Old Jan 27, 2013, 03:01 PM
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
I like mine
Originally Posted by SteveT. View Post
I like mine (as everybody knows), but others do too...
SteveT.
I like mine! I would be lieing if I said that I would not like a little more power,but because I wanted to run a 6s setup I went with this. There is plenty o power for this plane.
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Jan 27, 2013, 03:06 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
8S on the Hacker A60-5S, will definitely give you more..... But I run 6S on my Slick, and the planes weigh pretty close to the same...plenty of power for me, even using a 20X10....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 27, 2013, 05:23 PM
Barefoot Birkinsomething
rcbirk21's Avatar
United States, KS, Overland Park
Joined Aug 2004
the one thing i like about the motrolflys over the hacker is the prop adapter. the motrolfly's use a bolt on, the new hacker 28 pole motors use something different. i havnt used one, and no one has complained so it obviously is no big deal, but just throwing that out there.
rcbirk21 is offline Find More Posts by rcbirk21
Latest blog entry: Transmitt
Old Jan 27, 2013, 05:29 PM
Flyin' low
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Yeah, I was wondering how that works. Can anyone tell/show me?
zmonster97 is online now Find More Posts by zmonster97
Old Jan 27, 2013, 05:42 PM
rcbirk21's Avatar
Joined Aug 2004
http://www.espritmodel.com/hacker-a6...-motor-v2.aspx
it says back mount and collet prop adapter included, so i am assuming it uses a set screw to hold the prop adapter on.
Old Jan 27, 2013, 05:59 PM
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
I assume this is what you are talking about....
I've never used anything like it. I'm not even sure the order is correct since there is no clear picture on the box and the directions are no help.
I hope the order is correct.
What it would look like if there was a prop in between.
kuczy is offline Find More Posts by kuczy
Latest blog entry: Getting into 3D a little more
Old Jan 27, 2013, 06:03 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
Ok, thanks! So its pretty much a complex collet adapter? When you tighten the prop it tightens onto the shaft?
Old Jan 27, 2013, 06:05 PM
SteveT.'s Avatar
San Jose, CA
The prop shaft is also the motor shaft, as it runs all the way through the motor, There is a tapered collet that seats up against the motor (or as shown in the above photo) they also give you a sleeve about a 1/4" long to move it out farther if needed), then the prop thrust plate seats on the taper. It is not like a collet that fits over the end of the prop shaft. Once you tighten the prop down, it locks in place, no set screws, nothing to bolt on, very secure. The prop nut is also a locking two piece nut.....which also works very nice.
SteveT.
Old Jan 27, 2013, 06:09 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
But it is sort of like a collet in the way it tightens down, right? The tighter you tighten the prop, the more it tightens on the shaft?
Old Jan 27, 2013, 06:11 PM
SteveT.'s Avatar
San Jose, CA
Correct.... But not complex at all....much less complex than bolting a bolt-on prop adapter on, and much truer running....absolutely no chance of it being off center at all.
SteveT.
kuczy's Avatar
Joined Feb 2007
The end lock nut is also threaded so a Tru Turn spinner would bolt right up.
Old Jan 27, 2013, 06:12 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
I wonder why they decided to go that route? Wouldn't a bolt on prop adapter be better?
Old Jan 27, 2013, 06:14 PM
SteveT.'s Avatar
San Jose, CA
No, as stated in my last post, much truer running that a bolt-on, and much easier to manufacture
SteveT
Old Jan 27, 2013, 06:15 PM
SteveT.'s Avatar
San Jose, CA
True!!
SteveT
Old Jan 27, 2013, 06:22 PM
Flyin' low
zmonster97's Avatar
Joined May 2011
SteveT
Ok, but I generally like bolt on prop adapters better. I'll still probably get this motor though.
Also, if you bend this shaft, you can't just bolt on a new prop adapter, you n eed to replace the shaft.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
