Old Dec 07, 2012, 09:19 PM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
I don't believe anyone in the this thread has tried the dle-35. The engines I think we have seen the most of are the DLE-30, OS 33 (I am one of them), the mintor 38 and the syssa 30.
Josef086 is offline Find More Posts by Josef086
Old Dec 07, 2012, 09:39 PM
collinss is online now
Find More Posts by collinss
United States, FL, Winter Springs
Joined Sep 2010
What size Savox servo would be good the Edge. Would the Savox 1258 TG servos work for this plane? Savox has 15% 4 servos or more. http://www.savoxusa.com/Articles.asp?ID=328
collinss is online now Find More Posts by collinss
Old Dec 07, 2012, 10:46 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
everything ive seen says the 1258tg's are pretty awesome. i just ordered up 4x 2271 brushless servos...cant wait to try em out
rcbirk21 is offline Find More Posts by rcbirk21
Old Dec 08, 2012, 12:32 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
If you call Aztec AeroModel, and tell Azhar that Steve Tillman sent you, he will also give you a 15% discount.....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 08, 2012, 01:27 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Originally Posted by robj View Post
I run a pair of 3800 and 4000. IMO you don't want to get to light up front, I like mine more nose heavy than neutral. I run a 20oz 5320 330 with a 19x8. Batterys all the way up.
6 minutes of fun with 25-30 left.
Is that 8S or 6S?
Neil_SC is offline Find More Posts by Neil_SC
Old Dec 08, 2012, 01:29 AM
SteveT.'s Avatar
San Jose, CA
I am pretty sure that is 8S considering the KV of the motor...
And I have six 4400mAH packs charging right now for tomorrow!!!
SteveT
Old Dec 08, 2012, 02:18 AM
Flyer95 is offline
Find More Posts by Flyer95
Sweden, ┼kersberga
Joined Aug 2012
Originally Posted by SteveT. View Post
8S still easy, all you need is a "Y" connector. There is also the advantage of lower current draw.
SteveT
Thats true and bullets run without "Y" connector.
Flyer95 is offline Find More Posts by Flyer95
Old Dec 08, 2012, 02:29 AM
SteveT.'s Avatar
San Jose, CA
Yup...and I use bullets in my 89" Slick which is 12S....but the one thing I don't like about bullets, is that it is much easier to mess up and accidentally plug the batteries in wrong. I always plug the two packs together outside the plane, so less chance of confusion, but there is still a possibility....
SteveT
Old Dec 08, 2012, 05:56 AM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
Originally Posted by ronbo111 View Post
Here is video of two 6s 74" setups ,red/white has Hacker A50 12l with 20x10 prop ,gray racing with Hacker A60-6XS 21x10 prop ,both with 6s5300mah packs
H'm, no cooling air vent areas opened up on the red/white one? Or has that been addressed since shooting the video?
On the silver Edge, did you open some vent areas for the drive LiPo, i.e. in the battery tray's balsa sheeting? That would let some cooling air circulate around the pack and then exit through the "canister" bay vents.
Still thinking about how to do the cooling on mine (electric setup as well).
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Dec 08, 2012, 08:38 AM
DenverJayhawk is online now
Find More Posts by DenverJayhawk
United States, CO, Denver
Joined May 2010
Anyone know if this will fit in the back of a VW Golf or GTI four door? If yes, does it go straight in or do you have to go in at an angle?
DenverJayhawk is online now Find More Posts by DenverJayhawk
Old Dec 08, 2012, 03:39 PM
ronbo111 is online now
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
The red/white has air vents on the bottom,just doesnt show up on the vid,you may also want to put cooling holes in the firewall for airflow over the battery
ronbo111 is online now Find More Posts by ronbo111
Old Dec 08, 2012, 04:11 PM
Josef086 is offline
Joined Jan 2010
All that there is left to do on my plane is cut a small hole for needle adjustments and I will be ready to run some gas through the engine.
I also need to borrow a CG stand. Its some place with in the range but this is my first plane thats a little to big to not use the stand.
Old Dec 08, 2012, 05:11 PM
SteveT.'s Avatar
San Jose, CA
Nope....no stand needed.....what I use are a couple of the little silicon rubber "feet" that go on the bottom of jewelry boxes (clear, about 3/8" in diameter) that are available at pretty much any hardware store.....stick them on at the CG point where you want to start, pick it up with your fingers on the feet, and adjust as needed. Get it close, and go fly. One in the air with a basic trim, roll it inverted and see if it climbs or dives. If you need to push forward just a little on the stick, it is perfect, unless you like neutral (no stick) or slightly til heavy (slightly back on the stick). .Just a bit tail heavy is good for 3D, but harder to land.
SteveT
Old Dec 08, 2012, 07:26 PM
Enterprise7 is offline
Find More Posts by Enterprise7
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Originally Posted by djmoose View Post
Two quick questions:
Has anyone tried a DLE 35RA on the 74?
Does Chief Aircraft service the Mintors or do they send them to Top Dawg?
Thanks in advance!
Top Dawg services Mintors. ghoffman and I have operated 2 M38s (the whole story is long and complicated). The second one had a catastrophic failure when the ring snagged on the exhaust port. There was a LOT of slop in the first batch. This motor has been warranty replaced and the new one seems much better with a redesigned crank and other parts. The first motor we got also started to show signs of slop and is currently in for servicing. The M38 is the most powerful motor in the class that I am aware of. It is also the loudest and in most need of a canister. It spins a Mejzlik 20x7 at 7600 RPM.
Two of my flying buddies operates the DLE-35. Both of them are in Aeroworks Freestyle Extra 260s. We have not had a opportunity to compare notes on RPM as they were both going through break in when I saw them fly. They seem pretty powerful.
To be bluntly honest, in this class I see no reason to not select the O.S. GT33. It delivers over 7800 RPM with a 20x6 Falcon, has a super smooth throttle that is close to electric as I have experienced in gas with no need for a throttle curve, is very quiet on stock muffler (canister is quieter on M38), and has a ton of compression. The choke is super easy to setup with the guide built into the case. I know the 3DHS crew loves this motor.
Enterprise7 is offline Find More Posts by Enterprise7
Old Dec 08, 2012, 09:35 PM
Josef086 is offline
Joined Jan 2010
SteveT
Thanks. I may try that.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
