Old Nov 11, 2011, 06:25 PM
Bivens is offline
Find More Posts by Bivens
Team 3DHS / Team JR
Bivens's Avatar
United States, TN, Knoxville
Joined Apr 2010
Wow...my edge is already in ktown....delivery on Monday....
Bivens is offline Find More Posts by Bivens
Old Nov 11, 2011, 07:05 PM
Komet ME163 is offline
Find More Posts by Komet ME163
Komet ME163's Avatar
E TN
Joined Jan 2003
hey Mike how did you get yours moved up to Mon? Mine origanally showed Mon and now tues? We are less than 10 miles apart and the distrubution center is in between us. You got pull with UPS
Bill
Komet ME163 is offline Find More Posts by Komet ME163
Old Nov 11, 2011, 09:10 PM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Mine is updated to wednesday now. I'm farther away than you guys.
Oh well.
Cory
RC4x4 is offline Find More Posts by RC4x4
Old Nov 11, 2011, 11:42 PM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Just good luck I guess...we will see if it holds....anyway, you aren't building yours now anyway, right?
DLE30 is now ready for install with standoffs, throttle arm, choke linkage, and header on it.....for those of you new to gas, here are a few photos of the setup.....the choke arm and rod are ALL homemade, the throttle arm is stock DLE, and the ball link is 3dhs.....header is 3DHS omega....can is also.....3DHS sells the header and can as a set with clamps.
Also, you may notice that I solder the hole in the choke plate closed...this is a trick I learned from jclark to help a 30cc pull fuel up a little better under choke when priming a cold motor. Nothing fancy, just regular solder and iron after shining up the brass around the hole by lightly scraping it with the tip of a hobby knife so the solder sticks well.
I will also be running the 3DHS omega carbon spinner...it comes drilled for the DLE and cut for a XOAR prop!! I will have to trim a little for the VESS as they are thicker than XOAR...not much...you will need to supply your own spinner bolt....I get mine at the local FASTENAL store.
I can't wait to fly this thing.....I'm going to balance the prop and get all the radio gear setup.....waiting on the brown truck now...
Old Nov 11, 2011, 11:56 PM
grubby is offline
Find More Posts by grubby
grubby's Avatar
Denver Colorado
Joined Jan 2010
Originally Posted by theKM View Post
8S 4400's would be perfect.
I ended up getting 2 4S4400's and 2 4S5000's
grubby is offline Find More Posts by grubby
Old Nov 12, 2011, 12:15 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
What motor, prop, speed control you using? What brand of packs?
Cory
Old Nov 12, 2011, 12:17 AM
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Those little 30's rip! My 72'' 330 is a blast with that little motor.
Cory
Old Nov 12, 2011, 01:20 AM
Bivens is offline
Team 3DHS / Team JR
Bivens's Avatar
Joined Apr 2010
Spinner trimmed for VESS and balanced....3 props balanced....XOAR 20x6 laminated, Vess 19A and 20A..... I got all these things I hate out of the way so I can build fast.....choke, tank, balancing.....blah..
Old Nov 12, 2011, 03:56 AM
grubby is offline
grubby's Avatar
Denver Colorado
Joined Jan 2010
Cory
Im going to run the Motrolfly 4325-310. Prop is undecided maybe an 18a or 19a Vess. Im really liking the Vess props.
Batteries are Sky Lipo 20c's. I have run their 20c's in an 8S plane before and they worked great!
Old Nov 12, 2011, 06:30 AM
E TN
Joined Jan 2003
Wow you've been busy, and looking good. The choke lever setup and arms look nice. Yea I have to order motor and servos, am anxious to see your setup, so I have a chinese blueprint. Hope you take a few pics during your build. Can't wait to see her flying.
Bill
Old Nov 12, 2011, 10:39 AM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
Have you ever compared the Vess props against the Xoar's in efficency?
gabrielisrael is offline Find More Posts by gabrielisrael
RC4x4 is offline
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Vess doesn't make a electric prop though?
I would use a Xoar electric prop.
Cory
Old Nov 12, 2011, 01:23 PM
grubby is offline
grubby's Avatar
Denver Colorado
Joined Jan 2010
Cory
Vess does make one up to an 18".
Their 19" props and above are gas.
Old Nov 12, 2011, 01:25 PM
grubby is offline
grubby's Avatar
Denver Colorado
Joined Jan 2010
I have not done actual tests.
But when I ran them both on my 50cc the Vess always worked better.
I have not run any Vess prop smaller then a 22". When I ran a Xoar 23x8 compared to a Vess 23A the Vess def performed a lot better in the air.
Old Nov 12, 2011, 01:30 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
i thought those were sport/glow props?
rcbirk21 is offline Find More Posts by rcbirk21
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 11:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 03:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 02:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 11:13 PM
