Old Sep 22, 2012, 01:30 PM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
I run new gensace 5300, my setup is high amp 450 kv on an 18x8. It will puff and heat up old batteries. I like the speed i get on the 18x8 but still have lots of pull out.
Zimm98 is offline Find More Posts by Zimm98
Old Sep 22, 2012, 01:36 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
nice!
yea higher amps are tough on the older generation packs. need a higher c-rating to handle that..
Manta1 is offline Find More Posts by Manta1
Old Sep 23, 2012, 09:38 AM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Motrolfly 4330-300 Update
Hey Guys. Thought I would post some numbers on the new 4330 wound to 300 KV that Ken made up for me. First of all the motor itself weighs about an ounce less than the Hacker A60-6xs that I had in there initially. Not a thing wrong with the Hacker I just wanted a little more punch.
Heres my setup
1x 30c 5300 Gensace 6s pack combined with 1x 30c Gensace 2s pack to make an 8s pack. Ice HV 110, BEC PRO, Savox 1258's, 20x11 Mejzlik prop.
On initial start it spiked to just above 3000 watts at 101-103 amps and settled to around 2930 watts at 98-100 amps. Freshly charged and relatively new batts. Real nice numbers there. Now I was initially concerned about temps because after about 20 seconds of playing around the motor temp itself reached 114 degrees. Asked Ken about it and he informed me that the motor would take a few runs to move some of the excess grease out of the bearings and should run cooler afterwards. I will also test a Xoar 20x10 later today to check some numbers. Below iis the email I sent Ken after yesterdays flights
Okay Ken. This motor is the cats meow so to speak. Using a 20x11 Mejzlik prop, Castle HV 110, BEC Pro, 1x 6s 5300 30c and 1x 2s 5300 30c to make a 30c 8s 5300 batt I tested it in flight today. Remember I was a little concerned about the temps getting warm? Well no worries there. Flew 3 minutes and landed to test temps. Outside temps are at 66 degrees, after 3 mins. flying time temp was 102 degrees. That is with a spinner on so no direct air going to the front of the motor, I do however have baffles directing air to the mid/back of motor. Took her up for 6 minutes doing a lot of uplines with mid to full throttle pulls and mild aerobatics, motor after 6 minutes- 106 degrees at the rear of the motor, batts are at 74 degrees. The power is wonderful to say the least. Rarely needed or used full throttle but I sure liked to have it when I did want it. Perfect motor and thanks for all your hard work.
Really like this motor. I will say that as a lot of people know this is a slightly tail heavy airframe, and even with the extra batt. in the nose shes still slightly tail heavy, but I'm used to her that way so I'm more than satisfied. Gensace batts come in on the light side compared to some so some heavier batts would not hurt it in the least. Hope these numbers help.
Steve
stevelmaa is online now Find More Posts by stevelmaa
Old Sep 23, 2012, 12:32 PM
Renton, Wa.
Joined Feb 2006
Just finished testing the new 4330-300 with a Xoar 20x10 prop. After spike watts settled in at 2700 watts and 93 amps.
Old Sep 23, 2012, 04:21 PM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
hey guys quick ? for you, does anyone know if the stopper kit that comes with the supplied tank is good for gas?
lb.man is offline Find More Posts by lb.man
Old Sep 23, 2012, 06:49 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Yes....good for gas!
Bivens is offline Find More Posts by Bivens
Old Sep 23, 2012, 06:57 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Gosh 2700 watts has got to be sicko power on that airframe!! lol whew
Old Sep 23, 2012, 07:22 PM
Renton, Wa.
Joined Feb 2006
I'm actually using the Mejzlik 20x11 at 2900 watts LOL. Too fun.
Old Sep 23, 2012, 07:23 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
nice!
Old Sep 24, 2012, 07:45 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
74" edge+fly 5320 8s 19x8 3400 watts=
Old Sep 24, 2012, 09:07 PM
SportFlyer2 is offline
Find More Posts by SportFlyer2
United States, TX, Palacios
Joined Feb 2009
Wow !!! What kV you running ???
SportFlyer2 is offline Find More Posts by SportFlyer2
Old Sep 24, 2012, 10:07 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
oh yea!!!!!!! V-ROOM
Old Sep 24, 2012, 10:09 PM
rogersrick123 is offline
Find More Posts by rogersrick123
rogersrick123's Avatar
Canada, BC, Vancouver
Joined Nov 2008
My friend and I are going to pick up a couple of 3DHS 74" Edge planes when they are available at the beginning of Nov. I'm looking for the best setup for our Gens Ace 6S 5300 30C lipos.
We already have
ESC Castle HV 100
Castle Pro Bec
Several Gens Ace 5300 30C lipos
20x 10 Xoar props
My question is should we go with the 3DHS recommended Hacker A50-12L or go with the A60-6XS V2 28 Pole Outrunner. I've gone over every post in this thread and I'm getting confused has to what setup will deliver the best punch out in a Hover. Will the flight time be the same?
We like to fly slow 3D
rogersrick123 is offline Find More Posts by rogersrick123
Old Sep 24, 2012, 10:14 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
We already have
ESC Castle HV 100
Castle Pro Bec
20x 10 Xoar props
A60-6XS as the plane tends to be tail heavy....
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 24, 2012, 11:24 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
just checked with ups my gt 33 is
scheduled for delivery end of day Sept 25th
not bad for an order placed on the 22.
gt33 in by the weekend cant hardly wait.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
