Old Nov 05, 2012, 04:43 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by rcdrum View Post
Thanks manta, how are you doing?
RC
im about 2 weeks into pt,which is gonna take a while.Pain is easing tho.As long as I dont over do it. I'm thinking the surgery is gonna work but not sure how much I will get back. Thanks for asking!
Manta1 is offline Find More Posts by Manta1
Old Nov 06, 2012, 02:21 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by lb.man View Post
4 more flights today return home to find my new stand offs have arrived cmala nice work, cant wait to clean the wood chips off my work bench so i can mount them.
Very Cool.
If you need another set I'll just trade with you
That sounds fair right? A set of custom standoffs for a custom guitar?
cmala is offline Find More Posts by cmala
Old Nov 07, 2012, 09:19 PM
lb.man is offline
Find More Posts by lb.man
fly low be happy
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
Originally Posted by cmala View Post
Very Cool.
yeah sure maybe when i scratch build a full scale edge.hahahaha
lb.man is offline Find More Posts by lb.man
Old Nov 11, 2012, 08:32 AM
RC Erik is offline
Find More Posts by RC Erik
RC Erik's Avatar
United States, FL, Naples
Joined Oct 2011
I searched the thread and found someone asking if an E-Flite Power 160 could be used but does anyone have this motor set up on their Edge?
I have an E-Flite Power 160, Castle HV 120amp esc, and 2 - 5000mah 5S packs laying around. And it looks like this might be the perfect match.
RC Erik is offline Find More Posts by RC Erik
Old Nov 11, 2012, 09:58 AM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
The power 160 would work fine. It is heavier than the recommended motor but it should balance without any problems.
skippy78 is offline Find More Posts by skippy78
Old Nov 11, 2012, 02:32 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Interesting. I have that power system in the cub I'm selling. Maybe I should hold onto the power system
Old Nov 11, 2012, 03:11 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Especially since the 74" Edge tends to come out tail heavy....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 11, 2012, 05:59 PM
airportdog is offline
Find More Posts by airportdog
departure from controlled flt
airportdog's Avatar
SF Bay Area
Might be overkill.
Power 160 on 10S is a popular motor choice for the EF 78" Extra which is a couple pounds heavier than 74" Edge.
I have both airframes and wouldn't dream of running 10S in my Edge. Depending upon "C" rating/form factor, your pair of 5000 ma packs may not fit Edge's battery tray (3 11/16" width).
Larry
airportdog is offline Find More Posts by airportdog
Old Nov 11, 2012, 11:35 PM
RC Erik is offline
RC Erik's Avatar
Joined Oct 2011
airportdog,
The EF Extra 78" was another choice. Do you think the weight of the batteries and motor might be too much for the 74" Edge? I thought the 78" Extra might be too big since its in the same size/weight as the 40-50cc powerplant and the 74" Edge is around 30-35cc powerplant.
Plus, the dimensions you gave 3 11/16th". Is that the width max for batteries?
cmala,
What size Cub is your Power 160 in? I currently run the motor in my 90" 1/4 clipped wing Cub.
I only have an 18x8 prop which is the very bottom end of the prop range. But as a result, I get about 16 minute flight times. It cannot hover but it is very close.
Old Nov 12, 2012, 12:00 AM
RC Erik is offline
RC Erik's Avatar
Joined Oct 2011
airportdog,
I was thinking more about when you said you wouldnt dream of running my system in the Edge 540. Yes, it would have way to much power but what are the downfalls? Would it be difficult to land due to the added weight?
Old Nov 12, 2012, 12:25 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Erik,
My cub is a hempel 1/4 scale 90" clipped wing cub.
The power 160 on 10s is what several of the guys in the 78 EF extra thread like for that plane so it definitely would be a good fit for that plane
Old Nov 12, 2012, 12:28 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
I have a 20 inch prop and get 9 minute flight times on the cub.
Probably has enough power to hover but the cub scares me post stall.
Plenty of power with the hangar 9 floats
Old Nov 12, 2012, 12:30 AM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
The 78 extra is in between the sizes of the 74 edge (30cc) and the 87 extra or 89 slick (50cc)
Old Nov 12, 2012, 01:01 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
I have a Rimfire 1.60 in my 78'' EF Extra on 10s. That would be too much for the 74'' Edge. The Extra is Bigger, Heavier than this guy. I fly my 74'' with a Motrofly 4325/310kv on 8s, and it has alot of power! It balances just fine too! That would be one heavy setup using the 1.60 and 10s 5000mah.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Nov 12, 2012, 01:52 AM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
I agree on 10s being way to much for this bird. It is a great flying plane on 6s and I am sure its ballistic on a good 8s set up. The edge can be so floaty and forgiving it seems like it would be a shame to weigh it down with too much power system.
Zimm98 is offline Find More Posts by Zimm98
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 11:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 03:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 02:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 11:13 PM
