Old Dec 28, 2011, 12:34 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
Thx guys. They must be for the cuffs
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Dec 28, 2011, 01:14 AM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Originally Posted by yankphan View Post
Ok so im almost finished with my build.... I need to get a bec.... What size 2s lipo or 3s lipo is everyone using and where do you place it ? How many flights canbe expected ? Any pic setups would be very helpful... Or please email some setup pics at. Azzonaples@yahoo.com
Im set up for electric power.
Here's what I run in my 71 Slick and 72 Extra 330SC. I just plug it into the receiver. Have never had a problem with A123 batteries.
http://www.bphobbies.com/view.asp?id...2&pid=C2126949
Or you could go with with this for around 4 flights without charging;
http://www.bphobbies.com/view.asp?id...2&pid=C2126944
Buzzed is offline Find More Posts by Buzzed
Old Dec 28, 2011, 02:21 AM
Epoxy & CA Investor
Joined May 2010
i'm using the 72 extra manual as a guide. Just noticed it doesn't cover anything related to the motor box installation. Can i use the 68 Velox manual? Velox manual says if using a short electric motor then install the motor box extension using M5 screws. I'm using a hacker a50-16L. So assuming i need to install the motor box extension? Also, what are M5 screws? Or should I just mount directly to the firewall and use extensions?
Old Dec 28, 2011, 02:48 AM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
The 72" Extra never used a motor box extension, though with the second version of it, you had to use really long extensions and bolts (the first ones that came out were designed to use the side carb, DLE30, the second version used the rear carb DLE30). I would assume yes, you need to install the extension as the main motor box is designed to mount a gas engine directly... (make sure you pay attention to the markings on it to put on the correct way)...Without the motor box extension, I would imagine you will need really "long" extensions and bolts...and...
M5 screws= five millimeter diameter screws....also seen as 5MM..
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Dec 28, 2011, 08:16 AM
yankphan is offline
Find More Posts by yankphan
yankphan's Avatar
United States, FL, Cape Coral
Joined Jan 2011
Please bere with me ! But do you need to install an extension wire with deans on rx or did you change out the plug on the 6.6v battery ? Maybe a phot of your setup please ? Azzonaples@yahoo.com Thanks for your help.
yankphan is offline Find More Posts by yankphan
Old Dec 28, 2011, 08:23 AM
ryan_m is offline
Find More Posts by ryan_m
doh!
ryan_m's Avatar
United States, AR, Little Rock
Joined May 2006
use the motor box extension.
See these pics, yours will be similar:
http://www.rcgroups.com/forums/attac...mentid=4429126
http://www.rcgroups.com/forums/attac...mentid=4442509
http://www.rcgroups.com/forums/attac...mentid=4447464
When mounting the motor box extension it appears that you have the choice of using blind nuts and the supplied bolts, or they also gave you regular nuts if you don't want to use the blind nuts. I did the blind nuts, and then used blue loctite on the bolts to secure them.
ryan_m is offline Find More Posts by ryan_m
Old Dec 28, 2011, 08:40 AM
hosam is offline
Find More Posts by hosam
hosam's Avatar
United States, MI, Livonia
Joined Nov 2004
okay, I have a question about BEC and radio batteries, why do some of you guys use both? the whole reason a BEC is used is to eliminate the the radio battery (a 2S or any battery that powers the Rx and servos)...
I flew my 68" Velox for an entire season (about 200 flights) with out a radio battery to power the servos/Rx and used a Castle Pro BEC. Power from the main flight pack (6S 5000mAh LiPo) powered the motor and the radio system. The BEC took care of getting the power needed to the servos and Rx
Am I missing something???????????
Cheers
Hosam
hosam is offline Find More Posts by hosam
Old Dec 28, 2011, 09:23 AM
RC4x4 is online now
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
You'll need to the extension box. Use the DLE30 template to mark the holes on the firewall for drilling and installing the extension box. Two ways to do it.
You can mount the blind nuts inside the fuselage motor box or the extension box. It's easier to put the blind nuts on the extension box and screw thew the box on from inside the fuselage. You need to remove wood from the triangle bracing if you install them inside the fuselage motor box. I did that, and can upload pic's later tonight. Put washers under the screws from which ever side you do. M5 is 5mm wide.
Cory
RC4x4 is online now Find More Posts by RC4x4
Old Dec 28, 2011, 09:28 AM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
Originally Posted by jhorton View Post
So i ran about 12 oz of gas through my DLE 30 today, closest I have come to flying my 74. The factory settings on the High and Low jets seem to work well. That said my HiTech 7955 servos are quite chatty and I did not expect so much noise from them. Can anyone tell me if this is a normal sound? attached a small clip with the noise in question. Also here is the first run of the DLE 30 with 1/8 turn on High Needle running 6300 RPM with the 20A prop
http://youtu.be/aKi9TtsM_zc http://youtu.be/9Gy502VYdck
I can't quite see with your engine vid, but make sure you are putting your wings on when you are running the engine. That way the vibrations won't be just confined to just the fuse, b/c the wings will dampen the vibes
joshet89 is offline Find More Posts by joshet89
Old Dec 28, 2011, 10:22 AM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
I did a little soldering on mine. But if you buy these, there is no need to. Just plug the JST connector directly into the receiver.
http://www.bphobbies.com/view.asp?id...F3954056&img=l
Old Dec 28, 2011, 10:37 AM
Epoxy & CA Investor
Joined May 2010
Cory, Ryan,
Thanks for your help. I'll have to look through my kit again, but i don't recall seeing a DLE 30 template. Does the kit come with the hardware to mount the extension box?
Old Dec 28, 2011, 12:37 PM
Epoxy & CA Investor
Joined May 2010
does this seem about the correct amount of gap you expect to see on the rudder?
Old Dec 28, 2011, 12:43 PM
Epoxy & CA Investor
Joined May 2010
buzzed -what would you say it the ideal way to go about charging one of those cheetah packs? All my charging equipment is only setup for Deans and PowerPoles.
Old Dec 28, 2011, 01:13 PM
Vitter is offline
Find More Posts by Vitter
Gas Monkey Vic
Vitter's Avatar
Snohomish, WA
Joined Jan 2005
Cheers
Hosam
People have to do what makes them comfortable but I'm with you. On all my 30cc size planes I run a CC BEC Pro powered from the main flight pack with no issues or added weight of an extra battery. Even if the ESC has a total melt down you still have power to the BEC to safely land the plane. Here are some photos of my BEC tied into the Deans plug of my ESC.
Vitter
Vitter is offline Find More Posts by Vitter
Old Dec 28, 2011, 01:46 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
looks fine to me
theKM is offline Find More Posts by theKM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 11:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 03:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) SmokeDogg Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 02:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 11:13 PM
