Old Dec 10, 2012, 09:08 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by Neil_SC View Post
I'm leaning toward a 6S setup because I do prefer a very lightweight 3D plane. It inspires more confidence to me and this is my first plane larger than a 60" wingspan. But is there a big differece in thrust between the typical 8S and 6S setups?
a similarly setup plane wont feel any difference. but you can get a bit more power out of the motor on 8s, but honestly if you like light and floaty stick with 6s
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 10, 2012, 09:17 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by Josef086 View Post
I am very glad I decided on putting using two elevator servos plus the pull pull rudder. The plane ended up on the nose heavy side.
Wow! Yours is the first 74" Edge that I have heard of that has come out nose heavy...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 10, 2012, 10:50 PM
0gravity is online now
Find More Posts by 0gravity
A tale of two slickies
0gravity's Avatar
United States, IL, Chicago
Joined Feb 2010
What motor are you using?
0gravity is online now Find More Posts by 0gravity
Old Dec 11, 2012, 08:14 AM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Joe is using the O.S. GT33. I helped him tune it the other day.
Mine with the Mintor 38 on a can has just 2 servos in the tail and I am not having any CG issues.
Enterprise7 is offline Find More Posts by Enterprise7
Old Dec 11, 2012, 09:18 AM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
So do you need to move the rudder servo to the tail if you go with a os33?
djmoose is offline Find More Posts by djmoose
Old Dec 11, 2012, 09:39 AM
lb.man is offline
Find More Posts by lb.man
fly low be happy
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
I have a gt33 in mine. ruder in the pull pull position. 1 ele. servo cg is at 4.75 from leading edge. I do like a forward cg.
lb.man is offline Find More Posts by lb.man
Old Dec 11, 2012, 09:41 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
I think I will do 6S. I mean, all of Joe Smith's videos of his Edge are on 6S and he seems to have plenty of power.
Neil_SC is offline Find More Posts by Neil_SC
Old Dec 11, 2012, 09:56 AM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
yeah, i mean if you like only having one pack, and like it being floaty, you will have way more than adequate power with the right motor/prop combo
Old Dec 11, 2012, 10:20 AM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
ditto, I have a mintor 38 in my edge and I have a pull-pull on my rudder
hosam is offline Find More Posts by hosam
Old Dec 11, 2012, 06:13 PM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
I flew Joe's 74" Edge at the Tenn. Huckfest in October, and it does have plenty of power and top end speed. However, he sets his TX timer for 4 minutes due to his aggressive use of throttle and to allow for a bit of conservative reserve. After my flight he measured the pack and said I could get by with 5 minute flight times. I was doing mostly low throttle rollers, a Split-S or two, and just easing the plane around a bit to get the feel of it. Flies really nice so I bought one and will have it ready to go by February.
But for my 74" Edge, I'm really wanting a bit longer flight times so I'm going 10S with a pair of 5S 4000mAh packs to start with, and the Hacker A60-7S (215kv) with a Xoar 20x10. That should give a good 7:00 to 7:30 minute flight times (motor calc.) doing a mix of 3D and precision at my, "cough", more relaxed 3D flying style
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Dec 12, 2012, 02:27 AM
Neil_SC is offline
Joined May 2004
Wow you actually flew Joe's plane. Must have been nice flying what I would assume to be a well set up plane. What capacity batteries were in Joe's plane? If I go 6S I plan to go 5300mah. I would be disappointed to get only 5 minutes. Can anyone on the forum with the A60-6XS, 6S 5300mah batts and 20x10 prop comment on typical flight times? I do an even mix of precision and 3D (nothing like Joe yet).
Old Dec 12, 2012, 03:24 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I don't fly the 74" on 6S, but as probably the first person on the 3DHS forums to fly with the A60-6XS (and I own three of them), I can tell you that it pulls the 71" Slick around just fine, and I get around 5.5 minutes, but you must realize, I do a lot of high throttle stuff, as I am not great at 3D. That said, I am also only using 5000mAH packs, not 5300mAH packs. And lastly, on my Slick, I am using a 20X10 APC prop, which really is probably more of an amp hog than some other lighter props, which probably also cuts down on my flight time.
SteveT
Old Dec 12, 2012, 04:33 AM
Byron C
3DeltaFly's Avatar
Joined Apr 2011
Joe was flying it on a 6S 5000mAh 40C Sky pack (~860g) with a 21x10. Yes, his setups are done right, and the Edge goes exactly where you point it. Flew nice on the float factor, and quick too (fitted out with high speed 0.06 sec. servos). Scott Stoops aerodynamic designs are hard to beat
Old Dec 12, 2012, 08:55 AM
gapple12 is offline
Find More Posts by gapple12
gapple12's Avatar
Joined May 2009
A50-12L and Turnigy 6S 40c 5000 packs on a 20x10. Im getting 7:30 a flight, and I fly mainly hard 3D.
gapple12 is offline Find More Posts by gapple12
Old Dec 12, 2012, 09:41 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by gapple12 View Post
a50-12l and turnigy 6s 40c 5000 packs on a 20x10. Im getting 7:30 a flight, and i fly mainly hard 3d.
wow!
robj is offline Find More Posts by robj
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 11:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 03:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 02:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 11:13 PM
