Old Mar 05, 2012, 10:17 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Only one problem....no servos or motor...unless I want to use a E-flite Power 110...which actually would probably fly the plane ok on 8S... But at least I have the plane on the way!!
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Mar 05, 2012, 10:45 PM
-= GYRO =- is online now
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
SteveT
I'm kinda in the same boat, although I got a NIB 4325-380 and cash for my 59" slick, so I've got a head start.
-= GYRO =- is online now Find More Posts by -= GYRO =-
Old Mar 05, 2012, 11:08 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Well... I used to fly a 10 pound Hangar 9 "Frenzy 100" with no problems with that motor, so I could use it for a while anyway... I do have a good ESC for it though...
SteveT
Old Mar 05, 2012, 11:54 PM
G.P. is offline
Find More Posts by G.P.
iumop ap!sdn w,I
G.P.'s Avatar
Canada, AB
Joined May 2005
Originally Posted by slickg66 View Post
Yes. They charge a flat rate for shipping, and were a little snobby about it. I'm one state away from AZ, and they charged me the same as if it was going to Maine.
I would have preferred to buy from Rob or the 3dhs warehouse. Just my preference.
You're lucky if that's all you had to deal with. "Snobby" would be a polite way of saying what I had to deal with when one of my shippments from them got damaged.
G.P. is offline Find More Posts by G.P.
Old Mar 06, 2012, 07:53 AM
heritageflyer is offline
Find More Posts by heritageflyer
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
YEEEHAAAAA!! Got a red one!! Finally!!
SteveT
Was wondering if you were going to jump on that!
heritageflyer is offline Find More Posts by heritageflyer
Old Mar 06, 2012, 10:18 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by Carbonfootprint View Post
Hmm, two pages of micro servos....musta made a wrong turn
Nah your posts per page must be set to 8-9. Set it to 100 posts per page and it's just a teeny weeny part of a page...
robj is offline Find More Posts by robj
Old Mar 06, 2012, 10:19 AM
robj is offline
robj's Avatar
Joined Nov 2008
Originally Posted by Irg View Post
he means wiggle room for when he wiggles that arm into a 50cc plane.
If it's an Edge...that's a roger!
Old Mar 06, 2012, 09:49 PM
skypan12 is offline
Find More Posts by skypan12
Northern IL
Joined Sep 2006
WHOOO Big Brown truck dropped off the 540 in Red and the A60-5S today, motor is mounted and working on getting the ESC wired up. I should have the Mejzlic 20X10 here fri or so and will have some numbers with this 8S set upby first of the week
skypan12 is offline Find More Posts by skypan12
Old Mar 06, 2012, 09:57 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
From what I have been told by the guys at AeroModel, (Mike, Kyle, and Sean [the owner]) a 20X10 is too much prop for an A60-6XS on 8S.... I am using a 20X10 on 6S using that motor...
SteveT
Old Mar 06, 2012, 10:07 PM
skypan12 is offline
Northern IL
Joined Sep 2006
SteveT
I have the A60-5S 28 pole
Old Mar 06, 2012, 10:22 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Oooops...better check my glasses again....
SteveT
Old Mar 06, 2012, 10:29 PM
skypan12 is offline
Northern IL
Joined Sep 2006
SteveT
That's ok Steve I am starting to catch my self more than I want to too any way I am hoping for about 2800watt out of this set up
Old Mar 07, 2012, 09:10 PM
nebwake is offline
Find More Posts by nebwake
nebwake's Avatar
United States, NE, Lincoln
Joined Mar 2011
I posted this in fly low also but thought id dump it in here also... "has anyone plugged 2x 2S lipos (unregulated servos) straight into a spectrum RX (I'm using AR8000)? Im looking at running 2x 1500 ish mah lipos for my 74" with a DLE 30 and a Wike IBEF. I assume this is possible and I would like some redundancy to the power system. so if anyone has ran a similar system (or a better idea) I would appreciate any feedback. Thanks!"
nebwake is offline Find More Posts by nebwake
Old Mar 07, 2012, 09:24 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
I am running two 2S 25C 2700mAH Thunder Power pack directly into my AR9100. As far as I know you "should" be able plug paralled lipos directly into the AR8000. To find out for sure call Horizon Hobby Tech support...if they are backed up, leave your number, they "will" call you back...
SteveT
Old Mar 07, 2012, 09:30 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
SteveT
Niiiiiiiiiice Steve!
Have you decided on servos yet?? If not, go with the Savox TG's. I am super happy with mine. Lightning fast, center well, and they make me feel "connected" to the Edge.
Buzzed is offline Find More Posts by Buzzed
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
