Old Apr 24, 2012, 09:03 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Good write up SteveT!
And nice tip GP
Here's avid that helps too.
hinges.mpg (12 min 35 sec)
jsmith285 is offline Find More Posts by jsmith285
Old Apr 24, 2012, 10:00 AM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Thanks so much Steve, GP and Joe's Dad for all the advice!!!
What kind of glue do you use on the joiner GP?
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Apr 24, 2012, 10:10 AM
ipsmotors is online now
Find More Posts by ipsmotors
3DHS Junkie
United States, CA, Fullerton
Joined Nov 2007
Gorilla or similar give the most working time.
Here are the build videos from the prototype 70" Slick. The hinge install hasn't changed. The end of video #2 and the begining of #3 show the elevator/rudder install.
I've got new videos in the works for 71/72/74" planes
3D Hobby Shop 70" AJ Slick Build Video #2 (6 min 44 sec)
3D Hobby Shop 70" AJ Slick Build Video #3 (7 min 15 sec)
ipsmotors is online now Find More Posts by ipsmotors
Old Apr 24, 2012, 12:55 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
That is a great idea, I will have to do that for sure on my next small airframe build! it seems the counterbalances are never perfect and you always have a small difference between the two. Not that it seems to matter in flight, I am just a perfectionist
One thing that I do different from the 3DHS manuals is that I do the elevator before the rudder. This allows me to clamp the two elevator halves together while the joiner glue drys. I use a long piece of wood on the top and bottom of the elevator halves and clamp them together for a proper alignment.
Also, don't use CA on the joiner as the manuals (used to?) suggest. One of the most common problems that I read about on here is misaligned elevator halves. Using a glue that gives you time to work, and clamping the halves together while it drys will give you a better chance at getting it right the first time.
nebwake is offline Find More Posts by nebwake
Old Apr 24, 2012, 02:14 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Thanks Greg....
And your suggestion is great too...I just suggested doing the rudder first as it is the easier of the two jobs, but doing the rudder second does give you the opportunity to clamp them together, which is definitely a good thing.
And, as noted for small planes, I have used "Slo-Zap", but I wouldn't for a plane this size at all...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 24, 2012, 05:45 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
I use Gorilla glue on all my joiners to give me working time and to fill in all the spaces. Use a q-tip to get everything moist with water first to get maximum expansion. I use blue painters tape to secure and align the counter balance to the stab on both sides while it is drying. Never had a problem with them being misaligned doing it that way. I do the elevator first too so i can assure both sides are lined up with the rudder out of the way. Rudder is easier to do anyways.
lammbn is offline Find More Posts by lammbn
Old Apr 24, 2012, 05:52 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Originally Posted by lammbn View Post
I use Gorilla glue on all my joiners to give me working time and to fill in all the spaces. I use blue painters tape to secure and align the counter balance to the stab on both sides while it is drying. Never had a problem with them being misaligned doing it that way. I do the elevator first too so i can assure both sides are lined up with the rudder out of the way. Rudder is easier to do anyways.
Though I heartily agree with you guys....another reason I do the rudder first, is that unlike what the instructions call for. I install the stab next to last, and the landing gear last. I like to be able to do all the interior stuff (I.E. rudder servo, receiver, motor.ESC etc..) before installing the stab and gear, so that I can lay the fuselage on it's side or whatever I want to do without having the parts that stick way out, in the way...This of course is just a personal preference, but it sure makes things a lot easier....and...as noted, just using some blue painters tape on the balance tabs on the elevator will keep the elevators aligned unless there is some gross problem, which would need to be corrected anyway....
SteveT
Old Apr 24, 2012, 08:37 PM
lammbn is offline
Hooked on 3DHS
lammbn's Avatar
Joined Nov 2009
I do things similar to that for the same reason. i do the the entire plane up front first, then elevator, LG/tail wheel, and rudder last. it is much easier to do as much as you can before you do the tail.
Old Apr 24, 2012, 09:56 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
Hey guys... check this out...
Real Flight Plane....
THEEEEE 3DHS 74" EDGE in Silver & White !
by me... I found it hard on a edge so its the same color on a extra 330L-DC...!
What do you think?!!!
Here is the Link to down load it!:
http://www.knifeedge.com/forums/down...=file&id=16636
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Apr 24, 2012, 10:52 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
I like Gorrila Glue for it's gap filling properties. You have to be able to watch it for about an hour though, and keep cleaning away the excess. It can also push things apart when it expands, so you really have to watch it.
I've used epoxy with great results though. It's nice that you can just leave it while it dries.
G.P. is offline Find More Posts by G.P.
Old Apr 24, 2012, 11:31 PM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
Good looking plane, now I've gotta upgrade from 4.5 to 6. Thanks alot....
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Apr 25, 2012, 07:53 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Me to but I tape everything and not overuse the GG. I also don't add any water. This just makes it expand more and in this small area you do n't need any more expansion than normal. I just let it expand and chip it off when it drys.
robj is offline Find More Posts by robj
Old Apr 25, 2012, 10:30 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
NICE!!!!!
keithy4129 is offline Find More Posts by keithy4129
Old Apr 25, 2012, 01:37 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Lets see....we have radio wars, motor brand wars, servo wars, connector wars...and now "glue wars"...
Just kidding discussion of ways to do things is good
SteveT
Old Apr 25, 2012, 11:13 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Can you do the red/white scheme for me also...??
Excellent work on this one!
Bivens is offline Find More Posts by Bivens
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
