Old Mar 05, 2012, 09:16 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
Originally Posted by robj View Post
I got the metal ones off ebay, Futaba spline!!! I have 1.25" everywhere and a bling 3" on the pull-pull. I don't use all the 3" but it's there for wiggle room.
he means wiggle room for when he wiggles that arm into a 50cc plane.
Irg is offline Find More Posts by Irg
Old Mar 05, 2012, 09:35 AM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
Do you know if this applies to all of the Savox servos, including the smaller SH-0255? I've been looking for a longer arm for those.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Mar 05, 2012, 09:49 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Yes they are Futaba spline, but they are a 21 tooth, unlike the regular 25 tooth spline. 21 is almost impossible to find, I've looked for days. Best thing to do is use the 3DHS phonelic arms or some carbon fiber ones like the ones from RCFoam.
Eagle34 is offline Find More Posts by Eagle34
Old Mar 05, 2012, 10:04 AM
-= GYRO =-'s Avatar
Joined Nov 2010
What about these? http://www.toysonics.com/futaba-fsh6...3-4-fsh63.html
Old Mar 05, 2012, 10:08 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
I use the align ds610 same as the savox...but the larger ones. Don't know that model mentioned...
Where I got mine...these I cut down a bit.
http://www.ebay.com/itm/NEW-CNC-Alum...item3cb85f9bf1
This would work but is a bit longer, mine is 3" but I don't see it on ebay anymore. I think I'm only using 2.5-2.75" anyway.
http://www.ebay.com/itm/Purple-CNC-A...item3cbb63c473
robj is offline Find More Posts by robj
Old Mar 05, 2012, 10:18 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Those may work (they are the right spline) but they don't say what the length of them are. I was told the stock 0255 arms were a bit flimsy, the only down side to them. I have a spare set of the 3DHS arms that I am going to use with mine.
Old Mar 05, 2012, 10:21 AM
-= GYRO =-'s Avatar
Joined Nov 2010
You might have missed it in the description:
Horn Length, long side: 1.60" (40mm)
Horn Length, short side: .79" (20mm)
Old Mar 05, 2012, 10:22 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Rob the savox SH-0255 is the size of the HS65, but with a bit more weight (15gr) and almost the same specs as the HS-85. I'm gonna be using them in my 51" Slick.
Old Mar 05, 2012, 10:25 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Yep sure did. Was cross referencing models to make sure the splines were right. Those might work nicely. Unsure about the strength, but aren't we always, till somebody tries them out. Good job finding those.
Old Mar 05, 2012, 10:27 AM
robj is offline
robj's Avatar
Joined Nov 2008
hmm, how much? 85's pretty pricey.
Old Mar 05, 2012, 10:36 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Yea I was looking at 85's or 5085's, almost the same price. Got the SH-0255's from Amain for $33 ea. so not that much difference. Plus I wanted to try them. Got the DS-610s for my 74" Egde from a guy at the field ($200 for 4 ea.)
Old Mar 05, 2012, 11:05 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
I've got a pair of the 0255's in an EF 48" Edge. They are nice so far. Hold up well, and very strong. I like 'em. they might just replace all my HS-65's eventually...
the power of the hs-85's in a servo the size of an hs-65 and with only a few gram weight penalty.
ryan_m is offline Find More Posts by ryan_m
Old Mar 05, 2012, 11:12 AM
robj is offline
robj's Avatar
Joined Nov 2008
Are they twice as fast like the ds610?
Old Mar 05, 2012, 11:41 AM
Eagle34 is offline
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
I picked up 5 of them, 4 for the 51" Slick and one for the rudder on my Buck.5 Edge.
Old Mar 05, 2012, 11:57 AM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
The 65 is .11 at 6 volts with 31 torque. The 0255 is .13 at 6 volts with 54 torque.
6L6Amp is offline Find More Posts by 6L6Amp
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
