Old Oct 31, 2011, 09:41 AM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Rascal 110 Electric Conversion with Arming Switch and Spark Arrestor
I got a crashed Rascal 110 from a friend who nosed it in.
I had to replace the firewall,along with a few other little repairs.
All in all it turned out pretty good for a free plane.
Setup:
Motor: JustGoFly U5345-7 Motor
ESC: Castle Creations Phoenix HV-85
Prop: APC 22x10 e
Batts: 9s 5000mAh
Note: Planed to do 10s but one cell went bad on my battery.
Amp Draw: 62 amps @ WOT stactic
Wattage: 2020 watts
I also added a High Current Arming Switch w/ Spark Arrestor.
This killed the High Voltage Spark when plugging in the batteries.
And keeps me away from the prop when powered up.
I did radar the plane and my top speed was 80mph.
Pics and video to come.
TaSaJaRa is offline Find More Posts by TaSaJaRa
Old Oct 31, 2011, 10:58 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Here are a few pics of my plane.
The wing struts were broke so I made 2 from flat bar aluminum.
They seem to work just fine.
Old Oct 31, 2011, 11:29 AM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Arming Switch
This is my arming switch I added for safety. And also to remove the spark from high voltage battery hook up, of which can pit your connectors making a bad connection.
Here is my take on the link below.
I use a momentary switch and a 1 ohm 5 watt resistor.
The switch and resistor are in series. I then soldered the resistor end to one female bullet connector. And the other coming from the switch to the other bullet.
To arm I press the switch(wait till I hear the first beep) and plug in my male bullet key.
I used 10 ga wire on my plug filled with solder to make it stiff.
Then coated with epoxy to give it shape, covered with heat shrink.
Old Oct 31, 2011, 05:37 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Short Video
I did a short video to show how well the plane does. I had already made a flight before I did the video.
That was why I didn't fly that long. This was my 2nd time to fly this plane so not sure how long my flight times will be yet.
Rascal 110
Old Oct 31, 2011, 08:31 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
very nice. the glow day's are over. lol!!!
onefastxp is offline Find More Posts by onefastxp
Old Nov 01, 2011, 06:17 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Thanks.... Funny I have never done glow started with electric...
Old Nov 05, 2011, 09:46 PM
DJ_ is offline
DJ_
Find More Posts by DJ_
DJ_
Joined Feb 2011
I'm using these arming plug switch from www.sharpRC.com
Nice Arming setuo, I'm using these arming plug switch setups from www.SharpRC.com. Like them alot, super small and high current, and you can always add the anti spark curcuit.
DJ_ is offline Find More Posts by DJ_
Old Nov 06, 2011, 09:58 PM
JustGoFly is offline
Find More Posts by JustGoFly
Rochester, NY
JustGoFly's Avatar
United States, NY, Monroe
Joined May 2004
Tas - I flew my SuperStar Yesterday, 5345 on 10s. It was great. Very powerful setup. Previous fuel setup was 1.60 OS FX Two Stroke - which I would not fly as low. I can hover and pull out with authority. It's a bit tail heavy, which I figured out due to it's absolutely perfect flat spin, then it would climb when inverted. I'll add some nose weight.
I have not yet put an anti spark in it yet. I really like your setup and will copy. But I wonder if I should add a large capacitor in the power lead. Running a long power lead will stress the caps on the ESC. Normally 20 inch's is fine, but I like as short as possible on the power lines and will normally extend the lines going from ESC to motor.
Vinnie
JustGoFly is offline Find More Posts by JustGoFly
Old Dec 06, 2011, 09:00 PM
TaSaJaRa is offline
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
My batteries are right up front with the plug so I have a short run ...it's not to bad. Only it makes it a bit nose heavy.
Discussion *Sig Rascal 110 Coming In November ???* olezippi Giant Scale Airplanes 1115 Apr 22, 2016 09:50 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Fuel - Airplanes (FS/W) 1 May 29, 2012 03:05 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Airplanes (FS/W) 3 Sep 18, 2011 08:49 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Power Systems (FS/W) 3 Sep 05, 2011 08:55 PM
Off Site deleted G.F. Beurling Aircraft - General - Miscellaneous (FS/W) 0 Mar 11, 2011 02:32 PM
