Old Jul 13, 2012, 09:43 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Originally Posted by SteveT. View Post
Well....checked my CG and found that even with the heavier motor and 8S batteries all the way forward my CG is still back around at around 5 inches...I was hoping for a CG a bit farther forward to start with. I could send my new packs back and get some 4400mAH packs. This would give me four more ounces which would allow the packs to be moved back a little...and would also give me more flying time....Oh well...what the heck...it's only money.....right??
SteveT
It's interesting to see the variances in this airplane. I'm using 4000 4s Gens 25c and I can balance on the wing tube with the 2 packs about an inch off the fire wall.
Assuming you are using the pull pull on rudder, yes?
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Jul 13, 2012, 09:49 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Originally Posted by DenverJayhawk View Post
does anyone have the decal sticker set that comes with the 74 edge that they would want to sell? I'm specifically looking for the black stickers that reads "Edge 540" in the smaller font. I messed mine up applying it.
Ken, I'll give you mine.
You'll have to come get them.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Jul 13, 2012, 10:00 AM
Epoxy & CA Investor
Joined May 2010
Cory - thanks. PM sent.
Old Jul 13, 2012, 10:02 AM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I use Gens and Skys almost exclusively, but Thunder Power are typically much lighter. I never realized it until I was trying to add some flight time to one of my setups. A 5S 6600 25C TP is just one oz heavier than a 5S 5500 25C Gens, for example, but the price difference was $230 versus $100. Needless to say, I'm carrying the extra weight.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Jul 13, 2012, 10:10 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by -= GYRO =- View Post
I think that the reward CG is one of the reasons I didn't like this plane when I had the old power set up. Get some heavier batteries so you have the room to work with!
ugh, more weight. My fav is still my 70 with a 12.5oz motor. 8s 3800 in the middle(flew it once with a pair of 2500 hyperions...hoot!). No idea "where" the CG is, packs about 2-3" from the tube. But it flys neutral. Put it in the air and see where it is. Remember it's an AJ plane so a little nose heavy design.
robj is offline Find More Posts by robj
Old Jul 13, 2012, 10:14 AM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
The edge is a Stoops design...I have found that all 3 of the 30cc stuff fly mucho better nose heavy vs tail heavy!
joshet89 is offline Find More Posts by joshet89
Old Jul 13, 2012, 12:47 PM
The_MonsterMash is offline
Find More Posts by The_MonsterMash
3d flippin
The_MonsterMash's Avatar
United States, CA, Ontario
Joined Jan 2012
Originally Posted by Aeroplayin View Post
I always use two redundant LiFe batteries for five 380 oz-in servos and the Rx in planes 27% to 35% and the setup typically uses between 22 and 32mAh per minute from each battery. On this size plane I would think it is safe to say 50 to 60mAh per minute combined. If you are using one 1800mAh Life, I would consider 1260mAh as a safe capacity to use, so 21 minutes, or three 7-minute flights. I would try flying it for two minutes and recharge and keep track of what you put back. You may get as many as 8 flights from it, but check first to see what your personal usage is.
You can also do it on the ground by plugging in the Rx with the main battery off the plane for safety and moving the sticks around like a madman for a full minute, then recharge. Whatever you put back, divide 1260 by that amount and this will give you the number of minutes you can fly with that battery.
thanks looks like i will have to mess with it i want to run life unregulated but i am going to run a wike ibef from TBM with my dle30 and i am using 4 hs 5945mg and a high speed throttle servo....just want to make it as light as possible without using regulators
The_MonsterMash is offline Find More Posts by The_MonsterMash
Old Jul 13, 2012, 02:59 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
I use the LiFe without regulators on AR7000 and 9100 and would not consider them unless I went to LiPo with HV servos, which I have not done yet. I'm still using the JR 8611A, but for this plane, I'd probably go with the Savox SC-1258TG.
Old Jul 13, 2012, 03:46 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
4.75" is right at the front of the wing tube. My plane does balance on the wing tube, but the packs are against the firewall, so no room for adjustment....
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 13, 2012, 09:45 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
4S 45C 3850 packs on the way back to Thunder Power, and 4S 45C 4400mAH ordered. Just over four ounces more weight (to help with CG) and longer flight times....a win/win I believe...
SteveT
Old Jul 13, 2012, 09:54 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
SteveT
I think you'll be happier! My batts are at the firewall, so I'm really happy that I like the way she's flying now with the current CG.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jul 14, 2012, 02:59 AM
rcdrum is offline
Find More Posts by rcdrum
Team 3DHS
rcdrum's Avatar
USA, CA, Garden Grove
Joined Feb 2004
A little fun in the haze with the 74 Edge
RC
rcdrum is offline Find More Posts by rcdrum
Old Jul 14, 2012, 03:05 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Great job!! And I saw that same haze today in San Jose, CA.!!!!
SteveT
Old Jul 14, 2012, 03:38 AM
rcdrum is offline
Team 3DHS
rcdrum's Avatar
Joined Feb 2004
Yup, weird getting rain in July.
RC
Old Jul 14, 2012, 03:56 AM
3d flippin
Joined Jan 2012
ok gunna run the life 3200mah just for security should be more then enough
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 11:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 03:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 02:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 11:13 PM
