Joined May 2004
Thought I would share my cooling mods on this plane. Its not the neatest install but for sure works. I baffled one cowl inlet to cool the motor and it works great, I leave the other inlet open to cool my batteries. For the ESC, I made a tube out of two paper towel rolls and glued it in the lower cowl inlet. Then just mounted the ESC to get the direct airflow. I sanded open the inlet as well for more flow.
Very nice!!! ![]() Those simple mods really keep things working better and for a longer amount of time. Baffles work great to keep the motor cool while in the air, but my biggest problem is the heat build up after I land. I'm using really small computer fans that to fix that problem now.
I use one of these for this size of plane. http://www.digikey.com/product-detai...543-ND/2757797 I run it off of the balance port of the main pack and just wire it for 3s, so the only extra weight you add is the fan and it's very light. |
United States, NJ, Clayton
Joined Aug 2010
| Thread Tools | |
| Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 | CRFan1 | 3D Flying | 40 | Mar 04, 2012 02:45 PM |
| Sold 3DHS 41" Edge 540 PNP $225 | gonzoman5 | Aircraft - Electric - Airplanes (FS/W) | 10 | Oct 05, 2011 10:53 AM |
| Wanted 3dhs Edge 540 47" (red bull scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 13 | Sep 29, 2011 02:19 PM |
| Wanted 3DHS Edge 540 47" (Red Bull Scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 24, 2011 01:58 AM |
| Wanted 3dhs edge 540 47" (red bull scheme) | vhuang168 | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 08, 2011 10:13 PM |
