Old Oct 30, 2011, 06:53 PM
lawguy14 is offline
Find More Posts by lawguy14
United States, VA, Winchester
Joined Sep 2011
Question
Blade CX2-Play in inner shaft
Hello all. I need some help. I recently purchased the boomtownhobbies outdoor conversion kit for my CX2. I put the shafts back together and before continuing, I check to make sure I didn't have any play when pulling on the upper rotor head assemble connected to my extended inner shaft. Unfortunately I do have some up and down play and I can not for the life of me figure out where I went wrong. Any input would be greatly appreciated
lawguy14 is offline Find More Posts by lawguy14
Old Oct 30, 2011, 07:28 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Here is a break down of your model. Hope you didn't forget that brass washer. I've done it a couple times..
http://www.dacaur.com/heli/bcxhelp/BladeCXAssembly.pdf
PDF file. this will help you
There is a CX2 thread BTW...
http://www.rcgroups.com/forums/showt...07057&page=422
Mike.
BTW, welcome
Chap1012 is offline Find More Posts by Chap1012
Old Oct 30, 2011, 08:21 PM
lawguy14 is offline
Joined Sep 2011
Thanks Chap. I did remember the brass fitting. I will check out your info and let ya know how it goes. I can't wait to get this thing up and flying
Old Oct 30, 2011, 08:34 PM
flyeraroo is offline
Find More Posts by flyeraroo
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
Is the lower gear pushed up tight to the upper gear? I place the helicopter upside down so it rests on the upper rotor head, then push the gear on and tighten it down. This way there is no play when it's installed. The inner shaft may have moved up some when you pushed the gear on leaving a little play.
flyeraroo is offline Find More Posts by flyeraroo
Old Oct 30, 2011, 08:48 PM
lawguy14 is offline
Joined Sep 2011
I will give that a shot too. I thought I had pushed them together, but I may not have done that good of a job. I was reading another forum on here about a spacer or bearing between the upper and lower gear, but I don't have one. Is there supposed to be a spacer/bearing between the gears. If there is I guess I misplaced it somewhere. The exploded parts view in the manual is less than helpful on that area
Old Oct 31, 2011, 12:51 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Maybe they are talking about that brass washer I mentioned but, I don't see anything here...
http://www.helifreak.com/showthread.php?t=123920
Scroll down a bit for a blow up..
Mike.
Old Oct 31, 2011, 01:34 PM
"whirlydude"
flyeraroo's Avatar
United States
Joined Sep 2008
There is no spacer between the gears. What they may be talking about is the bearing that sits in the bottom of the upper gear. The lower gear fits up against the upper gear and rides on the race of that bearing. Lawguy, just set the helicopter upside down on the upper rotor head, loosen up the set screws in the lower gear, and push the lower gear against the upper gear and tighten the set screws of the lower gear. (your good to go!)
Old Oct 31, 2011, 02:14 PM
JackGist is offline
Find More Posts by JackGist
Joined Oct 2011
Also make sure you have the gears right-side up. I first installed the bottom gear upside down. Just a thought.
JackGist is offline Find More Posts by JackGist
Old Oct 31, 2011, 04:45 PM
lawguy14 is offline
Joined Sep 2011
Evening everyone. Thanks for all your input. That helifreak page is very useful. So I got most of it working. I still have one issue. The fixed issues with the play were the set screw in the upper rotor head was loose. I also determined my lower gear was screwed up where the screws go through holding the collar to it. I purchased a new lower gear and that took all the play out of it.
I put it all back together and spooled it up. The upper rotors spin very smoothly. My lower rotors have a terrible wobble in them. Not sure what the issue is. I also just put a new outer shaft in so I know its not bent. Any more ideas. You guys have been great so far so I know surely you can pull through for me again
Old Oct 31, 2011, 06:54 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Make sure your blades are balanced. IMHO ...very important! Click on my user name and that will take you to my blog on blade balancing. It doesn't take long to check them and well worth the effort. My blades track and fly perfectly
Mike.
Old Oct 31, 2011, 08:05 PM
lawguy14 is offline
Joined Sep 2011
Well Chap, I think I got it, however I won't be able to confirm this until tomorrow morning when the LHS is open. I knew I should have picked up a pair of blades tonight when I was there. I have 4 sets up upper, but no lower. I really had no clue how a pair of new lower blades with the same numbers on it could be so out of balance. My uppers balanced perfectly. Not so much with the lowers. I placed them between two cups. I set the blades horizontally, when I let go, they were so unbalanced that they were vertical. Yes, thats right, completely vertical. Think that could be causing the violent wobble and shake I was getting
Old Oct 31, 2011, 08:09 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Yes, quite possibly. You would be surprised! Just follow my instructions to balance them. Very easy! BTW, I always check every set of blades before they even go on my heli.
Mike.
Old Oct 31, 2011, 08:34 PM
lawguy14 is offline
Joined Sep 2011
Well a trip to the hobby shop in the morning and hopefully I will be good to go. I bought the outdoor conversion kit for this heli and have been eargerly waiting to give it a go. Maybe that will happen tomorrow
Old Oct 31, 2011, 08:41 PM
Chap1012 is offline
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
You don't need new blades. You just need to balance the ones you have.. Follow my instructions. You just need some sandpaper.
Mike.
Old Oct 31, 2011, 09:23 PM
kodak_jack is offline
Find More Posts by kodak_jack
kodak_jack's Avatar
Hilton (Rochester), NY
Joined Mar 2008
If I read what is and isn't in the Boomtown "Outdoor" kits, they do NOT include pivoting blade holders. Lawguy, when you talk about going to the LHS to get blades, are you refering to stock blades or pivoting blades? If you're talking about stock blades, the pivoting blade holders should have been your very first mod. You'll go broke trying to learn to fly this heli with blades that don't fold in a "mishap". I guess they assume you already did that mod.
kodak_jack is offline Find More Posts by kodak_jack
Sold CX2 Parts (inner shaft upgrade and upper blades) $12 shipped mrfliboy Aircraft - Electric - Helis (FS/W) 3 Mar 22, 2011 11:27 AM
Help! CX2 Inner Shaft Play seuaniu Coaxial Helicopters 2 Aug 21, 2008 09:30 PM
New Product Xtreme Blade Grips/Extended Inner Shaft - Blade CX2 Tom Z Coaxial Helicopters 22 Nov 03, 2007 10:25 AM
Discussion How-To: Replace a Blade CX2 Inner Shaft rbgrn Micro Helis 0 Aug 13, 2007 12:15 PM
Discussion blade cx2 inner shaft. bigred 1 Mini Helis 1 Dec 27, 2006 07:21 PM
