Old Apr 12, 2012, 06:51 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Originally Posted by SteveTtoooo View Post
I have found that these Dubro crimps are just a bit larger than the 4-40 hole, but the I.D. is perfect for 2mm bolts. So... I drill the arms to accept the crimps, and insert them into the arms, cut them to the thickness of the arms, and insert my 2mm bolts...works perfectly!!
SteveT
not a shabby idea
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 12, 2012, 06:58 PM
lammbn is offline
Find More Posts by lammbn
Hooked on 3DHS
lammbn's Avatar
United States, ID, Boise
Joined Nov 2009
Originally Posted by Bivens View Post
I'd keep a CLOSE eye on this...I predict it won't stay slop-free for too many flights. For sure I'd plan on trying to find the right ball-links for the proper bolts before too long. Let us know how it performs...particularly if you see a little slop start developing or if you find that you have to tighten regularly.....Just curious. Enjoy.
Nice arms.
I have been checking them very often. Both my 71 and 74 have links setup this way. The 71 has had 30+ flights setup like that. The ball link is rounded just enough to center the bolt in the servo arm hole. They still are nice and tight. The problem i was finding was that i couldnt find any tubing that didnt require me drilling out the servo arm to a larger diameter than the 2mm nut so it wouldnt hold anything but the spacer. I already had 3mm servo arms but could not find 3mm ball links locally. I probably should order some but its hard to when they are working how they are now.
lammbn is offline Find More Posts by lammbn
Old Apr 12, 2012, 08:40 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by theKM View Post
not a shabby idea
Thank you...it has worked well for me...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 12, 2012, 10:01 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
TheKM,
I'm doing the same thing here and found the same thing lammbn did. I just took a quick look and I think on one I drilled another hole. But on the ailerons it has the larger hole but the ball fits perfectly in the hole just a bit and still has plenty of free movement. . And since the brass ball doesn't move(either set up), it should be good to go.
Looks like I need to adjust the angle of the aileron, but it works fine and I'm having to much fun flying this plane!!
robj is offline Find More Posts by robj
Old Apr 13, 2012, 03:22 AM
Elios000 is online now
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
oh yea about the DS610 servos they are the same as the Savox 1258TG
also the DS650 is the same as the Savox 1290MG
Savox OEMs for Align the new Align HV servos are the same as the Savox HVs as well
and they are all very good servos
im running the Savox 1258s on the cyclic of my 6HV and a 1290 on the tail
Elios000 is online now Find More Posts by Elios000
Old Apr 13, 2012, 07:46 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
I know this plane has been called tail heavy a few times, so I'm probably wasting time worrying about such things, BUT, do you think 2 of these batteries will be too heavy?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I building my plane with the Motrolfly 5320 motor, CC BEC Pro, and ZTW 120HV ESC (135g)
Thanks for the advice,
Gary
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Apr 13, 2012, 07:51 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Gary
I don't think they would be, I am using two 4S 45C 3800mAH packs in my 72" Extra, and I had to add three ounces of lead to get it to balance...but of course they are two different planes, so this is just conjecture on my part...
SteveT
Old Apr 13, 2012, 09:26 PM
PinkYakRC is offline
Find More Posts by PinkYakRC
Yeeah buddy!
PinkYakRC's Avatar
Northern Colorado
Joined May 2010
I have 8s, 5000mah in mine sometimes....when I want to go really fast.
PinkYakRC is offline Find More Posts by PinkYakRC
Old Apr 13, 2012, 10:45 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
thats weird,Randidly has a 4325 on 6s in one of these,I flew it in Fla a cple weeks ago and it didn't feel tail heavy to me..He does have his flight battery up front tho.
Edges I think can fool ya in how easy they go into the stall into thinking they are tail heavy?
Manta1 is offline Find More Posts by Manta1
Old Apr 14, 2012, 12:15 AM
lb.man is offline
Find More Posts by lb.man
KBDD TEAM PILOT
lb.man's Avatar
United States, CA, Shasta Lake
Joined Sep 2009
Gary
5320 cc ice 100 cc bec pro 2 4s 4000 sky lipo's balanced at 5 1/8, batteries almost touching firewall.
lb.man is offline Find More Posts by lb.man
Old Apr 14, 2012, 10:35 AM
-= GYRO =-'s Avatar
Joined Nov 2010
Thanks for the info! I feel better about getting some of those batteries
Old Apr 14, 2012, 10:41 AM
-= GYRO =-'s Avatar
Joined Nov 2010
Originally Posted by robj View Post
I have those on my 70. Work fine. Just a lot slower. 2 planes I have the 1258tg/ds610 on the rudder/elevator only. And check out the Align ds610 on Ebay. $55 each, same servo.
Rob,
I spent quite a bit of time hunting, and found 4 of the DS610 servos on Helifreak for $175 total shipped. One was brand new & sealed, the other 3 had less than 20 flights. Much cheaper than spending $240 on new 1258tg. Thanks very much for the advice!
Gary
Old Apr 14, 2012, 10:21 PM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
First time home in 6 weeks and get to pull the cob webs off mine. Is it just me or did it grow... Steve Tooo, I'll be in your neck of the woods in about two weeks or so. I'll have to bring my heli out to Tomcats.
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Apr 14, 2012, 11:36 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
By all means.... I'll PM you my tele numbers....
SteveT
Old Apr 15, 2012, 08:58 AM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
I have to resist the urge to get the DA35 when it comes out and replacing my motrofly…. maybe not
aerosheldon is offline Find More Posts by aerosheldon
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
