Old Sep 16, 2012, 06:34 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
A 5% KE mix is not too bad, even with a touch of aileron....not what most would consider horrible....
But the elevator mix would indicate you are tailheavy (assuming you have an up elevator mix).....go farther forward with your CG and report back. Mine is dead straight with no mix....but my GT33 setup is heavier on the nose than a leccy setup.
Bivens is offline Find More Posts by Bivens
Old Sep 16, 2012, 06:40 PM
blaiss is offline
Find More Posts by blaiss
Team Hillbilly
blaiss's Avatar
United States, OH, New Albany
Joined Jun 2006
Thanks Mike.
I have my battery all the way up to the firewall. I'll add a little weight up front -- or maybe a 2s receiver battery -- and see what that does.
blaiss is offline Find More Posts by blaiss
Old Sep 16, 2012, 06:43 PM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
I had to add a 2% aileron mix to mine flys great.
Zimm98 is offline Find More Posts by Zimm98
Old Sep 16, 2012, 07:32 PM
weaser42 is online now
Find More Posts by weaser42
House of Paine
weaser42's Avatar
United States, AZ, Gilbert
Joined May 2007
I've got -5% Rud-> Elev on left and +2% on right and -6% both ways Rud-Aileron for KE mixes on mine with same motor and Mej 20x11E.
weaser42 is online now Find More Posts by weaser42
Old Sep 16, 2012, 07:43 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Sounds like others are similar. I know mine is NICE...but I do know it's heavy on the front.
Old Sep 17, 2012, 09:10 AM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
I must be doing something different. I've got the electric setup with my battery an inch behind the firewall and no mixes.
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Sep 18, 2012, 01:05 AM
rcdrum is offline
Find More Posts by rcdrum
Team 3DHS
rcdrum's Avatar
USA, CA, Garden Grove
Joined Feb 2004
A 5% mix doesn't seem like much at all. I guess it all depends on the speed and angle of your KE passes. My Edge (Hacker A50, Gens Ace 6S 5300) balances on the back edge of the recommended range. I don't use mixes and, at my CG, find only minimal elevator and aileron input to keep the 74 straight down the center line. At speed, during more precision style manuevers, the Edge tracks straight with no counter input.
RC
rcdrum is offline Find More Posts by rcdrum
Old Sep 20, 2012, 08:25 PM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
so i am left with a empty spot on my plane starting to get ready for Huckfest in Lodi, only 21 more days, cant hardly wait. Thinking that i might fill the void in my cowl with an gt 33, $370 shipped to me by next friday if i order by sat. just not sure about setting up for gas. I have a nice servo for the throttle, stock tank and such. I imagine I could run servos and ignition off of my pro bec. Would I need an ignition kill switch? Always find lots of advise on converting from glow to electric, not much on electric to gas.
lb.man is offline Find More Posts by lb.man
Old Sep 20, 2012, 09:39 PM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
You can use the bec pro that is how i have mine setup to use 2s lipo. Yes you would need a engine kill i use this ibec and have been very happy with it http://www.tech-aero.net/ultra-ibec. The ibec plugs into rx so no ignition battery is need and also doubles as a kill swith.
skippy78 is offline Find More Posts by skippy78
Old Sep 20, 2012, 10:53 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
What kind of flight time are you guys getting with a motrofly 5320 and 6s 5000s?
I was thinking i could use some of these http://www.hobbypartz.com/98p-30c-5300-6s1p.html
I'm hoping to get one of these for Christmas
hone1er is offline Find More Posts by hone1er
Old Sep 21, 2012, 07:29 AM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
not sure about the 6s 5000, but with 8s 4000's i am landing @ 6 to 7 minutes with approx. 50% left in my packs. lots of mixed flying
Old Sep 21, 2012, 08:13 AM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
lb.....I'm glad to help. What standoff's did you get for you OS...I believe you need 1-3/4" (44.5mm) standoffs for the 74 and OSGT33. I'd order from this guy...cmala....
www.customstandoffs.com
For the OS...I LOVE my Falcon 18.5x6Wide prop!! It's not a "normal" cut...and Falcon's website doesn't show all of their props...but you may call Bob's Hobby Center and ask them about it. If you strike out...PM me and I'll try to help on that prop....I've got a couple of guys to check in with that may have one.
Old Sep 21, 2012, 09:46 PM
lb.man is offline
KBDD TEAM PILOT
lb.man's Avatar
Joined Sep 2009
Bivens, thanks for the info, the stand off length is helpful. very interested in the falcon props.gt 33 will be here by wed, hoping to have it broken in for huckfest.
Old Sep 21, 2012, 10:17 PM
Zimm98 is offline
Zimm98's Avatar
USA, SD, Rapid City
I do 4.5 mins on a 4325 I put 3300 mah back in. I do like the left stick though.
Old Sep 22, 2012, 01:25 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
holy wow how are your batteries? new? old? you are a left stick forward kinda pilot heheheheh
Manta1 is offline Find More Posts by Manta1
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
