Old Oct 30, 2011, 06:32 PM
flying_rhyno is offline
Find More Posts by flying_rhyno
USA, IN, Hobart
Joined Feb 2011
what happens if you under-prop a brushless motor
anyone know what would be the consequences of using a smaller than recommended prop on say a 5055-320kv motor
flying_rhyno is offline Find More Posts by flying_rhyno
Old Oct 30, 2011, 06:34 PM
anthony7820 is offline
Find More Posts by anthony7820
Team CJ Youngblood
anthony7820's Avatar
United States, WV, Wheeling
Joined Jul 2009
The motor wouldn't get hot, you would get more flight time, and you wouldn't have as much power as if you used the recommended prop size
anthony7820 is offline Find More Posts by anthony7820
Old Oct 30, 2011, 06:35 PM
USA, IN, Hobart
Joined Feb 2011
any experts out there on propping motors???
when is it favorable to use 3 or 4 bladed props
Old Oct 30, 2011, 06:37 PM
teookie is offline
Find More Posts by teookie
Perfect 3pt inverted landing!
teookie's Avatar
USA, AL, Huntsville
Joined Oct 2008
Smaller prop just means you will draw less current.
teookie is offline Find More Posts by teookie
Old Oct 30, 2011, 06:40 PM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
in rc, the only advantage to multi blade props are ground clearance and looks. they are extremely inefficient in small sizes (read rc as compared to full scale)
rcbirk21 is offline Find More Posts by rcbirk21
Old Oct 30, 2011, 07:00 PM
USA, IN, Hobart
Joined Feb 2011
thanks everyone. Birk what do you mean by "read rc as compared to full scale? thanks
Old Oct 30, 2011, 07:45 PM
rcbirk21 is offline
rcbirk21's Avatar
Joined Aug 2004
just meant that on a full scale, the multi blade props all contribute to thrust, but on small scale stuff, the extra blades just get in the wake of the other blades and dont do as much
Old Oct 31, 2011, 08:26 AM
GIFLYRC is offline
Find More Posts by GIFLYRC
GIFLYRC's Avatar
INDEPENDENTLY POOR in OHIO
Joined Dec 2001
I see no disavantage as long as the plane flies the way you want it to.
On the plus side, everything runs cooler for more duration with less stress on the ESC, BATTERY, and MOTOR which can result in longer component life.
Roger aka GIFLYRC
GIFLYRC is offline Find More Posts by GIFLYRC
Alert Free speech in the USA and what happens if you try it outside a free speech zone treehog Life, The Universe, and Politics 32 Oct 03, 2011 10:24 AM
Maiden flight carnage (or what happens if you use the wrong E-Z connects....) rilysi Parkflyers 16 Dec 08, 2004 06:55 PM
What happens if you don't know what you're doing when towing.... 96S14 Scale Sailplanes 5 Nov 22, 2004 02:22 PM
What happens if you run a LiPoly to zero? (Alternate title: Up a tree without a clue) TJJ Batteries and Chargers 2 Oct 08, 2003 03:20 AM
What happens if you plug a servo into the rx backwards? Ben C Power Systems 7 Nov 25, 2001 04:02 AM
