Old Nov 18, 2012, 02:09 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Very cool.....Your field is definitely in the middle of some desert it seems....any problem with rattlesnakes and scorpions out there?
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 18, 2012, 03:20 PM
NeverEnough is offline
Find More Posts by NeverEnough
NeverEnough's Avatar
USA, AZ, Phoenix
Joined Nov 2009
I'll answer for him..... YES. I was looking for a missing part that fell off a plane the other day, when I looked down and noticed a baby rattle snake right next to my foot. Needless to say I freaked out a bit.
NeverEnough is offline Find More Posts by NeverEnough
Old Nov 18, 2012, 03:27 PM
SteveT.'s Avatar
San Jose, CA
I bet!! And what a lot of people don't understand is that baby rattlers just as poisonous as a full grown one.....with the added danger that they don't have a rattle to warn you with...
Many years ago when I lived in Texas, I was headed out to a small lake to go fishing, and managed to step on a rattle snake...the only thing I could do to get away from it was to push the handle of my fishing pole down on it's head, and then jump away.....one very ticked off rattle snake, and one very scared schnittless guy....me!!
SteveT
Old Nov 18, 2012, 07:37 PM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
Originally Posted by SteveT. View Post
schnittless
there's that word again... hummmmmhhhhhhhhhhhhh
hosam is offline Find More Posts by hosam
Old Nov 18, 2012, 07:41 PM
SteveT.'s Avatar
San Jose, CA
Yup!!!
SteveT
Old Nov 18, 2012, 09:14 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Yup!!!
SteveT
Hehe HAHA
Buzzed is offline Find More Posts by Buzzed
Old Nov 19, 2012, 10:33 AM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
Prop Report
Had a blast yesterday dodging rain drops and trying out a new prop. Recently purchased a 20x6 Beechwood from Bob's Hobby Center. Found It to be easier to balance than other props I have tried recently, and was impressed with the lightness compared to similar props. I was able to achieve a stable idle@1600 rpm and a peak@ 7400, 22lbs of thrust measured with a fish scale. I think I am in love with this prop. Very controllable down lines, almost like having an air brake. Spools up nicely and excellent vertical pull out. Not much torque effect in hovers, but easy to start a slow torque roll.
74 EDGE 11/18/12 (7 min 46 sec)
lb.man is offline Find More Posts by lb.man
Old Nov 19, 2012, 09:17 PM
Josef086 is offline
Find More Posts by Josef086
Joined Jan 2010
I had a question. Does this plane use just one elevator servo or can you does it have a two servo option like the velox?
Josef086 is offline Find More Posts by Josef086
Old Nov 19, 2012, 09:23 PM
SteveT.'s Avatar
San Jose, CA
Velox only uses one elevator servo, and one is all this plane needs.
SteveT
Old Nov 19, 2012, 10:29 PM
Josef086 is offline
Joined Jan 2010
thanks.
Old Nov 20, 2012, 09:01 AM
Josef086 is offline
Joined Jan 2010
I will rephrase my question. Does it have the cut outs on both sides for the option of using two servos for redunancy reasons. The plane is on its way. I only ordered 4 servos and if it has the option I may put another one on order as well.
Old Nov 20, 2012, 11:51 AM
airportdog is offline
Find More Posts by airportdog
departure from controlled flt
airportdog's Avatar
SF Bay Area
Yes, it is an option. 74 Edge has cutouts for dual elevator servos though I would not recommend it, at least for electric setups as you will most likely end up with an very rearward CG.
I have used both a single 985 and single 7955 in my Edge without issues. Simple, reliable, easy setup.
airportdog is offline Find More Posts by airportdog
Old Nov 20, 2012, 12:04 PM
Josef086 is offline
Joined Jan 2010
Mines going to be on on OS GT33 Gas, but this was the thread I could find.
Old Nov 20, 2012, 12:22 PM
SteveT.'s Avatar
San Jose, CA
With a gas plane you will possibly be alright, but that said, the 74" Edge tends to come out tail heavy. I went with a heavy motor and batteries, and still ended up with 3oz of lead under the motor box to get it to balance, a second servo in the tail would definitely have made it too tail heavy. And really, again, if using good strong servos you don't need two for the elevator.
SteveT
Old Nov 20, 2012, 12:36 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
SteveT
But....I think if you throw away the manual, move your batteries up all the way(8s for me), I know you have the heavy motor, mine is 20oz 5320, remove the 3oz of weight, you will be fine and your plane will be 3oz lighter.
If I recall you have only flown your 74 for a couple minutes. I probably have over 150 flights on mine with no weight. It's neutral enough for me.
robj is offline Find More Posts by robj
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
