Old Jun 16, 2012, 09:26 AM
SportFlyer2 is offline
Find More Posts by SportFlyer2
United States, TX, Palacios
Joined Feb 2009
Originally Posted by reelcoolfish View Post
Just curious, how the heck did you kill and A123 pack? I always though they were indestructible......
Nope...I had one go bad on me, it was an earlier Fromeco pack and they said that they didn't need balancing (no balance lead)...luckily I cycled the pack as it was sitting in the plane for awhile and that's when it killed over...all my other Fromeco A123's have either a balance lead or the balance board built in as they sell them...on the one with the balance lead it was off pretty good so I cycled it while balancing it and all is well so far...now I always balance charge it even though it requires me to pull it out of the plane each time...
SportFlyer2 is offline Find More Posts by SportFlyer2
Old Jun 16, 2012, 10:10 AM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
Don't know how but they are not indestructible... In each case I lost one cell...
hosam is offline Find More Posts by hosam
Old Jun 17, 2012, 08:48 PM
stormz is offline
Find More Posts by stormz
United States, NC, Clayton
Joined Feb 2011
I think I am going to love this plane, just got back after maiden her with 3 flights, all I can say is wow, this is my 1st gasser. Coming from the 48" edge to 74 gas took some getting use to, so I took it east today. only a click or 2 of trim was needed. going have some fun when the pucker factor gos away
stormz is offline Find More Posts by stormz
Old Jun 17, 2012, 11:12 PM
reelcoolfish is offline
Find More Posts by reelcoolfish
Joined Apr 2008
If you don't like to remove the battery to balance charge it, you can splice the balance wires with servo extension wire and soldier. Worked well for me.
I doubt you really need to balance charge it every vhsthr. I balance charge about 1 out of 5 times, and I have never killed and A123
I have run packs down to literally zero volts before (by accident), cycled them a four times, and they were came to 95% (plus) capacity on charge/discharge cycle within the second or third cycle.
"Everydayflier" is charging 3 cell packs straight off a lead-acid battery at like 20-30 amps gets a full charge in only a few minutes...claims to have hundreds of cycles (I believe him)
I can charge my receiver packs at the field in like 5-10 minutes at 10 amps, I don't even need to remember to charge them at home it is so fast.
In terms of bullet-proof, practical, receiver and ignition packs, A123s are the best IMO........I wish they could make them about 30% lighter so we could use them in our electrics!!!
reelcoolfish is offline Find More Posts by reelcoolfish
Old Jun 18, 2012, 12:30 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
74 got to wow the crowd at XFC during a noon flight.
jsmith285 is offline Find More Posts by jsmith285
Old Jun 19, 2012, 08:52 PM
hosam is offline
hosam's Avatar
Joined Nov 2004
Does any one have the stock sticker set they would like to sell? If yes, plz send me a PM.
Thanx
Hosam
Old Jun 20, 2012, 08:56 PM
stormz is offline
Joined Feb 2011
hey guys, what is a good throttle servo for my dle 30 ? I went with a jr ds821 but seems a little slow or it might be me not use to a gasser
thanks
Old Jun 20, 2012, 10:33 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
this is what I use for all my throttle servos, used it on a DLE 30, now its on a DA-150. Its fast enough, metal gears, high voltage and CHEAP
http://www.hitecrcd.com/products/dig...t/hs-5665.html
nebwake is offline Find More Posts by nebwake
Old Jun 21, 2012, 09:08 AM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
I use Hitec 7955 or 7940...neither is cheap like the 5665 though...but these are HV capable (not sure if the 5665 is or not.....never owned one).
Key items are FAST response and good centering for a gas throttle servo. And...for those that have never owned a gasser....there's usually a spring on the throttle to pull it closed if the linkage fails....I leave that spring ON the engine...which means the servo always pushes against a spring...this also helps with any "slop" in the linkage if there is any....but a good linkage that has NO slop and NO binding is very important too...
Bivens is offline Find More Posts by Bivens
Old Jun 21, 2012, 09:17 AM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
The Hitec 5665MH works perfectly on HV. All of my 50cc and 100cc planes have the 5665 on the throttle. I have probably 800 flights on the one in the 104.
joesmith285 is offline Find More Posts by joesmith285
Old Jun 21, 2012, 01:47 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Cool. Nice to know! I suppose I just found myself a new "NEXT" throttle servo...they are cheaper than 7940's or 55's.
Old Jun 21, 2012, 08:40 PM
stormz is offline
Joined Feb 2011
thx for the info guys
Old Jun 23, 2012, 07:52 AM
RobT01 is offline
Find More Posts by RobT01
United States, NY, Syosset
Joined Jun 2012
I see people talking about the Xoar and Flacon props. Anyone fly both who can compare? Planning in running the A60-6xs.
Also is Joe Smith still flying the 21x10 over the 20x10? I see a lot of people running the 20 and wondering why he went with the 21.
Thank you!
RobT01 is offline Find More Posts by RobT01
Old Jun 23, 2012, 10:14 AM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Thank you!
Yes, Joe flies the 21X10...as to reason why, I would think that it works best for his flying style...YMMV...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jun 24, 2012, 01:03 AM
Zimm98 is offline
Find More Posts by Zimm98
Zimm98's Avatar
USA, SD, Rapid City
Well the Edge treated me well today. I placed third in the black hills huckfest 3d throw down. Great flying plane and the authority made it super violent. Its fun to have a 30 cc that can play with the big boys.
Zimm98 is offline Find More Posts by Zimm98
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
