Old Jan 11, 2012, 10:36 AM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by yankphan View Post
OK so I went to maiden my edge...... powered her up, adjusted the INSANE throws.... goosed the throttle before flight with the plane held back.... taxi her around for a little bit... man my adrenaline is pumpin now !! SSSSSCCCCCCCCRRREEEEAAAATTTCCHHHHH !! The damn motor locked up..... took it apart to find the "round bracket type ring" that holds all the magnets in precise order I guess you can say..... start working its way back out of the can...started to rub on the motor half mounted to the firewall.... anyhow, I tapped it back in carefully... and used 30 minute epoxy all around including between all the magnets.... I think I did a pretty nice job on it.... will find out today.... but I did power up the motor last night and it seemed fine.... just want the epoxy to cure.... Did I use the right stuff ? I used a 30 minute epoxy.....never had to re-glue magnets before in my 4 years of flying !! I hope I dont need a new motor. 5 1/4" CG if im not mistaken ?? Don't want any surprises during the maiden... Thanks for your time everyone... and man does that pjn xoar WHITE prop w/red tips look sweet !!
Photos of that prop please!!!
Also, where did you buy it?
Thanks and have a blast with the maiden.
-Buzzed
Buzzed is offline Find More Posts by Buzzed
Old Jan 11, 2012, 11:13 AM
0gravity is offline
Find More Posts by 0gravity
A tale of two slickies
0gravity's Avatar
United States, IL, Chicago
Joined Feb 2010
So using the motrofly 4325-380. I did as you said Steve and used some debonder to get the backings off.
Then filled in the preexisting holes and cutout the pattern for the wire coming out of the back of the motor. I realized however that I did not necessarily need to do this because the motor will be on standoffs. Oh well. If I do choose to slide the wires through the box now I can.
So far getting the backings off was the hardest part. Tonight I'll get the motor on with 1/2" spacers plus some washers and we will see how we line up.
0gravity is offline Find More Posts by 0gravity
Old Jan 11, 2012, 11:36 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
-Buzzed
I think Espirit carries those white Xoars.
Eagle34 is offline Find More Posts by Eagle34
Old Jan 11, 2012, 11:53 AM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Thanks!
FireyFate is offline
Find More Posts by FireyFate
FireyFate's Avatar
USA, AZ, Surprise
Joined Apr 2010
Indeed they do.
http://www.espritmodel.com/xoar-prop...hite-pjmw.aspx
FireyFate is offline Find More Posts by FireyFate
Old Jan 11, 2012, 12:26 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by FireyFate View Post
Wow, double the price for paint? I painted mine myself, I like the black on the red plane. Red tips.
robj is offline Find More Posts by robj
Old Jan 11, 2012, 12:27 PM
robj is offline
robj's Avatar
Joined Nov 2008
Originally Posted by Fliprob17 View Post
at this size I would ditch the bullets and solder direct
At least, I use 4mm bullets but the Ice wires are about twice the size of A50. If I recall the A50 are still multi stranded but the strands are thicker.
Old Jan 11, 2012, 02:03 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Originally Posted by RCMC View Post
jhorton,
That isn't as complicated as it looks or seems. I will start with the most rounded top section first. Wet the balsa pretty good and test the bend in your hands. Pre-bending is good for the wood anyway. Always have a few extra pieces available as some pieces resist the bending and will break. Once this piece is in place the rest are just slightly bent sides and easy to install. The factory sometimes installs the turtle deck in one piece but they are set up for the process. In our case a joint is not a problem.
I'll have pictures in the next few night of this work. I need to repair the bulkheads tonight.
RCMC
Using common household ammonia will really help with bending balsa.....just saying...
SteveT
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jan 11, 2012, 02:58 PM
yankphan is offline
Find More Posts by yankphan
yankphan's Avatar
United States, FL, Cape Coral
Joined Jan 2011
Here's my edge...... still need to maiden it.... what is the best CG before I maiden it ? anyone !!
http://www.youtube.com/user/yankphan100?feature=mhee
yankphan is offline Find More Posts by yankphan
Old Jan 11, 2012, 03:02 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
4.5" - 5.25" from the root leading edge.
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jan 11, 2012, 03:03 PM
joesmith285 is offline
Find More Posts by joesmith285
Game on
joesmith285's Avatar
United States, IN, Fort Wayne
Joined Nov 2008
5 1/4" CG back from the leading edge of the wing is safe. For maiden, 5" would be even better.
joesmith285 is offline Find More Posts by joesmith285
Old Jan 11, 2012, 03:07 PM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
NICE! The white prop with the red tips looks killer on your Edge.
Vitter is offline Find More Posts by Vitter
Old Jan 11, 2012, 03:11 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Outstanding! Thanks for sharing and we can't wait to hear about the maiden.
-Buzzed
BTW, that prop is awesome! I'm getting one now.
Old Jan 11, 2012, 03:31 PM
yankphan is offline
yankphan's Avatar
Joined Jan 2011
It's a little pricey but man does it make the plane !!
-Buzzed
Old Jan 11, 2012, 03:32 PM
yankphan is offline
yankphan's Avatar
Joined Jan 2011
Hey thanks... I'll give the 5" a try ... looks like tomorrow for a maiden... a bit windy today !! I'll fly my precision aerobatics planes in winds today .... but not a maiden !
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
