewall inside the cowl and cut a hatch in the bottom of the cowl. There have been quite a few electric conversions, but very few documenting their builds, hence the lack of info. I think with your power setup weight you should be ok so long as you keep the batteries on or forward of the CG. For instance, were the fuel tank would go. Cheers, Peter |
Joined Mar 2010
I would definitely plan to locate the batteries in the cowl. I have the Spitfire and face the same problem. Also, be advised that published CG on some or all the ESM/KMP planes may be wrong, resulting in a tail heavy plane. Best to verify CG at 25% MAC for the first flights.
Joined Mar 2010
If I recall, others wound up 1-1.5in forward of where the manual stated. I believe the issue was that the published CG was erroneously carried over from the larger model. I clearly remember that it was recommended to calculate 25% MAC at the fuse and use that as a safe starting point. Seems to be the rule for most of these warbirds. I don't know why the manufacturers get this wrong so often. Planned "obsolescence", perhaps?
I have not built the plane yet, so I have no real world info. |
| Thread Tools | |
| Build Log Electrifying KMP/ESM's Hawker Typhoon (The Sloooww Build) | Orvis | Glow to Electric Conversions | 252 | Mar 21, 2013 06:33 AM |
| Build Log ESM/KMP 82" Hawker Hurricane | Orvis | Glow to Electric Conversions | 58 | Feb 13, 2012 07:59 PM |
| For Sale light weight retractable tail wheel or nose gear!!! | unclegeorge | Aircraft - General - Miscellaneous (FS/W) | 0 | Sep 23, 2011 09:24 PM |
| Discussion ESM Hurricane Saito 200Ti | psjdb | Fuel Warbirds | 1 | Jun 28, 2011 06:17 PM |
| Wanted Completed TF Gold or Pica Spitfire or ESM /KMP ARF | TTRotary | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 22, 2011 03:39 PM |
