Old Jul 08, 2012, 10:56 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by FIXXIN2FLY View Post
How about an Illinois Huckfest? Maybe somewhere near Chicago?
I like the idea of that even though I'm in Texas.... My family is up there and it would be a good way to expose them to the hobby
Park_aviator is offline Find More Posts by Park_aviator
Old Jul 08, 2012, 11:39 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Originally Posted by SteveT. View Post
If you own, or have access to a drill press, and can find a machine shop supply in that little "one horse town" you live in, buy a counterbore in the correct size, You can buy them in various sizes with a pilot that will guide the counterbore. this is the best way there is to drill out props..
You can see what I am talking about here...
SteveT
Thanks Steve, I'll take a look. The specialty place I know of is called McFadden-Dale and they seem to have everything... except a location close to my house!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jul 09, 2012, 01:31 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Yeah....never fails, I have to drive about ten miles to get to a machine shop supply house,,,and then are are a few of them in that area...
But...from their website, it looks like they carry machine shop supplies, so, they should carry counterbores...
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Jul 09, 2012, 10:37 AM
SnowDog1974 is offline
Find More Posts by SnowDog1974
SnowDog1974's Avatar
United States, IL, Crystal Lake
Joined Jan 2009
Originally Posted by gapple12 View Post
Oh, the one I got was one of the prototypes, Ive never seen this scheme. Anyone seen this one before ?
Collectors item for sure...looks great too!
The Midwest FLI in Cape Girardeau is as close to Chicago as we are likely to get...it was only 6 hours, and for you maybe a bit less since you could just shoot down I39 to I55.
It was a good location as it brought pilots from all over the midwest and even a bit more
You should plan on going next year; maybe we can have a caravan!
SnowDog1974 is offline Find More Posts by SnowDog1974
Old Jul 10, 2012, 08:34 AM
Capt. Roll is offline
Find More Posts by Capt. Roll
Capt. Roll's Avatar
United States, TX, Fort Worth
Joined Dec 2010
Rear Exhaust Engines
I searched the thread, didn't find anything.
How will the new rear exhaust 35cc gas engines (DLE and PTE) work for this ARF?
Mainly:
1. Fitting under the cowl......I'm sure there will need to be a few cuts on the bottom for the exhaust tubes and for some cooling.
2. Any effect on CG? Seems like the rear exhaust engines use motor mount stand-offs 10 to 15 mm longer than the side exhaust engines which pushes the prop hub out.
Capt. Roll is offline Find More Posts by Capt. Roll
Old Jul 10, 2012, 09:45 AM
gapple12 is offline
Find More Posts by gapple12
gapple12's Avatar
Joined May 2009
OK, BEC or 2s lipo to the RX for HV servos on this plane ? Cant decide......
gapple12 is offline Find More Posts by gapple12
Old Jul 10, 2012, 09:50 AM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
I'm using BEC only with 7955 servos all the way around... No issue so far...
hosam is offline Find More Posts by hosam
Old Jul 10, 2012, 09:59 AM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Are you running HV to them ? I'm just wondering if I will get better servo power from the Lipo then the BEC on 7.4V.
Old Jul 10, 2012, 10:12 AM
hosam is offline
hosam's Avatar
Joined Nov 2004
My BEC is set for 7.4 volt output...
Old Jul 10, 2012, 10:56 AM
skippy78 is offline
Find More Posts by skippy78
skippy78's Avatar
USA, VA, Narrows
Joined Mar 2009
You will get a more consistent voltage with the bec. Plus it I'd one less battery to charge.
skippy78 is offline Find More Posts by skippy78
Old Jul 10, 2012, 11:03 AM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Interesting, just had a guy tell me on another forum that he gets brownouts on his servos running 7.4 when he does hard 3d manuvers with his BEC, he switched to a RX lipo and problem went away.
Old Jul 10, 2012, 11:59 AM
Joined Nov 2010
I think the "c" rating on most lipos is higher than the majority of becs out there...
Old Jul 10, 2012, 02:17 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
which BEC?...
also true.
separate Rx pack does mean fewer moving parts. That said, I have some standard voltage servos on my 72 and running a separate pack through a CCBEC-Pro for power... running well.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jul 10, 2012, 02:53 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
Mainly:
Well with the PTE you should be able to carry your plane home in a paper bag
kerwin50 is offline Find More Posts by kerwin50
Old Jul 10, 2012, 03:09 PM
gapple12 is offline
gapple12's Avatar
Joined May 2009
Originally Posted by theKM View Post
which BEC?...
also true.
I have the Castle Pro BEC, not sure what he had that was giving him issues.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
