Old Sep 25, 2012, 09:28 AM
departure from controlled flt
airportdog's Avatar
SF Bay Area
Originally Posted by rogersrick123 View Post
My friend and I are going to pick up a couple of 3DHS 74" Edge planes when they are available at the beginning of Nov. I'm looking for the best setup for our Gens Ace 6S 5300 30C lipos.
We already have
ESC Castle HV 100
Castle Pro Bec
Several Gens Ace 5300 30C lipos
20x 10 Xoar props
My question is should we go with the 3DHS recommended Hacker A50-12L or go with the A60-6XS V2 28 Pole Outrunner. I've gone over every post in this thread and I'm getting confused has to what setup will deliver the best punch out in a Hover. Will the flight time be the same?
We like to fly slow 3D
Punch out of a hover is adequate (but not ballistic) with A50-12L. I have the same A50-12L/Xoar 20x10/6S5300 combination in mine. My flying style is a mix of 3D, slow flight, and precision. The A50-12L flys fine, but not enough power IMO, particularly when performing multiple elements on an upline, continuous in-place waterfalls, etc.
You can achieve a slightly forward CG if you use a 2S or 3S1300 flight pack with the BEC pro.
airportdog is offline Find More Posts by airportdog
Old Sep 25, 2012, 09:52 AM
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by SportFlyer2 View Post
Wow !!! What kV you running ???
Good question. And what batterys. I have a couple brand new hyperions on 8s and also have some 2 year of the same. I've never tested but I bet the new batts are worth a real 300-400 watts. hehe, 74 was jumpy the first flight! But the old ones still have plenty for me. I like good power but don't really need insane.
robj is offline Find More Posts by robj
Latest blog entry: Well...
Old Sep 25, 2012, 11:15 AM
rogersrick123's Avatar
Canada, BC, Vancouver
Joined Nov 2008
So other then weight will the A60 give me a little more power?
rogersrick123 is offline Find More Posts by rogersrick123
Old Sep 25, 2012, 06:01 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Oh heck yes!!! A60-6XS if you want to go 6S, A60-5S if you want to go 8S
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 25, 2012, 09:25 PM
fly low be happy
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
5320 330kv.
2- 4s 4000 30c packs 129 cycles, 6.5 min. flights normaly leave 3.87 per cell
18x8 pulls 83 amps
19x8 pulls 103 amps
motor ran pretty cool all summer
lb.man is offline Find More Posts by lb.man
Old Sep 25, 2012, 09:31 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
so i come home from work to find a rather large brown box upon opening the box i am greeted with another box. after opening that box what do i find but yet 1 last box and in it is a shiny new os gt33. if i only had longer bolts for my standoffs i could go fly tomorrow oh well more time to recheck for loose glue joints after 129 flights.now if i could only find a home for my sexy fly 5320
robj's Avatar
Joined Nov 2008
what i have but never put a meter on it. what brand of batterys?
Old Sep 25, 2012, 09:42 PM
Joined Nov 2008
SteveT
Thanks SteveT
Looks like that's the way I'll go. I have a new Katana MX coming in the mail Monday, so at least I'll have something to fly until the Edge's are back in stock at 3DHS
Old Sep 25, 2012, 09:44 PM
United States, TX, Palacios
Joined Feb 2009
Originally Posted by lb.man View Post
5320 330kv.
18x8 pulls 83 amps
19x8 pulls 103 amps
Cool...I got the 300kv on a 20 x 8 pulling around 88 amps and ~2600 watts...tried a 20 x 10 and the batts couldn't handle it (25C batts) or the ESC probably for that matter...over 100 amps and over 3000 watts...maxed both watt meter and ESC so I backed off to the 20 x 8...5320 took it no problem on the run up...it was cold, the batt wires were HOT in only about 8-10 secs of testing...
SportFlyer2 is offline Find More Posts by SportFlyer2
Old Sep 25, 2012, 10:20 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
sky lipos from hobby partz, work great awsome set up, just limited run times, 129 flights and less than 15 hours in the air. its time to go gas
Old Sep 25, 2012, 10:25 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
whoever had the brilliant idea to make the mounting holes for the extension box, the same as a dle 30, i thank you for the easy conversion,
step 1 unbolt electric extension box
step 2 bolt gt 33 in place.
ill have to figure the rest out latter
Old Sep 25, 2012, 11:44 PM
Team 3DHS
Bivens's Avatar
USA, TN, Knoxville
Joined Apr 2010
I may never figure out the Hacker motor numbering scheme.....A50, A60, A60xs...blah...blah...blah.... I suppose I've never had enough of them. I do know every plane I've seen with that new A60-something....has plenty of juice.
on another note....
I understand clearly.....33cc, 60cc, 120cc, 170cc...
Bivens is offline Find More Posts by Bivens
Old Sep 26, 2012, 12:52 AM
SteveT.'s Avatar
San Jose, CA
on another note....
I must admit to the same my friend....I used to think that the 40-50-6 etc, stood for the diameter of the motor....but that is clearly not the case....I guess I'll have to give Mike a call and ask him.....
SteveT
Old Sep 30, 2012, 02:19 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
so i got my os gt33 mounted and ready to go:Make it out to the rc club, only to realize that i left my aileron extensions at home. well i at least got to run a tank of gas through it, and mess with the carb settings. i can not wait to fly this engine, bench running, it seems to pull better than my 5320. and for some reason i am really good at getting this engine to run backwards
Old Sep 30, 2012, 05:57 PM
Joe's Dad and pit crew
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Bump up the idle a bit when your trying to start it.
Helps a lot.
jsmith285 is offline Find More Posts by jsmith285
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
