Old Apr 08, 2012, 10:27 AM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
oh and Happy Easter to all of you! Now get back to the family stuff and we will do RC stuff the other 364 days of the year...oops 355... reserved 10 for Holidays
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Apr 08, 2012, 11:34 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
correction....365 days. Leap year this year so one extra day of flying! what a nice weekend around here this weekend. I'm about to go fly in the front yard...again!
robj is offline Find More Posts by robj
Old Apr 08, 2012, 03:08 PM
Joined Dec 2005
Ordered the CCP Ice 100 & the programming plug.
Old Apr 08, 2012, 09:54 PM
motojoe996 is offline
Find More Posts by motojoe996
motojoe996's Avatar
Panama City, Fl
Joined Jan 2009
For those of you who are using the Omega 3" carbon spinner on your gassers, what size and where can I find the spinner bolt?
I have the spinner but I haven't been able to source a bolt that'll work.
BTW, flew 7 more flights on Saturday. Almost gone through my first gallon of gas. This airframe and being my first gasser is a lot of fun and the motor sounds and runs great.
I also broke loose a cowl attach point and lost a cowl screw and washer. The screws are 2-56 xsomething length right? I gotta find some spares and some nylon or rubber washers.
Thanks for help,
Joe
motojoe996 is offline Find More Posts by motojoe996
Old Apr 09, 2012, 02:07 AM
Elios000 is offline
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
wondering is there any way to get the DLE30 totally under the cowling?
Elios000 is offline Find More Posts by Elios000
Old Apr 09, 2012, 02:08 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Not that I am aware of...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Apr 09, 2012, 08:50 AM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
Fastenal might have one that works,its tough to find a 4mm x 75 or longer. I had to use a long nut with a stud to extend the mounting hole on the engine, then I used a 4mm x 65 cap head bolt. Its a little rigged... I'm sure you could find one online somewhere though
Thanks for help,
Joe
nebwake is offline Find More Posts by nebwake
Old Apr 09, 2012, 09:11 AM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Thanks for help,
Joe
Fastenal for my spinner bolts...special order, but arrive the next day...not expensive...we have a local Fastenal store in Knoxville so i just stop by...not sure where to order from online.
For the cowl bolts...I just use a standard 4/40 bolt with blind nut installed into the wood tab. I use a standard steel washer...but I put a slice (small donut) of regular GLOW fuel tubing (silicone) on the bolt so it's compressed by the washer. I use this on ALL of my giant scale planes...the bolts NEVER back off and it's something I could do without having to find and purchase rubber-backed washers.
No.
Bivens is offline Find More Posts by Bivens
Old Apr 09, 2012, 09:59 AM
motojoe996's Avatar
Panama City, Fl
Joined Jan 2009
Thanks for the replies.
4-40 is not the original size for the cowl screws right? I already have the original blind nuts installed. Good idea on using fuel tubing!
I'll check out fastenal, but a 4mm x 75 should do, eh?
Last edited by motojoe996; Apr 09, 2012 at 11:04 AM. Reason: edited for english. big thumbs...
Old Apr 09, 2012, 01:11 PM
racerxky is offline
Find More Posts by racerxky
Watts is where its at!
racerxky's Avatar
United States, WA, Seattle
@motojoe996 My kit appears to be all metric. M2 & M3 fasteners. Extra blind nuts and screws are in one of the hardware bags.
You want to track down some #4 "bonded washers". McMaster Carr doesn't carry that size so you have to go to a specialty supplier:
http://rtlfasteners.com/RC/bw4.html
http://www.microfasteners.com/catalo...ts/WASFWRB.cfm
racerxky is offline Find More Posts by racerxky
Old Apr 09, 2012, 01:23 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Those washers are also called "sealing" washers.....
SteveT
Old Apr 09, 2012, 01:32 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the closest you could get is with a canister and a header... put the cylinder to one side... you'll have to put a hole in the side for the plug and maybe the very top of the head, but not much will be sticking out if at all. also note, once you've fully enclosed the engine, cooling airflow then becomes an issue. the way we have ours mounted there's no extra concern for the cooling...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Apr 09, 2012, 04:05 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
GT 33 runs GREAT. 5 more flights today....total of 6 now with a reasonable tune on it....it is starting to rip the 18x8 prop....over 8000rpm. I'm able to lean the low end a little too...runs so nice. VERY good throttle response....very clean and consistent idle.
Anybody want to buy my DLE that has 40 flights on it? I have the omega can also. $225 for the DLE...throw in $40 more if you want the can. I've also got two props drilled and balanced for the DLE....Vess 19a and 20a.....$15 each. Of course these prices are all shipped or delivered to SEFF or NALL. PM if interested. I did use the DLE standoffs for mounting the OS...so you won't get those...
DLE ran good but not great. It hurt my feelings to chunk down the cash for the OS but....in the end I've come to the same conclusion here that I did on the DLE111 vs. DA120 game.....I just have really high standards for engine performance and that costs more $$....simple. I'm happy with the OS....for sure.
That being said, the DLE30 is not bad either....it just never gave me the confidence to take it to a fly in and have Wamsy or Joe or KM wring it out on the deck....but I don't think its fully broken in yet either as it was still blowing black slime.
Old Apr 09, 2012, 05:41 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
I made my DLE30 fit inside the cowling by selling it to a local club member for exactly enough $$$ to buy a Motrolfly 5320.
Several problems solved, including cutting holes in the beautiful cowling.
G.P. is offline Find More Posts by G.P.
Old Apr 09, 2012, 06:29 PM
Elios000 is offline
Elios000's Avatar
Joined Jul 2010
yea im really thinking of going e power but i REALLY would love to have smoke
and i have every thing for epower
eh bday is coming up see what cash i get + what i can sell the engine and air frame i have now for
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
