Old Jan 04, 2013, 09:55 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by blaiss View Post
I'm gonna have to try those one of these days. Problem is I still have about 20 EC5s and about 30 pairs of Deans.
you can always make a few adapters to make the transition easier
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 04, 2013, 10:05 AM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Originally Posted by weaser42 View Post
I'm using 45 amp APP on everything including my electric 104 and Logo 700.
WOW REALLY?
Don't you think that maybe you should have gone to the 75a version?
Alex Schauer is offline Find More Posts by Alex Schauer
Old Jan 04, 2013, 10:20 AM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
Originally Posted by alexjschauer View Post
WOW REALLY?
i dont know about the logo, but remember on the 104 you have 4 packs, which means every pack is in some kind of parallel meaning each pack only sees about half of the peak current, which on that setup is 170a or so depending on setup. 85a per connector is more than doable, actually easier on itself than our 6s 70" setups
Old Jan 04, 2013, 11:09 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Originally Posted by rcbirk21 View Post
the 45a rating is for a 110v input. if you do the calculation, that is over 200 amps at 6s voltage
Ah, that makes sense. I'm convinced
Neil_SC is offline Find More Posts by Neil_SC
Old Jan 04, 2013, 12:25 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Thankyou for posting this. Alot of misunderstanding goes along with these wonderful connectors. APP really should rename them lol.
Manta1 is offline Find More Posts by Manta1
Old Jan 04, 2013, 12:31 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
the problem is they werent designed for nor most popular use is rc. They are made to run on 110v, so i guess thats why they call them that. Personally i want them to make a 55a power pole, one that has a little bigger housing to fit heavily insulated silicon wire plus a bec wire or telemetry wire, but not as big as the 75a power pole. When (ok, if) i get rich im buying a plastic injection molder and making a tweener size
Old Jan 04, 2013, 12:34 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Totally agree!! We def need one more size up instead of going the golf cart connector crap up from the 45. For sure for sure. Maybe i should call the company. Tell them they are missing out on an important piece of the market. Yea, Manta said get yo butt in gear!
Old Jan 04, 2013, 12:37 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
if you start a petition ill sign it hahaha. the thing is we dont really need different size crimp sleeves, we can use the ones from the golf cart connectors, we just want a smaller housing
Old Jan 04, 2013, 01:01 PM
weaser42 is offline
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
was
Correct, the 104 has four packs with two || sets of two in series so i don't think they are seeing more than 80 amps each as ice 160 shows peaks of 160 amps. The 700 is 12s using 2 packs only and comes with a YGE160 esc and i don't know what it pulls for max amps. I was concerned the 45 app would not be enough but so far they are not even getting warm. The APP75 are huge, use them on supply side of PL8 charger as the 45s i originally tried got too hot for my comfort.
I also wish APP made something in between.
weaser42 is offline Find More Posts by weaser42
Old Jan 04, 2013, 02:20 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I think these are the 75a. I get these out of larger power supplys that run the computer room. I use these for my ATV winch(can move to front or back). I use the 250a for my truck(also move the winch from front to back).
For an 87" and up they would probably be ok, 74 a little bulky.
robj is offline Find More Posts by robj
Old Jan 04, 2013, 02:39 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
those are SB connectors, they are a little bit different. They use the same crimp sleeves, but are a single housing. I have used the 75a powerpoles a lot, and they are bulky. they look exactly like 45a powerpoles, they are just bigger.
Old Jan 04, 2013, 04:06 PM
rmr24 is offline
Find More Posts by rmr24
rmr24's Avatar
Joined Jul 2006
They are twice as big in every dimension, which doesn't sound like much until you see them side by side.
rmr24 is offline Find More Posts by rmr24
Old Jan 04, 2013, 04:37 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
2nd maiden =
I was lucky the field was wet and there was a puddle near by to scoop swamp water into this as it was on fire. damage is prop, cowl and front motor box extension and of course esc.
I'm calling faulty esc on this one
3drcparts is offline Find More Posts by 3drcparts
Old Jan 04, 2013, 04:50 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Castle Cremations strikes again. Bummer!
Motor OK?
Lardog is offline Find More Posts by Lardog
Old Jan 04, 2013, 08:07 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
AGREED!
was
Thats what i need to do for my PL8. I had to shorten the leads from the power supplies to the powerlab charger..The connectors would get way too hot. They still get hot tho.. maybe a bigger connector is in order for there then.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
