Old Nov 25, 2012, 03:29 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Trying kicking it up to 7:30 and see what happens....then if you still have plenty, then eight minutes...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 25, 2012, 04:29 PM
gapple12 is offline
Find More Posts by gapple12
gapple12's Avatar
Joined May 2009
SteveT
Thanks SteveT
gapple12 is offline Find More Posts by gapple12
Old Nov 25, 2012, 08:55 PM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
Originally Posted by gapple12 View Post
OK, question. Ive been flying my Edge on 8S 4000 and 18x8 for a while with 7 minute flights and recently switched to 6S 5000 20x10 and like it much more. Locks into every maneuver better. Now, I'm flying 7 minutes like before and putting about 3300 back into the 5000 pack. Could I fly to 8 minutes since I have 1700 left in packs or is that pushing it to close ? Thanks !!
If it where my plane i would look at the voltage per cell after 7min, to help determine if I could fly longer.
lb.man is offline Find More Posts by lb.man
Old Nov 25, 2012, 09:05 PM
SteveT.'s Avatar
San Jose, CA
That is actually what I meant, but forgot to say so...
SteveT
Old Nov 25, 2012, 09:08 PM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
I always use the 80% rule. If I pull out more then 80% of the pack I need to back it down a notch. So for 5000 packs that means you can safely pull 4000 out. This allows your batteries to last longer and also gives you some added safety for in case of a missed approach.
Another way to get your timing down is to check your voltage per cell after each flight. I like to come down with 3.80-3.85 per cell.
Josef086 is offline Find More Posts by Josef086
Old Nov 26, 2012, 09:05 AM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Good info, thanks.......I was just about to ask about Voltage and how much to leave in the pack.
Old Nov 26, 2012, 10:38 AM
Neil_SC is offline
Find More Posts by Neil_SC
Joined May 2004
Do you know how much thrust you were making with the 8S vs 6S? Do you do any 3D or mainly precision? I'm still trying to figure out the power system I want for my Edge. Been leaning toward 8S but I understand that is a heavier setup.
Neil_SC is offline Find More Posts by Neil_SC
Old Nov 26, 2012, 10:50 AM
Neil_SC is offline
Joined May 2004
I pretty much just look at the voltage per cell right after the flight, like you say here, to judge if I'm flying too long. But 3.80-3.85 seems pretty conservative. Yes, the batteries will last longer if you only discharge them to 3.80 but how much flight time could you be getting? I've always discharged down to 3.75 per cell and my batteries usually last about two flying seasons before I start to notice degradation. We're only getting 5-7 minutes per flight as it is.
Granted, I've only flown 3S and 6S planes up to 2200mah so far so I'm spending between $10 and $40 per battery. Even with HobbyKing batteries, the 74" Edge batteries will be $100, so I might not be able to afford beating up my batteries then.
Old Nov 26, 2012, 10:52 AM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
United States, TN, Knoxville
Joined Apr 2011
Here's a handy motor/prop calculation tool that's helpful for comparing power / thrust / speed and etc. for various setups:
http://rcwebclub.com/PropEngine.aspx
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Nov 26, 2012, 10:58 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
if you're going to spend $100 on batteries for this plane, whether it be 2 4s packs to make 8s, or a single 6s 5000, do yourself a favor and try at least one set of either GensAce, SkyLipo, or Glacier from Epbuddy.com. the quality is much better and in my experience they deliver more even power over the course of the flight as well as more cycles per pack.
I used to be a HK battery buyer but after trying a few of the packs mentioned above, I won't be going back. the price difference is negligible especially when I consider how many HK packs I got that either had a bad cell out of the box or developed one after only a few cycles.
just my experience so far.
Irg is offline Find More Posts by Irg
Old Nov 26, 2012, 12:41 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I had some trouble with Gens ace, none have lasted over a year, actually less, much less. Hyperions for me.
robj is offline Find More Posts by robj
Old Nov 26, 2012, 12:54 PM
Josef086 is offline
Joined Jan 2010
It all depends on how much I spent on the batteries and how big they are. With 6s I use the 3.80 per cell limit. If its like a small 3s or 2s I don't mind sucking more out of them.
Old Nov 26, 2012, 01:22 PM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Not sure on thrust, but I fly 3D as well as a little precision and I like the 6S on Xoar 20x10 wood best. Ive tried 8S with a xoar 18x8 and 18x10. It flew it good and tons of power, but in my opinion the Edge needs more prop. I also tried a 19x8 and 19x10 with the 6S and still think the 20x10 is awesome. The plane just locks into everything better.
Old Nov 27, 2012, 04:38 PM
SteveT.'s Avatar
San Jose, CA
Old Nov 27, 2012, 06:35 PM
collinss is offline
Find More Posts by collinss
United States, FL, Winter Springs
Joined Sep 2010
UPS just droped off my new Edge (this is my first 7X size plane). Plane looks even more aweseome in person !!!!!
collinss is offline Find More Posts by collinss
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
