SteveT |
Latest blog entry: My hangar...
Hotay....just thought I would check....as many people forget to do that....
SteveT |
Latest blog entry: Well...
How far forward......nose heavy does NOT balloon. What does "way forward" mean to you? Also, saying you have had it way forward makes me think you did not stay that way.
What components arenyou running. Any RX pack? Where is your rudder servo mounted? What flight pack and where is it normally sitting? As for "Improper" incidence.....I don't think it is safe to say any of us except Scott Stoops or Ben would know their intended design incidence.....and I'm not second guessing them. Mine drops the nose when inverted...and does not balloon. When I used to set up planes more tail heavy (near neutral)...they would always balloon. |
I dont understand how anyone can get the cg too far forward as my 6s 5300 is against the firewall on mine with the A50 and castle ice100 mounted on the side of the cage. (and pull pull ta boot)
![]() And I love my planes on the tail heavy side |
Latest blog entry: The family continues to grow
My plane is going to be flown on 8S, and with a Hacker A60-5S, two Thunder Power 4S 45C 4400mAH packs, a Castle ESC and a Castle BEC Pro... I still had to put two ounces of lead under the motor box to get it to balance at a bit behind the suggested initial CG point for the first flight. Once I have a chance to fly it, I am sure I will be changing is a bit, but as my packs are all the way to the firewall, I have lots of room to do this....
SteveT |
Personally, I think with that motor you are still tail heavy...if you slid you flight packs all the way to the front and then put the 2S lipo on top of that you might be closer....
SteveT |
| Thread Tools | |
| Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 | CRFan1 | 3D Flying | 40 | Mar 04, 2012 02:45 PM |
| Sold 3DHS 41" Edge 540 PNP $225 | gonzoman5 | Aircraft - Electric - Airplanes (FS/W) | 10 | Oct 05, 2011 10:53 AM |
| Wanted 3dhs Edge 540 47" (red bull scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 13 | Sep 29, 2011 02:19 PM |
| Wanted 3DHS Edge 540 47" (Red Bull Scheme) | SmokeDogg | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 24, 2011 01:58 AM |
| Wanted 3dhs edge 540 47" (red bull scheme) | vhuang168 | Aircraft - Electric - Airplanes (FS/W) | 2 | Sep 08, 2011 10:13 PM |
