Old Dec 12, 2012, 11:29 PM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Originally Posted by ronbo111 View Post
I get 6.min with 6s 5300mah Glacier packs with plenty to spare and they also have a 7s 5300mah for even more power,great packs IMO from EP Buddy
Is that with a Hacker A60-6XS? Which prop? If I could get 6 min easily and have a little room to spare, I would be very happy. I am definitely considering those Glacier packs. A guy at my field uses them in his heli and loves them. They're lighter than the equivalent GensAce too. And it's very interesting that they have a 7S pack. Does anyone else sell a 7S pack? I thought about buying a 6S and a 7S to try out, but honestly I'm a little scared that I would accidentally charge the 6S as 7S one day.
Neil_SC is offline Find More Posts by Neil_SC
Old Dec 12, 2012, 11:38 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Use a Hyperion Super Duo, and you won't have to worry about that, as if you plug a 6S pack into a 7S program, the charger will warn you...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Neil_SC is offline
Joined May 2004
What size Lipo for RX/Servos?
I have a CC BEC Pro and want to power via a 2S or 3S Lipo. What size battery are most people using? I'm planning on using four HS-7955TGs. I'd like to get at least 5 flights on one charge. Any idea about how many mAh the RX/Servos use in a typical flight on this plane? I have a couple 3S 1300mah batteries I'm not using.
Old Dec 12, 2012, 11:39 PM
SteveT.'s Avatar
San Jose, CA
Run a pair in parallel...or with some type of redundancy system
SteveT
Old Dec 12, 2012, 11:42 PM
Neil_SC is offline
Joined May 2004
SteveT
True. My iCharger 208B would also warn me as well, so I guess it's not that much of an issue. Plus the 7S would have a different balance connector and that should tip me off when I'm connecting it to the charger.
Old Dec 12, 2012, 11:46 PM
Neil_SC is offline
Joined May 2004
SteveT
What size battery are you using?
Old Dec 12, 2012, 11:53 PM
SteveT.'s Avatar
San Jose, CA
I don't use a separate RX pack in 30CC size planes. I run a BEC Pro, right off of my flight packs.
SteveT
Old Dec 13, 2012, 12:13 AM
Neil_SC is offline
Joined May 2004
SteveT
This is my first 30cc size plane, gas or electric, so I wasn't sure what was typical. I'd definitely like to power the BEC off the flight packs too, for light weight. Which do you think is more common, a dedicated battery or running off the flight packs?
Old Dec 13, 2012, 01:21 AM
SteveT.'s Avatar
San Jose, CA
BEC off of the flight pack is probably the most common on planes up to 30CC size...about that...separate packs....
SteveT
Old Dec 13, 2012, 05:30 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
Yes sir,Jeff has the Hacker A60-6XS in his 74" and with the 21x10 xoar ,6s 5300 and he flys 6min .With the Hacker A60-6XS ,I was thinking on 7s maybe a 20x10
ronbo111 is offline Find More Posts by ronbo111
Old Dec 13, 2012, 05:43 PM
SteveT.'s Avatar
San Jose, CA
I would think more like a 20X9 or 19X10....
SteveT
Old Dec 13, 2012, 06:14 PM
Neil_SC is offline
Joined May 2004
Awesome. I like this option of going 7S, especially since it will result in a little less current draw. Will the A60-6XS work ok on 7S? I guess I mean, does Hacker support it?
Old Dec 13, 2012, 06:23 PM
AllBread is offline
Find More Posts by AllBread
Like a boss!
AllBread's Avatar
United States, CO, Denver
Joined Sep 2007
Got in 4 more flights today on a calm, pleasant December Colorado day.
This is definitely my favorite of all the planes I've owned. I told myself I wouldn't get low with it until I had a number of good flights on it but it feels so locked in and gives you so much confidence that you can't resist flying it right in front of your face!
Thanks to Zach Lambert for the photos!
AllBread is offline Find More Posts by AllBread
Old Dec 13, 2012, 07:18 PM
SteveT.'s Avatar
San Jose, CA
No, they will not... When I first got my A60-6XS (which was as far as I know, the first 6XS sold to a private customer), the people at Aero-Model (including Sean, the owner), where adamant that the motor was not to be run on anything other than 6S. Since then, Noll, and a couple other guys at 3DHS have run them on 7S, and I believe even on 8S, and said they were wicked powerful.
SteveT
Old Dec 13, 2012, 07:21 PM
SteveT.'s Avatar
San Jose, CA
Great shots, and great flying!! I agree with you, the Edge is in a league all of it's own!! I have HS-7955TGs in mine, and HS-985's in my 71" Slick. I would really like to put a set of the 7955's in my Slick, bu alas, no money to do so. I think I might try the HS-7954's and see how they compare.
SteveT
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
