Talcum powder also works nicely, and nothing sticks to it....
SteveT |
Latest blog entry: My hangar...
Sweden, Åkersberga
Joined Aug 2012
If the CG do I would shoot for 2300watt, 6s and the lighter A60-6xs as my first choice to save weight.A larger prop. spinning slower is more efficient, and more quiet..... Hacker A60-5s is a different animal, not a comparable motor as beside the KV different it weights more |
SteveT |
Latest blog entry: Transmitt
Yup!!
"Spot-On" doubles.. "Spot-On" singles.. From Aztech Aeromodels I don't like plastic arms on anything larger than a 60" plane, however, the problem arises that aluminum arms don't come with M2 threads for the ball links used on 3DHS 7X' size planes. My solution to this is to use Dubro "pull/pull" crimps, to reduce the size of the hole. The large Dubro crimps are very close to M2, but a little larger than the 4-40 tapped hole found in aluminum arms (unless you get ones with M3 tapped holes). So, I drill them to about .002" undersize and tap the crimps in, and then cut them off flush.. SteveT |
Joined May 2004
| Thread Tools | |
| Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 | CRFan1 | 3D Flying | 40 | Mar 04, 2012 02:45 PM |
| Sold 3DHS 41" Edge 540 PNP $225 | gonzoman5 | Aircraft - Electric - Airplanes (FS/W) | 10 | Oct 05, 2011 10:53 AM |
| Wanted 3dhs Edge 540 47" (red bull scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 13 | Sep 29, 2011 02:19 PM |
| Wanted 3DHS Edge 540 47" (Red Bull Scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 24, 2011 01:58 AM |
| Wanted 3dhs edge 540 47" (red bull scheme) | vhuang168 | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 08, 2011 10:13 PM |
