Old Jan 03, 2013, 07:15 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Pinky!!! How ya doin' my friend???
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 03, 2013, 07:16 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Good! I have not been flying much at all, but I am getting back into it.
PinkYakRC is offline Find More Posts by PinkYakRC
Old Jan 03, 2013, 07:23 PM
SteveT.'s Avatar
San Jose, CA
Your plane looks cool!!
SteveT
Old Jan 03, 2013, 07:32 PM
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
Thanks!
Old Jan 03, 2013, 08:48 PM
hertzrepkeith is offline
Find More Posts by hertzrepkeith
hertzrepkeith's Avatar
United States, CA, Hughson
Joined Jan 2012
Power Poles
I will have to look up power poles because I am not good at soldering either and that is my worst fear. (Losing a plane because I did not solder correctly!
Originally Posted by rcbirk21 View Post
ice comes bare on both the motor and esc side. use whatever connectors you are comfortable soldering/crimping. i use powerpoles just because i dont like to solder
hertzrepkeith is offline Find More Posts by hertzrepkeith
Old Jan 03, 2013, 08:53 PM
Joined Jan 2012
I was at the LHS today and they have two different sizes from what I saw. EC3's andEC5's the only reason I know is because I double checked it online to make sure I bought the correct ones today. Steve I grabbed a couple packages of the EC5s to put all those on because that is what my buddy Doug uses and he said when we go fly together he will share some of his batteries with me since I could only afford 3 right now! Thanks for the help guys
Originally Posted by RCPilot1234 View Post
The Castle ESCs come with no ends on them (unless you buy them used and someone left some on). Personally I like EC5. The ones I have have a very nice tension; not too tight nor too loose. With this being said, I have seen a few vary in size slightly. So if you stick with EC5, buy your connectors from the same company and don't mix and match, didn't work for me (some just wouldn't fit even though they should've). Make sure the ones you buy fit the Glaciers before soldering the ESC, some just are too tight/loose (it shouldn't really happen as I believe they should all be made to the same spec). They're fairly easy to solder; a 40W soldering iron is enough Never tried Deans. Although I'm interested in trying Power Poles one day Remember you can always make an adapter so you may as well stick to EC5 if you decide to buy a lot of Glaciers.
EDIT: Damn, beaten to the punch by Eric and Steve, haha! Man this forum's fast Should probably go to bed now anyway, 1AM here Night everyone
Old Jan 03, 2013, 08:57 PM
SteveT.'s Avatar
San Jose, CA
As has been said, everybody should use what they are happiest with. As to sharing batteries, that is always good...and adapters can also be made.
SteveT
Old Jan 03, 2013, 09:10 PM
ronbo111 is online now
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
I use EC5 no problem so far
ronbo111 is online now Find More Posts by ronbo111
Old Jan 03, 2013, 09:31 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
http://www.andersonpower.com/product...onnectors.html
That is the manufacturer info page. in this size of plane 45 amp powerpoles are plenty. if you do end up going into it, get this to crimp them :
http://www.powerwerx.com/powerpole-a...-contacts.html
It is worth its weight in gold and makes great crimps every time. Its soooo nice to not have to worry about waiting for the soldering iron to heat up, getting the correct solder, making a good joint (especially on huge wires), etc. I can get 4 packs ends on in a mater of 3 minutes. Its also nice because you can take multiple wires (such as external bec, telemetry, etc) and just put them all in the same crimp sleeve, one squeeze, and they are done. All you have to do to check to see if it is a good crimp is give it a good tug. if the wire stays in, your good to go. If it comes loose, grab a new crimp sleeve and go at it
rcbirk21 is offline Find More Posts by rcbirk21
Old Jan 04, 2013, 12:32 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Are the 45A Power Poles really big enough? Or are they severly underrated? I'm planning on running 6S and expecting close to 100A at WOT.
Neil_SC is offline Find More Posts by Neil_SC
Old Jan 04, 2013, 12:34 AM
SteveT.'s Avatar
San Jose, CA
Yes, they will work...
SteveT
Old Jan 04, 2013, 08:45 AM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
i'm using them in everything now, including my 90+ amp 57sc and my former 74 Edge. No problems.
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Jan 04, 2013, 09:22 AM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
the 45a rating is for a 110v input. if you do the calculation, that is over 200 amps at 6s voltage
weaser42 is online now
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
I'm using 45 amp APP on everything including my electric 104 and Logo 700.
weaser42 is online now Find More Posts by weaser42
Old Jan 04, 2013, 09:39 AM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
I'm gonna have to try those one of these days. Problem is I still have about 20 EC5s and about 30 pairs of Deans.
blaiss is offline Find More Posts by blaiss
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
