Old Jan 22, 2013, 06:57 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
I was flying a 72" Extra with a lot of power (8S Hacker A60-6S) today with HS-7985MGs today, and they work just fine....but as noted, if you can afford a bit more, Then get the HS7955TGs, for Chief....OR, if you want Savox 1258TGs, then Aztech Aeromodel has them, and if you call Azhar, and tell him Steve Tillman sent you, he will give you a 15% discount on them....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 22, 2013, 07:20 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
SteveT
Now that's a good deal! Very tempted! I'll be ordering the parts over the next month. I'll order servos this week or next week. Airframe should be here in early March by which time I should have all the equipment
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jan 22, 2013, 08:54 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Hey this may have already been touched, but I noticed you said you are going to run a 6 Cell set up. When I called Ken at Sub Sonic he told me that he has never had a 5320 run on 6 cell. I just bought the Hacker A60 6XS and run a 21x10 Prop and I am very happy with power. I also have 7955 in my plane (And what a difference they really do make! Good luck with your set up
Originally Posted by kuczy View Post
I'm really wanting this plane. I'm having a hard time pressing the buy button.
Is there a reason to go with the 7954's over the 7985's? I'm only planning on running 6s for the foreseeable future. 1 local guy (Ronbo) is using the 7985's and likes them. I'm just figuring for the extra $10 it might be worth it or is it a little overkill
I have a BEC Pro and ICE100 already. Just need to decide on the servos and motor. I think I'm going to go with the Motrofly 5320-330KV...again though wondering if the I should go with the Hacker A60-6XS...
Thanks for any advice.
Luke
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Jan 22, 2013, 09:10 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
you can also go with the motrolfly 4330 on 6s. heard great things about it from wamsy on his 72 extra
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 22, 2013, 09:15 PM
Joined Jan 2012
Yes Sir! That is the Motor Ken recommended to me I just could not remember if it was the 4325 or 4330 So I did not want to say one or the other.
Old Jan 22, 2013, 09:29 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Originally Posted by RCPilot1234 View Post
I'm pretty adamant on getting the S9352HV servos, largely due to Joe Smith's video But is it the best servo for this plane? The three listed below appear to be the best. I think I'll get the S9352HV however
Futaba S9352HV- probably the best spec. But it's not brushless.
JR DS8711HV - it's bigger and slower but has a huge amount of torque.
MKS HBL950 - about normal size. It's brushless. Although speed and torque are less.
Thanks!
Don't do the JR's....their gears wear much faster than hitec's. I'd do the Hitec 7955's if you want to use them in a larger plane....otherwise, the Futaba High speed's that Joe uses are AMAZING in this 74...and would be useful and equally amazing in any other 30cc plane....
Yes...a nice setup for sure....
but I like my GT33 in my 74...
Bivens is offline Find More Posts by Bivens
Old Jan 22, 2013, 09:34 PM
Joined Jan 2012
Many thanks Bivens! Futaba servos it is
Old Jan 22, 2013, 09:42 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Silver 74" and 7955's ordered.
kuczy is offline Find More Posts by kuczy
Old Jan 22, 2013, 11:23 PM
NeverEnough is offline
Find More Posts by NeverEnough
NeverEnough's Avatar
USA, AZ, Phoenix
Joined Nov 2009
You're gonna love it.
NeverEnough is offline Find More Posts by NeverEnough
Old Jan 22, 2013, 11:36 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yep!
Buzzed is offline Find More Posts by Buzzed
Old Jan 22, 2013, 11:53 PM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
I charge one at a time I think I should try parallel!
I wouldn't be flying electric if I wasn't able to do parallel charging. I have a PA Extra MX that uses two 2200mah 3S batteries in series per flight. I have five sets of these batteries, so 10 batteries in all. I use an iCharger 208B that can charge at up to 20A and I have 1 to 6 parallel cables for the deans and balance plugs. I routinely charge six of my 2200 3S batteries in parallel at 13.2A, which is 1C for six of these. For the Edge, I plan to buy probably three 5300mah 6S batteries and so I will be able to charge three of them in parallel (15.9A at 1C).
Neil_SC is offline Find More Posts by Neil_SC
Old Jan 23, 2013, 12:12 AM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
That's a great idea. I have the KMX and charging 12 packs is a pain.
Old Jan 23, 2013, 12:07 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
The 208B is a 350watt charger IIRC so that will be 13.8A max. I use 2 206Bs and charge 2 at a time on each of them for my 6s 5300s
Enterprise7 is offline Find More Posts by Enterprise7
Old Jan 23, 2013, 05:24 PM
Joined Jan 2012
As kuczy said that's a great idea! I think I'll try that I'll need to be careful to get the same voltages on each pack I think. Beats buying more chargers, haha!
Old Jan 23, 2013, 06:27 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
No need to worry....just plug, charge, fly, plug, charge, fly..... parallel charging is no problem, it soon becomes routine!
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
