Old Dec 01, 2012, 08:09 PM
rogersrick123 is offline
Find More Posts by rogersrick123
rogersrick123's Avatar
Canada, BC, Vancouver
Joined Nov 2008
Originally Posted by rcbirk21 View Post
....moral of the story, buy a bunch of props and see what suits your flying style best. everyone flys differently and you wont know what you like best until you try multiple setups!
Sounds like a plan
Part of the fun of flying 3D is to experiment.a bit and find that perfect setup to suit your own style.
rogersrick123 is offline Find More Posts by rogersrick123
Old Dec 01, 2012, 10:17 PM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
i flew blais's edge with both of them. he initially had the 20x10 on (correct me if im wrong steve) and it just wasnt enough. the 21x10 had much much more punch and made me more comfortable in the air. this is depending on setup, how fresh your packs are, etc. i have no clue what the battery state was, but it wouldnt hurt to try both props.
Correct. On my setup the 20x10 was lethargic. the 21x10 felt more snappy. I get a full 6 minutes of hard flying on a 6S 5000 battery with plenty of reserve left.
I checked it today, and I'm getting around 5700 RPMs.
blaiss is offline Find More Posts by blaiss
Old Dec 02, 2012, 12:50 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Which 21X10 are you using?
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 02, 2012, 01:22 PM
blaiss is offline
Team Hillbilly
blaiss's Avatar
Joined Jun 2006
Xoar electric
Old Dec 02, 2012, 01:29 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Thanks...
SteveT
Old Dec 05, 2012, 10:33 AM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
Rainy days=no fly so i have decide to install a smoke system in my edge I have gathered most of the needed parts. Hoping to locate a muffler fitting and some tubing for making an injector. 2nd project for my edge is to re hinge the rudder, managed to loosen a couple of hinges with a ruder strike. Considering making the rudder removable by adding a music wire hinge. + side, with a removable rudder i will be able to load 3 planes 57 extra, 59 slick,74 edge and my entire family for outings to the rc club
lb.man is offline Find More Posts by lb.man
Old Dec 05, 2012, 12:16 PM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
I've seen the music wire hinges on the larger planes but I don't see why it wouldn't work on the 74 Edge. Are you planning on using the existing hinges after modifying them or are there some hinges you can buy specifically for this purpose? Good thing is that I haven't even started on my 74 Edge yet so I could do this modification from the start.
Neil_SC is offline Find More Posts by Neil_SC
Old Dec 05, 2012, 12:56 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
I am planning on using the extra hinges that came with the kit. I took a small file to the flange on the rivet an pushed the rivet out. I am going to attempt to cut the existing hinges apart, then drill them out with a 1/16th bit. or trying to melt them out. I am hoping to reuse the existing holes with some gorilla glue.
Old Dec 05, 2012, 02:43 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Just as a matter of mentioning, you can buy Robart hinge halves, so making a removable rudder is very easy....see this post.. and if I remember correctly, I used .047" music wire, and there is no slop....
1/8" halves...
3/16" halves...
One comment about drilling them out, is that you will usually end up with a piece inside the surface rattling around...no biggy, just annoying. As you said, you can use a soldering iron, but sometimes again, you end up with a piece ratting around. The last time that I had to replace a hinge, I cut off the big part of the hinge, then used a Dremel tool with a fine bit, and ground the very end of the hinge. I then used a piece of brass tubing the same diameter of the hinge, and filed some "teeth" on the end of a piece of it about 2.5" long. I put this in an electric drill and stuck it over the end of the hinge and just drill it right out..no problems at all, and nothing ended up inside of the surfaces..
SteveT
Old Dec 05, 2012, 06:35 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
Thanks Steve, I did manage to separate 4 hinges today. went pretty easy, just took a few light and i do mean light passes with a small file. and the lip on the rivet came right off. the rivet were very easy to press out. now i just need to find the right size wire for the hinges. as for the smoke system, I managed to aquire a 10oz. tank a pressure fitting some tubing and a TME simple smoke pump. Just playing around with placement right now.
Old Dec 06, 2012, 08:50 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
What hinges are those? The OEM?
robj is offline Find More Posts by robj
Old Dec 06, 2012, 09:56 AM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
Yes, those are the OEM hinges, they come apart very easily. The rivet that is used is aluminum.
Old Dec 06, 2012, 03:20 PM
robj is offline
robj's Avatar
Joined Nov 2008
The holes look bigger than the dubro's I have. Need something like a 104 hinge. I can't find much else.
Old Dec 06, 2012, 07:47 PM
Neil_SC is offline
Joined May 2004
6S or 8S?
I'm trying to decide if I want to go 6S or 8S. I currently do an even mix of 3D and precision. I will be buying batteries either way but I already have a CC ICE 100. What are the pros and cons between 6S and 8S? 6S draws more current since less of the power is coming from voltage, right? Isn't that why most 6S setup seem to involve 5000-5300mah batteries and 8S involves 4000-4400mah?
I compared the weights of the motor and batteries for 6S and 8S Hacker setups and got the weights below. So the 8S setup will be about 10 oz heavier. Does anyone know about how much thrust each of these setups make, assuming an 18" prop on 8S and 20" on 6S? The larger prop allowed on the 6S setup probably helps with 3D, right? I do like a very floaty 3D plane but I like to have enough thrust to comfortably hover at half throttle and have good vertical punch-out from 3D. Thanks.
Hacker A60-6XS (16.9 oz) + 5000mah 6S 30C (28.6 oz) = 45.5 oz total
Hacker A60-5S (21 oz) + 4400mah 8S 35C (34 oz) = 55 oz total
Old Dec 06, 2012, 08:10 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Rockford
Joined Jul 2008
Ive got a killer deal on my like mint 74 for someone in the Illinois area if interested
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
