Old Oct 24, 2012, 07:39 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
74 edge os 33gt
1.75" standoffs?
cmala is offline Find More Posts by cmala
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
No search on tapatalk
Can't edit posts either
Old Oct 24, 2012, 07:52 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
44.5mm
yep...
Bivens is offline Find More Posts by Bivens
Old Oct 24, 2012, 08:27 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Originally Posted by Bivens View Post
44.5mm
yep...
Thanks!
Again!
Old Oct 27, 2012, 08:31 PM
ronbo111 is offline
Find More Posts by ronbo111
lazy 3D specialist
ronbo111's Avatar
United States, OH, Canal Winchester
Joined May 2007
Looking at getting a new motor for my 74 Edge .Would the Motrolfly DM5320-330 work on 6s and 8s?
ronbo111 is offline Find More Posts by ronbo111
Old Oct 27, 2012, 10:43 PM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
Haven't posted a flight vid since the maiden. Here's a quick video having some fun in Dublin, CA while visiting friends in the bay area.
Edge 540 over Dublin, CA (1 min 49 sec)
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Oct 28, 2012, 06:45 PM
FIXXIN2FLY is offline
Find More Posts by FIXXIN2FLY
FLY ANGRY
FIXXIN2FLY's Avatar
United States, IL, Roscoe
Joined Jul 2008
Im sure it would. Its a bit bigger than the 4325-380 but the plane seems to be a bit tail heavy out of the box anyway. The 53 will give you the 8s option that isnt recommended on the 4325. You can always give Ken at Subsonic a call and get his recommendations on it.
FIXXIN2FLY is offline Find More Posts by FIXXIN2FLY
Old Oct 28, 2012, 07:03 PM
ronbo111 is offline
lazy 3D specialist
ronbo111's Avatar
Joined May 2007
Thanks ,Ya I will give Ken a call , looks to be a good fit and I know it will run cool
Old Oct 28, 2012, 07:22 PM
3DeltaFly is offline
Find More Posts by 3DeltaFly
Byron C
3DeltaFly's Avatar
Joined Apr 2011
Split_S Dave must not be around this weekend, or he'd of jumped in on this. Anyway, I got to check out his 74" Edge setup at the Tenn. Huckfest last month. I was surprise at how cool his Motrolfly DM5320-300 came down. It was just barely above ambient. From my notes Dave is running it on 8S 4000mAh and using a 19x10 prop.
3DeltaFly is offline Find More Posts by 3DeltaFly
Old Oct 28, 2012, 07:34 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
5320 and or 4325 can go 8s no problem. 5320 balances better on the 74 edge,but I have flown a 4325 and it seemed ok to me balance wise,but ymmv.
Manta1 is offline Find More Posts by Manta1
Old Oct 28, 2012, 07:35 PM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
works excellent with 8s and 8x8, 19x8. didnt have much luck with 6s, didnt have the right size prop. 7s though with a 19x8 was fun. ran all summer no problems. great motor. only if batteries lasted longer.
lb.man is offline Find More Posts by lb.man
Old Oct 28, 2012, 07:39 PM
bradhoke08 is offline
Find More Posts by bradhoke08
Old Dog learning new tricks~~
bradhoke08's Avatar
United States, PA, East Stroudsburg
Joined Jan 2011
I have the 4325-310 spinning a 18x8, casle ice100, with 8s - 2 4s 5000mah 40c and it balances great with room to go either way. I love it I would like to try a 19x8 just to see how it feels
bradhoke08 is offline Find More Posts by bradhoke08
Old Oct 28, 2012, 07:45 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
well put one on there.. check watts and amps,and temps after about 2 minutes of flight before keeping it. Sometimes in the winter you can prop up a tad due to cooler temps making packs less strong and also the cooler temps cooling the motors better
Old Oct 28, 2012, 07:48 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
just got back from my first set of post break in mix flights. decided to go with a 32:1 mix. and to try a 19x8 prop. It is amazing how much the control authority and roll rates increase just by increasing the prop size 1 inch. i was able to obtain an idle of 1600 and a top end of 7200. crank case temps after 15 minutes of hard flying,(trying to imitate the redbull racers) was 118 f . cooling fins were 102, and the hottest part of the pipe was 189 good pull out of hovers, short take offs. Beautiful snap to hovers. need to go fly some more, maybe think about touching needles again.
Old Oct 28, 2012, 08:23 PM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
No doubt the 4325 will fly the edge just fine. I am running a 4325-450 on 6s with an 18x8 and has good power but not insane (its parts I had in a 70" slick). If I were to start fresh with gear I would of gone bigger on a motor because I had to add a bunch of dead weight. Going with a bigger motor at least the weight is doing something for you. One thing though is I am about as light as you can get and the thing flies like a giant foamy, which is a lot of fun, I still would of gotten a bigger motor though.
Zimm98 is offline Find More Posts by Zimm98
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
