Espritmodel.com Heli Air
Old Aug 30, 2012, 07:50 AM
hosam's Avatar
USA, MI, Livonia
Joined Nov 2004
Originally Posted by gapple12 View Post
That is were my packs are now, all the way up front. 2 4S 4000 packs and 1 2S 2000 pack. As far as they can go up as well as a few ounces of lead.
is the plane actually ballooning or is it more of the tail dropping giving it that ballooning affect? if the tail is dropping when you are slowing down then it is a tail heavy situation and allot of people will mistaken the situation. let us know the outcome when you do add more weight as Bivens noted...
Hosam
hosam is offline Find More Posts by hosam
Old Aug 30, 2012, 09:28 AM
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
before using the 4325 motrofly, i had an a50-16L with 4s 4000 x 2 and a 2s lipo rx pack. I was a few inches away from the firewall and it balanced out just fine on the wing tube. If an a50 worked in mine from a CG point of view, i'd assume it would probably work in yours too.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Aug 30, 2012, 09:26 PM
Team 3DHS
Bivens's Avatar
USA, TN, Knoxville
Joined Apr 2010
Balancing on the wing tube isn't always the final say in CG. Most do...but the edge has a center of lift far forward due to the straight leading edge....and rear wing taper.
I'm interested in what it does with a lot of nose weight....my money still goes on tailheavy.
Bivens is offline Find More Posts by Bivens
Old Aug 30, 2012, 09:34 PM
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by Bivens View Post
Mine does not balloon...but it floats for a while. The incidence questions always make me chuckle a little. It's not easy to mess this up with laser-cut locating pin holes and tight fitting stab openings. I assure you.....most of the people building THOUSANDS of ARF's by 3dhs each year wouldn't even know what an incidence meter is used for, nor possess one.
The thrust angle and incidence are set by the designer and laser cut. Of course, everything is a compromise....right thrust for example helps upright flight but means more left rudder is required when inverted harrier...
The bottom line, check that your CG is "nice", the plane should not baloon if you set it up slightly noseheavy...but may baloon a little if you go for "3D neutral CG's"....I like noseheavy because it's more precise....My edge land's itself without much help.
Also, make sure your linkages are all free from binding and the elevator servo is centering properly.
Your is perfect Mike dont touch it!!lol balloning is def tail heavy..
Manta1 is offline Find More Posts by Manta1
Latest blog entry: Lil repair work.
Old Sep 02, 2012, 01:30 PM
fly low be happy
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
just got done flying around and having fun
/watch?vhttp:/youtube.como8WzYnADDz8/www.&feature=plcp=
lb.man is offline Find More Posts by lb.man
Old Sep 02, 2012, 01:51 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
server not found is what I am getting..
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 02, 2012, 06:42 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
SteveT
sorry, 1st attempt at uploading videos. and adding links. on you tube its found under edge 74 010
will try another link
Old Sep 02, 2012, 08:58 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
74 edge 010 (5 min 24 sec)
i think i got it figured out
Old Sep 02, 2012, 10:48 PM
Renton, Wa.
Joined Feb 2006
Nice flying. Looks like great power.
stevelmaa is offline Find More Posts by stevelmaa
Old Sep 02, 2012, 11:51 PM
fly low be happy
lb.man's Avatar
Joined Sep 2009
thanks, i am really liking my motorlfly 5320, on 8s runs cool with an 18x8 plenty of power and comes down cool every time even when flying when its 105. insane with an 19x8 on 8s, and a real blast with 19x8 on 6s as well.did you decide to go with the 4330 or the 5320?
Old Sep 03, 2012, 08:36 AM
Joe's Dad and pit crew
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Originally Posted by lb.man View Post
Looks like you like it!
jsmith285 is offline Find More Posts by jsmith285
Old Sep 03, 2012, 08:37 AM
fly low be happy
lb.man's Avatar
Joined Sep 2009
just getting ready to head out to the club to get some flights in todaay, cant wait, just got done carving a 18x8 wide prop. am also going to try a 3 blade 16x8 on 6s should be fun
Old Sep 03, 2012, 08:59 AM
Renton, Wa.
Joined Feb 2006
I'm working with Ken on the 4330. Looks like the 4330 will come out approx. an ounce lighter than the A60-6xs, add the added weight of the 2s 5300 that I am going to use with the current 6s 5300 (Gensace), and that will be the weight difference. I'll know more at a later date.
Old Sep 03, 2012, 09:48 AM
fly low be happy
lb.man's Avatar
Joined Sep 2009
always grinning ear to ear before during and after every flight,
Old Sep 03, 2012, 01:10 PM
SteveT.'s Avatar
San Jose, CA
You carve your own props??? Man, I haven't done that since the 1960's....
SteveT
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
